Question about Lexmark X1150 All-In-One InkJet Printer
I have an X1150 and the scanner is not working properly
It was working fine. All of a sudden it started stretching the image being scanned. At first it would work okay for a while and then go wrong again. There is an unpleasant loud noise and the scanner bar swings out diagonally.
Any ideas?
  • bjp28uk Feb 10, 2008
    Though it might be mechanibal. Thanks
    Genius:
  • 3,587 Answers
Yeppers..the scanner mechanism is either corrupted(broken) or there's something hanging it up inside(paper jam, perhaps). sounds like the mechanicals are really unhappy here
Posted on Feb 06, 2008
Honeywell 2020-5 suddenly stopped scanning. The lights are on the charger base, but the scanner seems dead.
I guess there is a problem with the base station. Let me tell my story:
I got a 4820 scanner with 2020 base. All worked fine till I experimented with scanning images. After a few images (which I cannot retrieve/receive properly due to lack of software) the scanner seems dead. From time to time a short buzz sounds when triggered, but no light or else.
So I bought another 4820, a slightly different model. Seems to work fine but has to be paired with the base to get the data. Now after pairing this scanner shows the same issues as my first and refuses to scan.
I installed QiuckView and HSM-USB-Serial-Driver on a virtual machine at my MAC to flash firmware to base and scanners. But the base device does not show up in the program (althought it is shown in the USB device table). Maybe I can try on a native WindowsPC ...
Oct 21, 2013 | Honeywell 2020-5B Cordless Bar Code...
When I scan 35mm negatives, the pixel aspect ratio is incorrect: the resulting images are stretched out by twice their width without any change in height. I can fix this after importing the image into...
I have the same problem with mine; medium format scans are fine but 35mm scans are stretched. The same happens with both the Minolta software and with Vuescan. Has anyone manage to fix this?
Dec 26, 2009 | Konica Minolta Dimage Scan Multi PRO Film...
CanoScan LiDE 20 started stretching image at the beginning of the scan, continuing just fine afterwards. Bottom part of the image (in my case a letter-size page) will not fit, about 1/4 of an inch would be...
Hi pallada,
This might be a case where we address the symptoms rather than the problem.
Instead of positioning the paper to be copied at the normal position, drop it down to the 2" mark. Then on the preview screen, adjust the area to be scanned down accordingly.
This should allow a full letter size scan with no loss, truncation or stretch.
Best regards,
Mike
Jul 18, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
Hp 5400c scans blue images
sounds like a faulty scanning head to me......
when images are scanned they are normally imaged in 3 colours red blue and green these are then combined to give a full colour scan. sounds like you are only getting the blue pass.
not alot that can be done here, if it is in warranty (check with manufacturer for duration of warranty as sometimes this can be more than a year) they should repair or replace this for you
Apr 23, 2009 | HP Scanjet 5400c Flatbed Scanner
Red images when I scan...
That means, your scanner lens are not reflecting images properly so
you need to clean ADF kits and Glasses of Lens.
i highly recommend not to mess up with your scanner if you are not aware of those all parts and if you are just open up scanner glass cover and clean those all ADF kits otherwise better getting help of a printer Tech.
Good luck
and rate all answers.
Mar 25, 2009 | Compaq S4 100 Flatbed Scanner
Basic instructions for scaning on a lexmark x1150
Using your MSoffice Word (2003/7) you can simply create a New document and then go to Insert / Picture / From scanner or Camera
select TWAIN scanner and satrt scanning from PC (have your document in Lexmark scanner Tray in).
Accept or modify settings.
Resize or change properties of adquired picture
save the Word Document.
You can also use your Picture processing program (Paint or other)
Open Paint (or Other) Go to file /adquire/ select your scanning device Scan.
Dec 19, 2008 | Lexmark X1150 All-In-One InkJet Printer
Scanner
that's a resolution settings issue on the scanner software. Open up the scan manager, and set the resolution at fine or less, not superfine(which works for color photos, etc.)
Feb 05, 2008 | Lexmark X1150 All-In-One InkJet Printer
Scanner not working
Please open HP director from Start - All programs - HP .
Click Scan document to scan.
You can scan by following steps :
For Windows XP:
To isolate the issue I suggest you to try scanning from the Windows Image acquisition(WIA) wizard on the computer.
Follow the below steps to Scan using WIA
1.Verify that the all-in-one product power is turned on and the printer cable is properly connected.
2.Click Start then Click All Programs then Click Accessories then Click Scanner and Camera Wizard.
3.Follow the Scanner and Camera Wizard instructions to scan images to the computer.
Waiting for you reply.
Thanks
Dec 22, 2007 | HP PSC 2355 All-In-One InkJet Printer
Scanner started scanning color photographs in black and white
The problem is simple.Someone or somehow the "TYPE OF ORIGINAL" option on ur SCANGEAR CS window.Set it back to "MAGAZINE" or "PHOTO" and it should scan in color.
Oct 07, 2007 | Canon CanoScan LiDE 70 Flatbed Scanner
Lexmark X1150 All-In-One InkJet Printer Logo
50 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
