Question about Epson Stylus C46 InkJet Printer
Which port do i use?
I cant print from word and think i may have the wrong port selected! i have a choice of about 8 and am currently on usb. as i am thick when it comes to anything like this i am completely stumped. i could print before so i dont know what has changed? i have done a test and that seems ok. unfortunately i cant find the instructions.
please help.....frustrated
  • 1 more comment
  • Anonymous Feb 03, 2008
    I have the same damn problem. does anyone know what to do? which port? I tried lpt 1 and usb. any one know what to do?
  • rc004u2340 Feb 04, 2008
    I am embarrassed to admit that I tried a lot of other things trying to get the printer to print. I cleaned the heads and that showed me all was ok, but then I went the whole hog and cleaned the nozzles......that seemed to do the trick, so it seems ( in my case) that was my problem. Next time I will try that first.
    Good luck to the person who has the same problem. Try what I did! you never know. The port is still USB.
  • Raniel Diokno
    Raniel Diokno May 11, 2010
    What windows version are you using? Is the printer directly connected to your computer?
I am using Windows XP, the printer is directly connected to my computer. the port is the USB one. Good Luck
Posted on Feb 07, 2008
Print color photos with windows 10 and HP printer
First and foremost, use the most current HP drivers for that model of printer. The two choices you have are printing in color directly via the printer itself. Naturally you can print from the class or inserted USB/Card reader slot. OR you can print from the Computer's devices matched to the printer. To get proper results: Down load the current updated HP drivers for your computer to communicate with the printer. Use the HP software to select either color or b/w. Also make certain the HP Printer FIRMWARE is up-to-date. If all of the software is current, you should only need the HP programs to select your choices and no other apps are necessary.
Jan 12, 2018 | HP Office Equipment & Supplies
How do I print from a USB flash drive to a Toshiba Studio 3040C photocopier
insert the drive into the usb port hit print choice find usb open it select your file hit start
Apr 07, 2017 | Toshiba E-Studio 3040c Copier
How to delete console port and telnet passwords through BootROM?
1. Connect a PC to the device with a serial cable and log in to the device through the console port.
2. Restart the device. When the message "Press Ctrl+B to break auto startup ..." is displayed, press Ctrl+B and enter the password to display the BootROM main menu.
3. Select choice 4 to enter the Startup Select menu.
4. Select choice 1 to view the system configuration.
In V200R001C01SPC300 and later versions, you can use the following method to view the configuration file. In Huawei V200R001C01SPC300, the menu choice is Startup Information. In Startup Information and later versions, the menu choice is Display Startup.
Startup Select
1. Display Startup
2. Set Boot File
3. Set Config File
4. Startupfile Check Manage
0. return
Enter your choice (0-4):1
************** Current Stratup info ****************
Valid Flag State : Vaild
Boot File Name : sd1:/software.cc
Config File Name : sd1:/vrpcfg.cfg
Licence File Name :
Patch State : Deactivate
Patch File Name :
Voice File Name :
In V200R001C01SPC200 and earlier versions, the configuration file cannot be viewed. The system often uses the file vrpcfg.zip or iascfg.zip.
5. Rename the configuration file.
6. Restart RouterA.
7. Stop Auto-Config.
8. Change the renamed configuration file to executable file. Select one file format.
9. Restore the configuration.
Aug 19, 2015 | Computers & Internet
Printer is too slow to print once the command is given from PC
Hi
While printing from the USB Port sometimes slow printout/data transfer will result in slow printing of print jobs. or The printer might be printing slow , pausing in between print jobs , or intermittent printing. The symptom solution is mention below, read and follow the instruction.
Solution 1
After the printer is installed on the USB Port, check the description under the Ports Tab what is selected. Please refer to the figure below : c00873625.jpg Using the USB/ Virtual Printer Port and DOT4/ HP Laserjet 2420, under the Port/Description Tab printer speed will be as per the standard. Whereas using the DOT4/ Generic IEEE 1284 under Port/Description Tab, Printer speed will be very slow. If DOT4/ Generic IEEE 1284 is selected by default, then you have to uninstall the USB driver from the Device manager and plug in the USB cable again. Then it will detect the printer and USB port with respect to the printer model. Insert the Driver CD as prompted and by default it will select the DOT4 HP LaserJet2420 Port.
Solution 2
  1. Insert the HP LaserJet 2400 print series CD-ROM.
    NOTE: If the HP Software does not automatically start, click Start , Run , and then Browse . Browse to the CD-ROM drive at the top of the window under look in and select Setup.exe .
  2. Select Modify Installation . Figure 1: Modify Installation c00369540.gif
    NOTE: If Modify Installation is not available See Modify Installation is not Available.
