Question about Toshiba Estudio 200L Copier
Printing on Manilla Folders
How can I print onto manilla folders without getting a paper jam?
    New Friend:
  • 120 Answers
Try feeding them thru the bypass on the right side. this way they will go straight thru without having to turn aroung the bend.
Posted on Feb 01, 2008
Sir ,ir 2020 paper jam at fusing unit.some times half of paper will come out,sometimes jams at the entrance of fusing unit.i changed every sensors,then changed new fusing unit,then feeding assembly...
Sometimes you can vlear a fuser jam with a manilla folder. Open the copier let it coll a bit and slide a manilla folder through the fusing unit. If it is just pieces of stuck paper the folder can sometimes push them out of yhe wsy ad you gorce it through and pull it out the other side. The fuser has two rolls one heat and one pressure both of these rolls have small fingers which are supposed to kerp paper from sticking to them. Sometimes these fingers get bent or damaged and this causes the actual jam. There is also an exit sensor that detects jams in this area it can have a damaged part as well
Jan 20, 2018 | Canon iR 2020i Laser Printer
Error message to "Load Paper"
Push something thicker than a plain sheet of paper through. Cut a side of a manilla folder into a 8.5"x11" and let the printer try to grab it during a copy. After doing it's normal "grab the right side until it's skewed and stop", continue to try to push it through.
Nov 30, 2011 | Canon imageCLASS® MF4150 All-In-One Laser...
I have got an envelope stuck in the envelope slot.
You will need to carefully remove it and avoid using any sharp objects when doing so. Turn off the printer at the mains while doing this. All traces of the envelope will ned to be removed as the printer will then report a paper jam if not and not operate until all traces are removed.
Sep 30, 2009 | HP PSC 950 All-In-One InkJet Printer
Minolta EP 2050 CS Pro
This machine has been discontinued for some time now. Not sure exactly how long but I haven't seen one in the field for a while. try taking a manilla folder a manually feeding it through the same direction as the paper goes through the machine afterr pulling out the paper tray all the way to see if you dislodge any paper. Other than self remedies, it isn't worth the money for a service call.
Apr 08, 2009 | Konica Minolta Office Equipment & Supplies
Printer keeps reading paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 07, 2009 | Canon MX300 Office All-In-One Printer
Clearance Specs For ignition module to magnet on 25cc engine.
.010"(.25mm) you can also use an index card or manilla folder
Sep 19, 2008 | Poulan Garden
"Paper Jammed"
Yes I have the same problem :-( I have lots of work to do!!
Apr 13, 2008 | Canon PIXMA MP170 All-In-One InkJet...
Paper Jam in MP Tray under the Roller
Push a thick manilla envelope through the area with the machine open to try and get the pieces out. Be careful not to damage the drum unit with rings on your fingers.
Jan 28, 2018 | Brother HL 1850 Laser Printer
1,658 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
