Question about Samsung DynaFlat CXM2785TP 27 in. TV/VCR/DVD Combo
Samsung CXM2785TP When I got the tv from a friend it had no power.I found the horizontal output transistor shorted and replaced it.Now the tv fires up but the screen is very bright with white horizontal lines.I cannot run it for too long as the horizontal ouyput transistor gets very hot.There is no video,audio,or on screen display. As it warms up the high voltage drops to 25kv.The B+ voltage should be 200v but is 230v.
  • 2 more comments
  • Rick53 Feb 02, 2008
    I would like another opinion.
    I don't know what you mean by floating the B+ output of the FBT. Could you explain further? thanks Rick53
  • Rick53 Feb 12, 2008
    I have checked the Flyback Transformer and Yoke with a Sencore Ring Tester and they checked OK. Any ideas where to look now?
  • Rick53 Feb 24, 2008
    Well guys, I finally found the problem and thought you would like to know what it was.I checked the flyback and yoke with a ring tester and it chacked OK. I was reinstalling the flyback by soldering some connections and not others but didn't help. You mentioned the CRT board with possible shorted outputs so they were checked and were OK. When I removed the CRT board from the Picture Tube the heavy current load went away.I reinstalled the board and the tube lit up with On Screen Display came on.I checked the HOT for overheating and it was normal.I removed and reinstalled the board again and it acted up again. It seemed like an intermittent connection so I resoldered all the CRT PCB connections as I could not find any One connection that was the problem.I have had another Samsung TV before that was acting erratically and it was intermittent, so I soldered the entire PCB and has worked perfectly for over a year now.Poor solder connections may be a problem with Samsung TV's.Thanks for the help guys as it is now working perfectly.I have also resoldered the main PCB to be on the sefe side.
    Sincerely,
    Rick53
    Brigadier General:
  • 6,966 Answers
With the indulgence again of robotek,
1. 230V instead of the B+200V - normally I use A variac to supply a unit in question. This way I have control of the input voltage which reduces risk of burning a component such as the Hout.
2. Overheating Hout - is indicative of a short in the FBT area or its output including the vertical (as robotek have posted). You can try having the FBT tested and/or run the unit with the low B+ output of the FBT floating and determine which one causes the Hout to overheat.
3. In some Samsung units that I have worked on, the Yoke tends to be the culprit when the Hout burns out or overheats.
Hope this be of additional help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Feb 02, 2008
  • 2 more comments
  • Louie  Role
    Louie Role Feb 02, 2008
    Hi again,
    Floating the B+ output of the FBT - refers to desoldering some of the
    FBT pin/terminal connection points going to the diodes. Pls refer to
    the images below:
    normal solder floated/desoldered pins
    Going back to your initial post:
    1. screen is very bright with white horizontal lines - indicates
    excessive screen voltage normally adjustable using the screen control
    located at the FBT or if something in the HV is way off;
    2. Hout transistor gets very hot - as posted initially, indicates a
    short or partial short. If the FBT doesn't heat as well, then it can be
    a HV cap or the yoke. If the FBT heats up likewise, then it can be the FBT
    itself or any of its load;
    3. There is no video, audio or OSD - more often B+ supplying these secondary circuits are from the FBT. These normally 12~18, 36~42, 80~100;
    4. As it warms up the high voltage drops to 25kv - normal tendency if something is still wrong with the HV section;
    5. The B+ voltage should be 200v but is 230v - this appears to be another issue on the same unit. As robotek have
    posted seems to be a power supply problem. Not unless you are measuring
    the B+ at the collector of the Hout which tends to give you erroneous
    DC readings due to the HV & Hfreq component. You might get more
    realistic B+ readings at the FBT pin that leads back to the PSU.
    Things that you can try:
    a. Float as above described;
    b. Remove the 4-wire yoke connection. Even with no display, you can still assess if the Hout will abnormally heat up;
    c. desolder/remove the FBT and have it tested;
    Pls post back any development(s) or lack thereof.
    Cheers.
  • Louie  Role
    Louie Role Feb 04, 2008
    Hi robotek,
    Appreciate the pat on the back and likewise the invite to be your tech buddy.
    Regards all.
  • Louie  Role
    Louie Role Feb 12, 2008
    Hi again Rick,
    Copy your last post. To summarize so far:
    a. The HOut, FBT and Yoke has been checked and determined OK;
    b. the unit powers up but HOut heats up;
    c. you have floated the FBT's secondary outputs but still the HOut heats up;
    d. you have determined/verified that there are no shorts in the FBT's secondary circuitry which includes the Vertical (36~42VDC), Color Drive (80~100VDC) and audio (12~18VDC).
