Question about Honeywell Programmable Thermostat Heater
RTH230B Thermostat I've been told that after I installed the thermostat that it did something to the transformer. Where is that located and how to fix it?
  • 625 Answers
The transformer may be installed remotely to the furnace or may be a part of the honeywell burner relay. if you connected the thing between the transformer secondary common and hot it will surely blow the transformer.
Posted on Feb 03, 2008
New instruction manual for RTH230B
Do you mean the Honeywell RTH230B programmable thermostat? Most of the Honeywell thermostat manuals are available here: http://yourhome.honeywell.com/en/faqs/thermostat . Scroll through the pages to find the RTH230B or use the search feature. The search engine found the installation and user guide in three different languages, see https://yourhome.honeywell.com/en/supportsearch#q=Rth230b . The direct link to the manual in English is https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-1800.pdf .
I hope this helps.
Dec 07, 2017 | Heating & Cooling
My thermostat keeps blowing itself out
Electrical problem getting to hot ie burning out stat check transforme rvolts ?
Jan 24, 2013 | Heating & Cooling
Honeywell RTH230B cooling problems...
I printed out the instructions for your thermostat. It looks like you should have the following.
There should be jumper wire between Rh & Rc
Red wire to Rh or Rc whichever is easier since there is a jumper. This is the hot wire and all the thermostat does is connect to route it to the components needed for heating or cooling.
Blue wire, tape it up and don't use it. There is no spot on this thermostat for it. It is only used on thermostats that are powered by the transformer.
White wire to W. Powers the heat relay
Yellow wire to Y. Powers the cooling contactor
Green wire to G. Powers the indoor fan relay
There is a black jumper on the back of the face plate. Look at section 2.4 Setting J2 Jumper in the installation instructions. Make sure you have it in the right position for what you have. If you don't have them just google them.
Hope this helps.
May 24, 2010 | Honeywell Electronic Programmable...
I replaced the battery to honeywell RTH230B. Heat won't turn on.
I followed a comment from a previous source and reversed the polarity of the batteries. I then flipped them back to the correct position and the flashing battery indicator went away and the thermostat functions correctly.
Feb 04, 2010 | Honeywell Programmable Thermostat Heater
Honeywell RTH230B
This my situation exactly.  Changing from a 6 wire manual round Honeywell thermostat to a 5 wire Honeywell programable.  Is there a way to maintain all functions?
Sep 21, 2008 | Honeywell Programmable Thermostat Heater
Model RTH230B uses a lot of batteries
THIS TYPE has been deemed defective! changeout to a different type.
Sep 04, 2008 | Honeywell Programmable Thermostat Heater
Honeywell rth230b won't shut off heat
Sounds like a relay sticking. Possibly in the thermostat or possibly the furnace relay at the furnace. The next time it happens, unplug the thermostat from the wall. If the furnace still runs then it's the furnace relay.
Hope that helps...
Geno
Mar 07, 2008 | Honeywell Programmable Thermostat Heater
Honeywell RTH230B
Normally, you should have 5 color wires: W-White, Y-Yellow, G-Green, R-Red and C-Blue.
The Blue wire is a common from the transformer on older systems, which is probably hooked to RC terminal.
Try this: Remove the blue wire and jump the RC to RH with the red wire and you will be fine. Blue wire should not be needed with the new thermostat.
This should also be stated in the instruction manual.
Hope this helps.
Feb 03, 2008 | Honeywell Programmable Thermostat Heater
I can't program my thermstat
go to www.honeywell.com. There you will find a search tab. Type in the exact model number of your thermostat. You will be able to download the installation/owners manual.
Nov 29, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
163 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
