Question about Dell Inspiron 2200 Notebook
Lost disc in laptop
Help, i put a disc in draw of laptop but must not have put it in properly the disc has gone inside the laptop somewhere can you help please
    Problem Solver:
  • 9 Answers
Theres only three things to do
1 theres a small pinhole to manually open the draw just stick in a toothpick and the draw should open see if you can see the disk and shake it out(if it fell in so easy.
2 get a screw driver and start unscrewing the bottom panel(sometimes theres screws under the rubber pads on the bottom when you think their out just slowly wiggle if theres more youll feel it carefully of cousre after taking out battery hard drive and ram and if you need to unscrew any circuit boards lift them slightly just enough to get the disk to make sure no wires are pull out cos there will be wires that connect everything to each other, its easier than it sounds if you get cold fett stop and put it back together. also by doing this you void warranty but if thats expired then thats what id do rather than option 3 Pay a store to do the same thing, although i would expect it to cost $20-$45 and i wouldnt pay more than twenty but you might get rip offs
These are your choices
I hope you feel well advised
Clapster
Let me know how you go
Posted on Feb 01, 2008
The DVD Drive on my philips freevents 12NB5800 isn't working. The problem is that the draw opens but the laptop isn't recognising the disc. I had tried going onto my computer and double clicking on the dvd...
Either your CD/DVD drive is dirty & needs to be cleaned, or the drive has gone bad & needs to be replaced.
First, try to take the drive off the laptop. Open the drive & blow compressed air into it (from a can of compressed air) to clean it. You could also clean the lens (the small round glassy object inside the drive) using lens cleaning tissues & lens cleaning fluid.
If this did not fix the problem, you will need to replace the CD/DVD drive with a working one, or use an external CD/DVD drive
Aug 29, 2010 | Computers & Internet
After a complete system restore, i lost the authorisation codes for my preloaded MS Office Ultimate 2007. MS Office, HP and the reseller are all saying i need to buy new software - isn't there a way to...
The serial # codes should be on a holographic sticker on the base of the unit, somewhere on the laptop, inside the instruction manuals, or on the actual install disc envelopes.
Mar 22, 2010 | HP Pavilion dv5-1000us Notebook PC
Delco battery going dead X 3
I would check the water level in the battery, also there could be a ground problem somewhere.
Feb 04, 2010 | 1999 Buick Century
Lost docs to be printed?
if u had saved the documents u will find it in my documents
thats located ... start> and u will see my documents
Feb 07, 2009 | HP PSC 2355 All-In-One InkJet Printer
DVD disappeared in DVD Player after viewing movie
Get the dummy cd disc, put a blue tac on it. Insert it. Then after few seconds, eject it. Your dvd disc should stick with it when they came out. It worked for me and hope it will work for you.
Jan 31, 2009 | Kenwood DV-505 Multi-disc DVD Player
Cannon power shot sd800IS
download from canon's web site or just usb camera to computer and computer will auto recoginize camera turn on and put in playbck mode
May 16, 2008 | Canon PowerShot SD800 IS / IXUS 850 IS...
Help me!!!!
sounds like your laser has gone out of a limemunt and yes it can be fixed
Feb 21, 2008 | Sony PlayStation 2 (PS2) Console
DRIVE UNIT WONT OPEN OR EJECT
You can eject the cd by pushing a paper clip into the small hole in the draw.
Sep 26, 2007 | Acer Aspire 5100 Notebook
Broken ps2 slimline , sounds like the disc is catching sumthin, any help? could it be the draw, still isnt working, help??
ok the problem i had was the disc would not read and it sounded like struggling to read. 1/ if under warranty-use it 2/if not you need a small phillips screwdriver and a flathead screwdriver. Take the back soft pads off and unscrew x2.then use the flathead and unclip hard plastic (not rubber)front ones x3 and x1 back. Carefuly remove the top avoid touching the laser lens at all cost(this will cost you) Now to the problem The lens slides back and forth on the steel rods, i found that mine was sticking in a spot i put some crc on a tissue and cleaned the steel rods. Too test while still open put the leads in and (power last) and turn on .In order to fool the machine to think it is shut there are 2 trigger point to push down 1 next too the on button and the next is white and in mid-back when done together the disc will start to spin.(hopefully that was your problem as mine went back too whisper quiet and all my discs worked again) and just go in reverse to put back together Good luck and enjoy the experience
Apr 02, 2007 | Sony PlayStation 2 Slimline Console
Disc loading problem
disk draw timing is probably out ( gear or mechanism jumped out of time
Jan 23, 2007 | Cyberhome DVR 1600 DVD Recorder
Dell Inspiron 2200 Notebook Logo
241 people viewed this question
Alun Cox