    What can still be checked:
    1. IF there is a tripler, that could be a possibility;
    2. the three (3) color drive transistors at the small PCB at the rear of the CRT's neck. If there is a problem with one of them, the screen tends to be very bright with fine slightly diagonal retrace lines;
    3. the power supply section, if the should be 200B+ is still reading 230.
    Since the Samsung DynaFlat CXM2785TP is not readily available in my region, I have no service manual/schematic hence have to resort to winging it based on other comparable models.
  • Louie  Role
    Louie Role Feb 25, 2008
    Hi again Rick53,
    Glad that your TV now works and to have been of some assistance. Thank you too for sharing the information/update.
    Would also appreciate if you can rate the posted solutions as you see it fit pls?
    Thanks in advance.
    Genius:
  • 3,422 Answers
I think the controller IC chip has gone kaput. BUT, it could also be just a software glitch. So, try a hard reset and see if it solves the problem. If it does not you will need service. If still under warranty the factory service center should take care of it.
Do a hard reset by unplugging the power cord, as you have been doing, but a complete reset requires the power to be unplugged for at least 4 hours. Then when you turn it on all the internal soft codes will boot up to factory default settings.
Also, just in case there are loose connections or cold solder joints at the root of the problem, with your hand or fist go around and smack on the cabinet front, back, sides, etc. to see if that will wake up any dead connections.
if the above above method doesn't solve the problem then it is a bad power supply. a repair cost will range around $120-200. samsung tv's are not what everyone thinks they are. they do not last long.I would suggest you to call a repairman..
Goodluck,
Don't forget to rate me as fixya..
  • 1,512 Answers
It will have a short in the vertical stage or power supply to it, and maybe even a power supply regulation failure(high voltage) that set the whole thing in motion. I will do some research for you and get back real soon :)
Posted on Feb 01, 2008
  • Graeme Ross
    Graeme Ross Feb 01, 2008
    the power supply needs to be rebuilt. electrolytic caps and so on, the high b+ voltage will be affecting all stages of the set and you will need to attend to the that first. The set may not even be worth repair if it has multiple failures.. sorry to have say that to you mate. Good luck and BE CAREFUL with SMPS stages of the set. If you want more particulars of the repair... i will pursue for you. Consider a less blown up one to restore i suggest as the best outcome.
  • Graeme Ross
    Graeme Ross Feb 03, 2008
    heheh well done Benimur... I actually read it as the set had a vertcal collapse not retrace lines for some reason... Nice breakdown of the problem in your speil... you da man :)
What's the cause I already install three horizontal output of Samsung TV model number CT-15N30MJ always busted horizontal transistor?
Check the capacitor connected to the collector of the horizontal output transistor to ground for loose solder or open. Replace that freewheeling capacitor [ usually comes between 3900Pf to 9600Pf 2000V]. Replace it with an other one of same capacitance value; before proceed. Even if it blows out the horizontal output transistor; entire circuit should be checked. Check the deflection coil too for shorted winding.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Apr 26, 2015 | Samsung Televison & Video
Picture on Samsung TXL2791F gets smaller after a few minuets
The horizontal output transistor that drives the flyback transformer overheats now. There might be other reasons too for this fault. If the flyback transformer has any internal winding short, this transistor will overheat.
Just replace the horizontal output transistor. Check its heat. If the newly replaced transistor too overheats, replace the flyback transformer.
May 24, 2012 | Samsung TXL2791F 27" TV
MY TELEVISION DOES'NT POWER UP.
Hello
Check its horizontal output transistor for short circuit. It is a common fault to all type of CRT based TVs, and show this type of fault. If it is found shorted [collector to emitter], the LOT should also be checkd for winding short [internal]. Normally; LOT cannot be checked with normal measuring instruments. If LOT has internal winding short, the horizontal output transistor will get overheated and finally shorted.
Replace the horizontal output transistor first, and check whether it heats up ubnormally within seconds after switch ON the Tv. If it heats up so, make sure that the LOT is defective, and it should also be replaced. OK.
