It work connect too xbox live it's saying go to mtu settings and see if I can change it so I can get connected I need 1364 mtu or more to get connected to xbox live how do I do that
This mainly depends on your internet modem, I use linksys when I play xbox live. Also I use wireless adapter, sometimes an ethernet cable as well to plug straight from my xbox to my modem. Make sure your modem is connected to the internet, and that if your xbox has a signal, or properly connected to it.
Hope this helps a little. Good Luck!
SOURCE: xbox live is saying that i need 1364 mtu setting
that 1392 is a firewire, your xbox is in need a connection going to your firewire... install the firewire 1364 driver...
SOURCE: how to change mtu settings to get x box live?
heres a good site that discusses adjusting the MTU(maximum transmission unit)
Usually in most cases MTU of 1500will work just fine, I suggest using DrTCP a free program available online to help you tweak your settings
http://help.expedient.com/broadband/mtu.shtml
Dont forget to rate the advice.
http://www.aa1consulting.com
SOURCE: how do i change my 2wire routers mtu settings cant
you need to call your internet service provider because that is the firewall of the 2wire.
Once you have all the wireless
settings of the router, you are ready to connect the play station or the
x-box to the wireless network.
X-BOX
On the x-box you will need to
connect to the wireless network now.
Open the
main Interface of the X-Box.
1. In the Xbox Dashboard, go to My Xbox
and open System Settings.
2. Select Network Settings, Configure
Network.
3.
On
the Basic Settings tab, select your wireless settings.
4. Select
the name (SSID) of your wireless network. If your router isn't
broadcasting your network's name, select Specify Unlisted Network and
enter the name.
5.
If
your network has wireless security, enter your WEP or WPA key.
6. Try to
connect to Xbox LIVE again.
Trouble connecting to the
internet on X-box ,Play station or WII ?
You can
try to reduce the MTU settings on the router. if the MTU on the router
is set to 1500 then change the MTU to 1365. Also you will need to open
the ports on the router.
For
X-box port numbers are - 53, 80-88, 3074 .
