Question about Akai LCT2701AD Television
Humm coming from speakers - can't get cable to work
I just purchased a used Akai 27" LCD HDTV Model # LCT701. Now that it is powered up, there is a hum coming from the speakers. I know it is from the speakers because it goes away when I use the mute, and when I wiggle the cable connection I can hear the hum change, as if it is coming in with the cable signal.and it goes away completely when I disconnect the cable as if it is some sort of misread signal.
Also, I screwed the coax cable into the only screw jack on the back, labeld "rf input" but for some reason am not able to get more than one channel. when I choose sources and roll through the sources with the remote, most show "no signal", except for the DVD. here is a list of the screen shots and what they say.
VGA - blue screen - text reads - main no signal
AV - blue screen - text reads - Main no signal
S- video - blue screen text reads - main no signal
Component - blue screen - text reads - main no signal
Channel 5 - Dr. Phil followed by Oprah
HELP! :D
I am wondering if I am plugged into the right port and also if I need a filter to stop the buzz? Maybe I'm plugged into the wrong place and the signal is being misinterpreted as noise?
Thanks in advance for any ideas.
  • Curtis336 Jan 31, 2008
    Thanks for the response, but channel five is the only channel that I get. And when I try to change it, it goes to a gray/black screen, sits there a few seconds, then goes back to channel five. I've tried doing a channel search and it searches, but doesn't add any channels.
    The hum is constant, and it starts as soon as the cable housing makes contact to the metal of the rf in. I've touched it to the audio out and it makes the same noise. When I plug the cable back into my other television however it works fine, no hum.
  • Curtis336 Feb 01, 2008
    Ok.. Maybe I figured out the problem? This is an HDTV, and I have what I think is standard cable. Could this be the problem? DO you need HDTV service to feed an HDTV? It's as if the TV doesn't read the signal at all, although all the other inputs that I tested seem to work fine including the built in DVD player. The only problem is with the cable input. No channels, and an annoying, ever present hum.
    The only other thought is some sort of grounding incompatability between the cable and the set.
    Any thoughts?
    Thanks in advance.
  • 28 Answers
The RF input is the correct one for a cable signal. The other sources use the RCA and other ports which you can connect to other devices, like DVD or VCR players.
If the humm noise only happens when you're on the TV channel then it's likely just the station. Try changing the channel and see if that helps, and make sure the coax is screwed in all the way. Also make sure the other end, if connected to a VCR or other stuff, is tightly attached. If you share cable with many other people and the signal has snow (white spots on the TV), then you may need to buy an RF signal amplifier to reduce the noise.
Source changes the input (RCA versus coaxial versus component inputs), change the channel for different channels..
Posted on Jan 31, 2008
6ya staff
SOURCE:
My akai lcd tv model lct2721ad sound will not work.
We need to verify if the problem is in the preamp or poweramp sections. Hook up the powered PC speakers to the AUDIO Line out RCA jacks and verify that sound is OK there, if it is OK, The problem will be in the power amp sections that drive the speakers. If it sounds bad at the RCA jacks, the problem will be in the sound processor board which mean the main board will have to be replaced, same if the power amp is bad.
Nov 06, 2009 | Akai LCT2715 27 in. LCD Television
Akai TV remote is not working correctly
I don't think the Akai remote is designed to work with cable or satellite service. I have to use both remotes & I have Direct TV.
Try unplugging the TV for a few minutes then plug it in and try the remote again. I had the same problem shortly before my Akai LCT2721AD quit working altogether. Three 1000uF capacitors blew in the power supply. Bought 3 new ones and replaced the blown ones myself rather than pay over $100 for a new power supply. Works fine now.
Oct 23, 2009 | Akai LCT2721AD 27 in. LCD Television
I have a Akai 27 inch LCD HDTV will not Turn on
power pack most likely they blow capacitors all the time easy fix for some one who can solder.
Mar 26, 2009 | Akai LCT2715 27 in. LCD Television
Connecting ps3 to akai lct2060
I had mine connected with HDTV cables with no problem. It also took care of the poor sound quality issue with the internal dvd player.
Dec 25, 2008 | Akai LCT2721AD 27 in. LCD Television
Akai 27"
Hello, I can repair your power supply which is most likely the reason for this failure. I charge a flat rate of $100 + return shipping to recondition the power supply.
I have created an Instructable located here http://www.instructables.com/id/AKAI_LCT2715_Power_Supply_Removal/ which will guild you through the removal of the power supply from the TV. Once you have the power supply removed you can ship it to me for repair. E-Mail me at (twizted at dragonmodz dot net) for shipping address and to discuss any other questions you may have.
Dec 12, 2008 | Akai LCT2715 27 in. LCD Television
I need help tv lcd akai model lct2785ta
You do know that this model TV takes about 5-10 seconds to come on after you press the on button, right?
Press it once to get the green LED, then wait. If it doesn't display the blue AKAI splash screen within 15 seconds, the TV is not working as it should.
Also remember that this model has two RF input jacks. As seen from the back of the TV, the jack on the far right is the one to use for analog TV, analog cable, coax out to TV from a cable box, or rf out from a vcr.
Don't use the one on the far left. It is for input to the ATSC OTA DTV tuner only.
Most likely there is a real problem with your TV, but in the video, you are pressing the on/off button in rapid succession. That will never work with this model.
Jul 12, 2008 | Akai LCT2785TA 27 in. LCD Television
Attaching Wall Mount Support to AKAI Flat Panel
You use the four outer holes as suggested in the manual on page 12, see below:
Apr 23, 2008 | Akai LCT2721AD 27 in. LCD Television
Akai LCT2701AD - 27' LCD TV/DVD Player Combo
I don't know if I solved the problem. I find though if I turn the TV off and unplug it and then plug back in when I want to watch it - it works. I don't know why but it does. My remote still does not connect to the LCD but I have cable HDTV so chanel changes work from that control.
I am pretty ********** that it is only a year old and this has happened but what can you do? We live in a disposable world.
I was trying to get to your Premium assistance Plan from where I wrote my issue but I don't know where to pay or what to do on your site it keeps taking me all over.
Mar 15, 2008 | Akai LCT2715 27 in. LCD Television
AKAI LCT2715
I replaced 19 filter caps in LV power supply.
There were pruffed up on top
Mar 11, 2008 | Televison & Video
Remote Control Programming
GE Universal remote only $12.00 at Target works on my Akai LCD HDTV, this remote also has learning capability but the third code under Akai worked!!!
Jan 24, 2008 | Televison & Video
Akai LCT2701AD Television Logo
206 people viewed this question
Top Akai Televison & Video Experts
KISHORE DESHPANDE
Ekse
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
