Question about Canon FAXPHONE L80 Laser
Canon Fax phone L80
Our machine is unable to receive faxes. The screen reads "FaxTel". We have a dedicated line to the fax. The paper is full and there are no jams and nothing appears in memory. I have disconnected all the lines and power cord and reconnected with no success. What do you suggest?
Mary
  • 59 Answers
Make sure the fax is on a deicated line and the telephone line is plugged in the "L" jack not the T or the handset symbol jack.
Posted on Feb 20, 2008
Is there possibilyti to have telephone line and fax line at the same time. In my model Canon L290 on display write FaxOnly. How to change?
Posted on Feb 18, 2008
    Scholar:
  • 78 Answers
If it is a dedicated fax line it is probabaly best set to fax only mode. Fewer rings (No more than two) FaxTel mode will ring for longer to allow you to pick it up if its a phone call.
Check if the machine has dial tone by onhook button or handset to check. If you have none try testing with another phone to rule out the machine.
Try a manual reception. Pick up the phone when it rings and press the start button.
Posted on Feb 01, 2008
Cannot receive faxes
Make sure that the telephone line from the wall is plugged into "LINE" and not "PHONE" on the fax machine. You might also call the fax number from a different phone to see if you can hear the fax tones.
Aug 20, 2009 | Canon FAXPHONE L80 Laser
Inoperative fax and telephone line
try connecting line 2 to a simple phone and chk for dial tone.
Sep 22, 2008 | Canon FAXPHONE L80 Laser
Send and receive speed
That's not even a coherent response. Even analog phones go from an analog signal from your home, to a digital signal at the carrier, to an analog signal at the recipients end. It all goes digital at some point.
Fax machines work fine with a digital phone. The baud rate may need to be lowered in some cases, but working for a cable company, I've personally worked with hundreds of fax machines that work just fine.
Try lowering the baud rate and/or using a DSL filter if you are having problems. If you are unable to find the baud rate or speed setting on your fax, you may want to contact Canon to find out how.
Dec 09, 2008 | Canon FAXPHONE L80 Laser
Can not send a fax
Plug a regular phone into the wall jack to verify a dial tone. Make sure the phone line is plugged into the LINE port of the fax.
Oct 02, 2008 | Canon FAXPHONE L80 Laser
Canon image class MF4150 distinctive ring
How to Set the Receive Mode (MF4140/MF4150)
1. Press [Additional Functions]. 2. Use [Left cursor] or [Right cursor] to select [FAX SETTINGS], then press [OK]. 3. Use [Left cursor] or [Right cursor] to select [RX SETTINGS], then press [OK]. 4. Use [Left cursor] or [Right cursor] to select [RX MODE], then press [OK]. 5. Use [Left cursor] or [Right cursor] to select the receive mode, then press [OK]. [FaxOnly]: Answers all calls as faxes and disconnects voice calls. [AnsMode]: Receives faxes automatically and records voice messages. [NET SWITCH]: Distinguishes between fax and voice calls. [FaxTel]: Switches between fax and voice calls automatically. [MANUAL]: Does not answer any calls. You have to manually receive faxes. NOTE: a. For [FaxTel] or [MANUAL], make sure the optional handset or an external telephone is connected to the machine. b. For [AnsMode], make sure an answering machine is connected to the machine. c. The [NET SWITCH] mode is available for certain countries only and requires subscription to a network switch service. 6. Press [Stop/Reset] to return to the standby mode.
Aug 12, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Canon Faxphone L80 - Alan Silva
To send a fax you do not need to enter anything into your fax. You have to make sure that you connect the telephone line to it's desgnated connector. You dial a number to send as if you are calling form a normal phone. If you ever get a ringing tone press start. You can enter any data trough the data registration after you make sure your fax is functioning properly.
Jun 24, 2008 | Canon FAXPHONE L80 Laser
Can't receive faxes
Something is causing the fax machine to "trip" to busy. There is some type of short occuring either in the fax machine or the physical phone line itself. Unplug the fax, plug in a regular single line telephone. Call the fax number from another telephone. If the phone rings and you can talk to the other party, the problem is in your fax machine. If the call still is busy, the problem is in your wiring, either in your office or the phone company network.
Feb 01, 2008 | Canon FAXPHONE L80 Laser
Can't receive fax but can send
Call your cell phone from the fax machine and check the caller ID to make sure that it is the correct number for your fax machine. Next, call the fax machine from you cell phone, and make sure the fax machine rings. Problems like these are almost always a phone line issue, not the machine.
Don't forget to rate your solutions please.
Dec 03, 2007 | Sharp UX P200 Plain Paper Thermal transfer...
Fax line stays busy continously...
Still a problem? Can you be more specific?
Jan 29, 2007 | Canon FAXPHONE L80 Laser
Canon FAXPHONE L80 Laser Logo
371 people viewed this question
old marine
old marine