Feb 28, 2012 | Mitsubishi CS-32307 32" TV
HOT transistor TT 2222burn after second replace. TV Samsung Model CS-21Z45MJ
Hello
Before replacing an other one, replace the freewheeling capacitor, the capcitor fitted between the collector of the 2222 and earth; usually of a value of 3500pf 2000VDC, some times this value may differ from set to set. If this capacitor has opened of developed in value, the result will be the failure of the horizontal output transistor, at switch ON itself. The second reason is the short in horizontal yoke windings. Even one winding get shorted, it will cause to a heavy load flyback transormer which in turn to 2222 failure. The last reason for this fault is defective Line Output Transformer itsef. Check these three.
Before proceeding, desolder out the horizontal output transistor 2222 fro circuit, and measure the frequency at the collector point of horizontal driver transistor. It should be around 15625HZ [may differ a little], with no signal. If this frequency is found higher than normal, The main IC jungle should be suspected.
Anyway, go forward after checking this frequency. OK.
Jun 10, 2011 | Televison & Video
What causes the horizontal transistor to short? flybak ok, supply line ok. my tv is a samsung with a model #: ct-21k30mh.
Hello
You just replace the capacitor fitted very near to the horizontal output transistor,[freewheeling capacitor], there may be one or two of them, whcih comes to a value of 3900pf to 6700pf 2000V or so. It is connected to the negative rail and the collector of the horizontal output transitor. If it gets opened, or its value gets reduced, this fault will occur. If so the transistor you replace will get shorted as you swich on the power to TV.
The second one is deflection yoke short. If so the transistor said above will overheat within seconds. Even a single winding inside the horizontal deflection yoke shors, it puts a tremendous load to flyback transformer, which in turn effects the transistor.
After replacing the above said capacitor, you do one thing to make sure about whether there is a short inside the yoke or not. It cannot be measured by normal methods. Fore that, unplug the base card from picture tube and place it somewhere near without getting any of its contacts to other parts inside your TV. This time only the EHT chord will be connected to picture tube. Unplug the horizontal yoke connection from main board. Switch on the tv, and wait for some time, say at about 10 seconds, and check whether the transistor gets overheated or not If it does overheats now also, the winding or EHT retifier diodes inside your flyback transformer has some trouble, and it should be replaced with same type and number. If it does not overheats now, the deflection yoke's winding have some short in it. Ok.
NB: Never connect the TV with base card is in postion while deflection yoke connection is isolated. keep it unpluged.
Oct 27, 2010 | Samsung Ultra SlimFit 20" Digital TV
SONY KP-61V90 tv will not power on, red light in front,
Its 2 times blink error code that shows +B volt supply (+135 volts) is shorted, most probably horizontal output transistor is shorted, replace it.
If you are good in soldering parts in circuit board then take out horizontal transistor, check it, found shorted then replace it with same number.
Horizontal output Transistor Q502 number is 2SD2578 and available in Part Store for $10
Let me know for further query, if any.
Thanks.
Nov 18, 2009 | Sony Televison & Video
Tv problem
The F27442 uses the CTC203 series chassis and that symptom is very common. If the horizontal output is shorted you MUST resolder the coil in series with the base of that transistor and the pins of the small horizontal drive transformer. When they have been properly resoldered you can put in a new original horizontal output transistor. If the output transistor shorts out again then your flyback (high voltage) transformer is shorted and needs to be replaced.
Aug 08, 2007 | RCA F27442 27" TV
RCA F27669 27"
The F27669 uses the CTC203 series chassis. The most common cause of that symptom is a shorted horizontal output transistor, caused by a cracked solder joint on a small coil connected to that transistor's base. When this happens, the main B+ supply is shorted to ground so the power supply squeels. Every once in a while I also see the horizontal output transistor shorted due to a shorted flyback (high voltage) transformer. A good tech will replace the horizontal output transistor, resolder the coil and drive transformer, test the flyback (replacing it if necessary) and your set will be back to perfect.
Aug 08, 2007 | RCA 27V570T 27" TV
18 Mo old Samsung CXM2785TP made high pitched noise and lost power
The high pitch sound could have been the flyback transformer. check the horzontal output transsitor if is gone the tranfomer is sure to be gone . Tranformers are varying in price are the transistors can also vary you could be looking at around 150.00 plus labour.
Apr 17, 2007 | Samsung CXM2785TP 27 in. TV/VCR/DVD Combo
No power
Check the FBT and the Horizontal Output Transistor also.
Sep 18, 2006 | Panasonic TX-15AT1 15" TV
Samsung DynaFlat CXM2785TP 27 in. TV/VCR/DVD Combo Logo
291 people viewed this question
Jerry Greenberg
Jerry Greenberg
