Kenwood Dual Cassette deck KX-97CW runs fast
When cassette is inserted in either side, deck runs fast (about fast dub speed) but no audio is heard. Can't make it run normal speed. Won't play or record. FF and REW run at their normal really fast speed.
No obvious damage to unit. I have owned it since new.
    Scholar:
  • 79 Answers
Sometimes this is due to the tape not being pinched between the capstan and the rubber roller.
Make sure there is no slack in the tape when you put it in the deck. See if you can observe the tape going down over the capstan on the correct side.
If this isn't the problem, then the mechanism that engages the capstan roller may not to be working. In most cases, the rubber roller is mounted on the same mechanism that moves the record-play head against the tape. If this mechanism isn't moving, that would cause the problems you describe.
Posted on Mar 15, 2008
How do you dub cassette to cassette
Hi
If you have a dual cassette deck, then one deck will only play cassettes,whilst the other will have a record facility as well.
Basically you need to place the original cassette in the play only deck and the target cassette in the record/play deck.
Start the playback in the play only deck and immediately press the record and play buttons together on the record deck. Some decks have high speed dubbing but this varies so much that you will need to consult your manual for this.
Cheers
Apr 09, 2015 | Audio Players & Recorders
How do I dub using the onyx double cassette deck?
There should be a button or switch that will select the recording deck and the dubbing deck. You put a blank tape into the recording deck and the pre-recorded one into the play deck. Pressing the record button on the dubbing deck, on some models should start the play deck running. If not press play on that deck.
Jun 05, 2014 | Sony TC WE435 Stereo Dual Cassette Deck...
Kenwood KX-79 CW dual cassette hook up?
Just connect the deck via tape 1 the out of the deck going to the in of the amp. While the out of the amp goes to the in of the deck.
The tape deck itself will automatically choose the player that plays the cassette. One will play the other will be on pause (if you press both play buttons) till the tape stops then the other will play. For recording from tape to tape one deck will be the copy and the other the copier. There should be a dubbing button which you press to record tape to tape. Some models have a high speed dub also. For recording from the amp unless both decks have record buttons you will only be able to record with one deck. Make certain the dub button is not set.
Dec 25, 2013 | Kenwood Audio Players & Recorders
Looking for schematic for Kenwood KX-55 stereo cassette tape deck
These dual cassette deck are rarely worth he effort to put repair time into. I checked Hi Fi Engine and they did not have anything. Is it worth a $100 repair bill? if not then look for a good solid single deck.
Mar 31, 2013 | Audio Players & Recorders
I have a kx-w4050 dual kenwood tape deck niether side will play hear click and counter moves one then another click. Is there a way to fix this?
Yes, the belts need to be check and idlers or whatever drive mechanism that is used in that system. Dual deck units are among the most unreliable units there are and a reason I tell people for the last 30 years not to buy those things. Almost most of the time they are not worth fixing due to their poor performance at the end. These are facts not just opinion.
Jan 14, 2013 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Kenwood KX-W6080 dual stereo cassette tape deck
I have the same unit which had the same problem. It has to do with dirty contacts on each tape mechanism.
Remove the main cover and look down on each tape mechanism. You will see 4 contacts on each unit. These come in contact with the tape. Remove each unit by removing 4 holding screws.
You will now be able to spray some contact cleaner into the front of the plastic contact cover. I removed the covers on both of the second from the right contacts so that I could clean them with an abrasive. These are the main ones.
Put everything back the way it was and the tape deck should work great.
Mar 24, 2008 | Kenwood Audio Players & Recorders
Repair of Sansui cassette deck D-1000W and Compu Receiver Z-5000X in India.
This is a fairly old and obsolete model and its components are now not manufactured. If you are lucky, some stockists may have replacement part, but normally at very high price.
Nov 06, 2007 | Audio Players & Recorders
214 people viewed this question
 Grubhead
Grubhead
