Question about Toshiba Satellite A60 Notebook
Trying to change the power management option in the bios
I need help in changing my laptop so that when I hit any key on the wireless keyboard attached to my laptop that the computer comes out of standby. I can not find this power management option in the bios.. can you help ?
  • hammyslh Feb 07, 2008
    thanks - tried to make changes in the power options but wireless keyboard does not have that option. Also looked in the bios but there is nowhere to change the keyboard to have control. I need to have the keyboard to turn off standby because my laptop is stored away from the workstation.
    thanks,
    Problem Solver:
  • 9 Answers
Control panel >power options has all the settings to change what mode the computer goes into when you close the lid eg.sleep hiberante etc. so set that up for starters. when you close the lid on some laptops they go into hibernation which can be difficult to come out of. I find it best to put the computer in sleep mode when i go for a break, then it only takes one push of the button to continue where i left off
you can extend or turn off stanby or have it go into sleep mode automatically in the power option setting, and while in control panel check wireless keyboard has full control. The click of the mouse should reactivate it from standyby so try sleep for now.
I hope this knowledge helps you
good luck
Clapster
Posted on Feb 01, 2008
  • Clapton Stockley Feb 11, 2008
    why not set it to sleep after 3mins with a password to reactivate it if possible.Or have a black screen saver that looks off but is only in sleep mode if possibble and if necessary have the power saver to shut down when the lid is closed.......for now
    Clapster
Tip
How to troubleshoot keyboard issues?
Wireless Keyboard:
If only some of the keys don't work skip to the section Some Keys Don't Work below.
  1. Resynchronize the keyboard. Press the connect button on the keyboard for 5 seconds. Then press the connect button on the receiver for 5 seconds
  2. Change the batteries.
  3. Try reseating the receiver if possible.
  4. Try positioning the keyboard closer to the receiver.
  5. Skip to the section Generic Troubleshooting below.
Some Keys Don't Work:
  1. Check if any of the num lock key, shift lock key, etc are causing the issue. This is especially prevalent on laptops which don't have a distinct numeric keypad.
  2. If it's only the multimedia or hotkeys that don't work then try installing the specialized multimedia keyboard software that came with the system/keyboard.
  3. Try reseating the keyboard and rebooting.
  4. Go into Accessibility Options in Control Panel and check that Sticky Keys, Filter Keys and Toggle Keys are all switched off.
  5. Check if the problem occurs in the BIOS. A good screen to test with is the create BIOS password screen if the keys don't work here then a new keyboard is in order.
  6. Continue on to Generic Troubleshooting.
No Keys Work:
  1. Try reseating the keyboard and rebooting.
  2. Try power draining the system. This can be particularly effecitive with a laptop.
  3. If this is USB try a different port.
  4. Try entering BIOS - if you cannot get into BIOS then the keyboard probably needs to be replaced.
  5. Go on to Generic Troubleshooting below.
Generic Troubleshooting:
  1. Try uninstalling and reinstalling the keyboard driver and reboot
  2. Try system restore back to before the problem occurred
  3. Check for malware or 3rd party software that may be interfering with the function of the keyboard.
on Jun 10, 2010 | Computers & Internet
Wireless radio will not power on
Make sure the Wireless Switch on the side or in front of the laptop is turned on. Also you can toggle the wireless on or off by keystrokes. Normally you would Press and Hold the FN function key located at the lower left portion of the keyboard then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key will have the wireless icon signal )))) on it or it might have the icon of a tower with the wireless signal icon )))).
Try changing which way you connect with the wireless. There are two ways. One way is allowing windows to control the connection (called Zero Config) or you can allow the software that came with the wireless card to control the connection. If you open the software that came with the wireless adapter it will say something like: Let this tool manage the wireless connection or Let Windows Zero Config manage the wireless connection. Switch them and see if you are able to get the radio on and connect.
Apr 25, 2012 | IBM ThinkPad R51 Notebook
I have bad dvd writer i want to diable from bios What do i have to do Laptop Make:dell Model: studio 1537 Os: vista ultimate
Access the BIOS Wizard:
Turn off your laptop. Wait 15 seconds, then press the power button to restart the system. When the computer starts to reboot, press "F2" repeatedly until you see the message "Entering Setup" displayed.
Change the BIOS Settings:
Scroll through the BIOS settings using your keyboard's arrow keys to highlight the setting you want to change. Press "Enter." Use the the arrow keys to highlight the option you want within that setting, then press "Enter."
Save changes in the BIOS Wizard:
Press "Esc," then choose "Save and Exit." Press "Enter" to exit the BIOS with your changes saved.
Note:
You can disable the DVD Writer in the Device Manager also.
Start > Type " Device Manager" and then Enter > Double Click " CD/DVD ROM Drives" > Double click on the Device > Click on the "Drivers" tab > click on "Disable" to disable the Hardware.
Have a nice day.
May 30, 2011 | Dell Studio 1537 Laptop
I am unable to activate wireless card. I have to press Fn f2 key but the f2 key on my keboard doesn't work. I tried connecting a wireless keyboard (it doesn't have Fn key), then pressed Fn on laptop, F2...