  3. Select the Language of your choice. Figure 2: Select Language c00369541.gif
  4. Click Next. Figure 3: Setup Wizard c00369542.gif
  5. Verify Reinstalling an existing printer is selected. Under Select the port for this printer , choose USB001 or Dot4_00x and click Next . Figure 4: Choose Port c00369543.gif
  6. Select desired Features and click Next . Figure 5: Select Next c00369544.gif
  7. Click Finish . Figure 6: Select Finish c00369545.gif
Uninstall options
  • First verify if an uninstall options is available. If an uninstall option is available under Start, Programs, HP LaserJet 2410 2420 2430 , use this method to uninstall the printer.
God Luck
Sep 09, 2011 | HP LaserJet 2420 Printer
PrinteInkjet download error
Check the printer ports, it is probably that your printer is connected to a wrong port. You have to go to printer properties and then to "Ports" If your printer is connected via LPT1 this port must be selected or if your printer is connected via USB port the "Virtual USB port" must be selected.
Jan 06, 2009 | Lexmark JetPrinter Z25 InkJet Color...
Why is my printer showing a idle status and not printing?
I believe the printer is connected via USB.
Check in device manager if the LJ 1020 printer is listed.
If yes, go to the driver properties > ports tab and Select the appropriate port for the printer
Alternatively, uninstall the full software and reinstall it again from
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=439320&
- Nikhil
Nov 18, 2008 | HP LaserJet 1020 Printer
Hello I can't seem to get my x5650 lexmark printer to print think my computer has it set up via waveless instead of usb.
When you loaded the drivers there may have been an option to select parallel port or USB if so you may have selected the wrong one. If so reload drivers and watch out for this option. Hope this helps
Sep 27, 2008 | Computers & Internet
Canon MX700 network problems
Once you have it installed and working on the USB port go to the properties page of the printer.
1) Select the "Ports" tab.
2) Select "Add Port".
3) Select "Canon BJNP Port".
4) Select "New Port".
5) Fill in the IP Address of your printer and select "Next".
Make sure that the Port is checked back in the properties page and select "Apply" and your done. Do a test print and your printer should work on your network. You may still need to fix the settings on your firewall or router to allow access if it does not print.
Sep 04, 2008 | Canon MX700 Office All-In-One InkJet...
Printer will not print
Some thoughts.
When you plug it into the computer that it will not print to, Does it tell you there is a new USB device found?
2. I am sure you have tried different USB ports on the computer.
3. Right click your printer to access the properties on the driver and select Ports and see if that somehow was changed.
4. Just delete the printer from the "printers" page in control panel.
Then click add printer and search for it.
5. Make sure the computer does not have a firewall that is blocking the printer.
6. Make sure there is no job error in the print queue.
7. Be sure the printer is selected as the "Default" printer. If there is another printer loaded on the computer, is the wrong one selected?
8 Make sure Print Pause is not selected.
I do suspect once you open the properties on the driver page you will find the problem. Unless of course your USB port or ports on the computer have failed.
Dec 14, 2007 | Samsung SCX-6320F All-In-One Laser Printer
ALPS Printer MD1000 Driver
Several things about these printers.......
1. Do NOT use the MS XP driver for these - it has limited functionality. Download the Alps driver, which you can find in the files section at the Alps YahooGroup (http://tech.groups.yahoo.com/group/Alps/files/)
2. The printer requires bi-directional comms in order to feed back the printer status to the computer. While this is not an absolute requirement, it means that without bi-dir comms, the error light will flash, and you won't know what the problem is.
3. The driver is hardcoded to only communicate bi-directionaly with Alps virtual LPT ports - run this with a non-Alps cable (And all of the cables on FleaBay are non-Alps), and you will not be able to monitor the printer status.
Now, how to install.....
1. Plug in the USB cable to the computer (But not the printer), and let it install. Reboot if required (Unlikely)
2. Install the Alps driver you downloaded fron the Alps YahooGroup. Reboot if required. If you now look at Printers in Control Panel, you will see a nice Alps printer there, waiting to be used. Make a note of what it named.
3. Plug in the printer and turn it on. XP will now tell you it has found new hardware, and install the MS driver. Reboot if required
4. Go back to Printers in Control Panel. You will now see you have TWO Alps printers! The MS driver will be called something like "Alps MD-1000 (MS)". Rename (DON'T delete!) this driver to something like "Alps MD-1000 (DO NOT USE)". If you delete it, it will come back to haunt you every time you switch on the printer, and screw up your settings.
5. Open the properties page of the driver you made a note of in step 2 (Control Panel -> Printers and Faxes -> right click on printer, and select "Properties"), and click on the "Ports" tab.
6. Check the checkbox next to the port created for your USB-// cable, and uncheck the other box that will be checked.
7. Uncheck "Enable bidirectional support"
8. Click on the "Advanced" tab
9. Select the "Print directly to the printer" radio button
10. Click on the "Print Processor" button
11. Select ALMD224S as the Print processor and select RAW(FF AUTO) as the Default data type
12. Click Apply.
Sep 23, 2007 | Alps MD 1000 Thermal Printer
Epson Stylus C46 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
