Question about Dell Inspiron 8500 Notebook
Notebook System Crash
My wife was using my laptop (Dell Inspiron 8500) and the thing just crashed.  She was using a program called Second Life.  She said the graphics went a little weird and there was an error message.  The screen went black and emitted a couple of beeps.  She left it alone and then it let out a long, continuous beep for about 2 minutes.  She pressed and held the power button until the laptop shutdown.
Now when we try to turn it back on it ends up going to a blank dark screen. The laptop powers down simply by pressing the power button once. Sometimes I can see the screen suggesting I press F2 as an option (like before) but nothing happens.  Occasionally it will boot up all way to the starting screening displaying the system loading but it eventually goes black.
I took out the hard drive and backed it up to another hard drive.  Does anyone know a way I can fix this problem?  I thought I might be able to restore the system, but I can find a restore CD that came with the computer.  Plus I can't interact with the system.  My end all solution will be to get another laptop if I can't fix this one.
Thanks in advance for any help.
  • 1 more comment
  • SeanJohn79 Feb 02, 2008
    Thanks a lot for the suggestions guys.  I used the F8 key to boot my system in safe mode.  While in safe mode, I had a lot of graphic distortion with lines steaming through.  That kind of stuff. I ran Norton AntiVirus and scanned for viruses, but nothing was found.
    I tried restoring the system back to an earlier date.  The first attempt was unsuccessful.  The second one brought be back to the computer blacking out.  While it's booting the random lines appear but no loading screen.  I'm trying my best to get back to safe mode.  If I'm able to do that, what do you guys think I should do?
  • Marty marty May 11, 2010
    if you have gone this far as: "Occasionally it will boot up all way to the starting screening displaying the system loading..", then you may try hitting F8 just after the BIOS screen to select safe mode-last known good startup...
  • Anonymous Mar 20, 2014
    does the same thing on reboot after restore
    Sergeant:
  • 201 Answers
Hey there SeanJohn79, have you tried hooking an external monitor to your laptop. You can move the video output back and forth, from external, LCD + external, LCD using Fn + F7. Hopefully this will allow you to see the necessary info for diagnosing the problem. Good Luck. Keep us posted! In case you are not aware, these are some display related key functions:
Fn + F3 = turn off lcd
Fn + F8 =Switch computer screen size
Fn + F12 =Hibernation mode, power for 4 secs releases.
Fn + F4 = Standby mode, press Fn key to return to normal
If you haven't tried switching some of these, give it a shot.
Posted on Feb 01, 2008
My DELL Inspiron 1525 won't connect to the Internet, all applications crash, it won't detect my flash drive, and it won't detect my networks.
Hi
Have you done a full system virus scan to see if you have a virus if that isnt the case
you could try a system restore bac to when it was ok
Nov 13, 2010 | Dell Inspiron 1525 Notebook
I have a Dell Inspiron E1505 laptop PC that crashed and will not boot up. What can I do?
You can try to re-build the operating system with the original disks.
You can get a new hard drive and reinstall the OS.
You can boot to Bart PE or other type of system disk to investigate the cause of the crash and try to repair it.
Dec 07, 2009 | Dell Inspiron E1505 Notebook
Dell inspiron 1545 laptop not working
Sounds like the hard disk could have went bad. try running a diagnostic from your discs and if you receive an error, report it here or to Dell. If you did crash the hd, you will need a new one. I hope your machine is under warranty.
Nov 05, 2009 | Dell Inspiron 1545 Notebook
Dell Inspiron 8500 PC Notebook won't enable radio by pushing Fn+F12
run system restore if fails
update the BIOS if fails
reinstall the dell quickset
Oct 15, 2009 | Dell Inspiron 8500 Notebook
Turbo c is not working in full screen in windows 7. Please let me know if you know the Soluation.
Vista and upwards do not support full screen for DOS applications. If you need to use it in full screen mode, use DOS BOX. But it will crash if you perform pointer or memory based operations.
Oct 02, 2009 | Dell Inspiron 1501 Notebook
My dell inspiron 8500 wont start up whit the battery
if it is the original battery, it most likely needs replacement. Portable batteries have a expected life of 300 to 500 recharge cycles (18 to 24 mos) If a new battery does not charge, then a motherboard replacement is warranted.
Oct 01, 2009 | Dell Inspiron 8500 Notebook
Cannont find drive 0
Your hard drive has probably crashed.
You might want to have a local tech check it out to make sure.
Jun 19, 2009 | Dell Inspiron 8500 Notebook
Windows crash
These are operating system errors. Start by doing a check disc from the bios or set up. The check disc is a hard drive test, if anything fails then you have a hard drive crash and you will need to replace the hard drive. If it passes, then you will need to run a repair on the operating system using your recovery or operating system disc. If you have any hang ups or issues during or after the repair then you will need to completely reload a fresh copy of the operating system.
Jul 17, 2008 | Dell Inspiron 8600 Notebook
Dell 8500 loading issue
The symptom that you have written suggest it to be a motherboard failure. To determine the same, follow the steps in the link below
http://tinyurl.com/6ccrbx
Thanks
Mandeep
Jun 05, 2008 | Dell Inspiron 8500 Notebook
Open Questions:
Dell Inspiron 8500 Notebook Logo
135 people viewed this question
Alun Cox