It could be a drivers problem... Unistall the drivers from the device manager and install a fresh one from the dell website.. Try pressing the FN+F2.. Still no go.. Try to check whether the keyboard is working.. Still no go - resaet the Wireless card... Still no go.. Replace the wireless card..
Sep 06, 2010 | Dell Inspiron 6000 Notebook
My laptop keyboard not work at booting time
I would first try to reset the CMOS according to the manufacturer's instructions provided on the manual.
Try that, and please report back the results.
You might wonder what is CMOS?
Complementary metal oxide semiconductor (CMOS)
is a type of semi-conductor chip that holds data without requiring an external power source. In a personal computer (PC), CMOS holds the basic instructions the computer needs to initialize its hardware components and boot up. These settings are known as the basic input output settings (BIOS), also referred to as CMOS settings.
Steps to Reset CMOS - BIOS Setting.
Turn on your computer and press the key on your keyboard to enter the BIOS. This is typically the Del (delete) key. Pre-built systems from major manufacturers may use a function key such as F1, F2, or F10. Go to the last tab or page of your BIOS. Select an option similar to "restore factory settings". Save your changes and confirm your selection if necessary. This will often be combined with the process of exiting a BIOS. Some BIOS types may have this as a separate option such as "F10: Save Changes".
Please let me know if you have any further questions or concerns.
Thanks.
May 04, 2010 | HP Compaq Presario C500t Notebook
I have a toshiba laptop & half the keys on the keyboard won't work
Try to go first to Safe Mode.
Bring up the "Start" menu. Select the "Shut Down" option and then click "Restart."
Wait for the Toshiba Satellite A105 laptop to begin its restart procedure. Press the "F8" key at regular intervals (every 3-4 seconds) when the Toshiba logo pops up on the screen.
Continue tapping the "F8" button until the advanced Windows options menu appears. Use the down arrow key to scroll through the list of advanced Windows options.
Highlight the option labeled "Safe Mode." Press the "Enter" key and wait for the operating system to load in safe mode.
On Safe Mode try to use the keys that are not working if it's woking it's a software problem and you need to have a System Restore for the laptop.
If it's still not working go to BIOS Settings of the laptop try to reset it to default settings.
Hit the "Power" button to turn on the computer. Press the F2 key on the keyboard. This must be done prior to the operating system loading; if the Windows OS logo has popped up, it is too late. Boot into Windows, restart the computer, and try again.
Pressing F2 on a Toshiba laptop takes you directly into the BIOS, and any settings can now be changed.
If you have successfully entered the BIOS Phoenix press F9 there will be an option that will pop out after pressing F9 the choose yes, after that press F10 there will be an option that says "Save and Quit." This will save any changes you've made, exit out of the BIOS, and restart the computer. Choose yes again, after that process the laptop will boot up now to your Windows Screen.
Try to use again the keys that are not working, if it's still not working definitely that's a hardware problem, you need to contact Toshiba Technical Support here's the phone number
800-247-7777
to assist you further with this problem or you can drop your laptop to a nearest Authorize Service Provider for Toshiba near in your place.
Hope this helps. :-)
Mar 22, 2010 | Toshiba Satellite A100-S8111TD Notebook
The ps2 ports for both keyboard and mouse do not work. i got around that by hooking both up with a usb connector. BUT when the computer is on with no mouse activity for a while, the mouse ''dies.'' Then...
HI,
Go into the BIOS utility and set the BIOS to defaults, hit F10, save the changes and exit the BIOS, the computer will restart, see if that helps.
To get into the BIOS hit the Esc or Del key when the computers just starting up.
Good luck.
Sep 14, 2009 | E-Machines eMachines Desktop PC
Dell 1200 Inspiron OS boot problem
Two things you should try to resolve this issue: -
  • Check that the FN button on the keyboard to switch from the Laptop monitor to external monitor has not been enabled - these are usually 3 state switches (Laptop screen ON, External screen ON, Both ON) it is really easy to accidentally hit this without realizing.
  • If this works there is no need to try the second option.
OR
  • Try booting to safe mode - as the laptop boots up and you see the Bios summary screen depress the F8 button and you should receive a screen containing several options.
  • Select the option to Boot to safe mode.
  • If the laptop boots up ok then login to XP, don't be alarmed at the change in screen resolution.
  • Right-click My Computer on the desktop and select Properties - Hardware - Device manager
  • In the tree-view containing the different hardware select Display Adapters you should see your graphics card in there
  • Right-click and select Scan for Hardware Changes if it is ok the close and reboot as normal
  • If there is a problem here it implies the driver is somehow corrupted and may need re-installing from the disk that came with the laptop.
Nov 15, 2008 | Dell Inspiron 1200 Notebook
More help needed pls !!!
I am not the first one that helped you.
If you have a program for your wireless you should be able to bypass the button. You can also check in your BIOS to see if there is a way to keep it on. To get into the BIOS you will have to hit the DEL key or one of the F keys.
May 29, 2008 | Computers & Internet
Toshiba Satellite A60 Notebook Logo
129 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
