Sony tv i have a sony kv-27hsr10 the prob is when i tturn it on i have a black screen then the black screen moves form the bottom to the top but it takes about 2 min to do it my e mail is mrpf8@hotmail.com thanks Larry
  • 48 Answers
It's hard to say, based on your description, if your symptom is caused by the power supply or vertical circuit. Do you mean there is one thick black area that moves slowly up the screen ? If so, do you still have picture and sound while this is going on ?
Posted on Feb 01, 2008
SONY KV-32xbr50 intermittent
The fault is with some loose contacts. Check and rectify this. There is no more components to replace. Look for any loose solder terminals. That is all. But it will be a difficult task to reach to the exact point of fault.
Oct 01, 2012 | Sony KV-32XBR450 32" TV
3" black bars top and bottom of screen. Can't
either you have the video setting of the television set to wide screen or you are purchasing "WIDE SCREEN" format dvds instead of "FULL SCREEN" format dvds
Oct 12, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Our TV has been perfect for many years. We now suddenly have the picture compress, if you will, to the bottom 2/3's of the television screen, and it makes an angle like a triangle going toward the bottom....
This fault sounds like failure of the LINE OUTPUT TRANSFORMER.
It can be fixed, but may cost you around $120, possibly more if you have to call out an engineer.
Best NOT to use the TV as it is, because it could possibly damage the system.
If you do use it, this line will become permanent and if you get the TV fixed later, there will always be a burnt section of the screen where the line was - so I suggest you either pay to get it fixed right away, or consider buying a replacement.
Hope this helps!
Mar 08, 2011 | Sony KV-32S42 32" TV
How do you tturn down your blue projector on a sony kv-48v80
Foucs and screen control block is located behind front bottom panel remove it and thats where it is.
Aug 20, 2010 | Sony KP-48V80 48" Rear Projection...
Sony KV-27FS13 27" TV Horizontal lines in the form of brigter to darker values of the picture, half screen size, moving from bottom to top of screen. I've been able to give the TV a lite tap on the top...
this sounds like 60hz or 120hz a/c ripple distortion. if taping tv corrects temporarily, ther must be poor solder on main a/c ripple filter. very large usually blue capacitor near power cord input on pcb. do not short positve and negative legs together as you could be shocked(even after tv is unplugged) and also cause more damage to tv. these filters can store electrical charges for days, even if unplugged the whole time. careful! mch
Mar 08, 2009 | Sony KV-27FS13 27" TV
Sony KV-32S66 Picture Rolling Up/Black Horizontal Lines
the problem there is a loose connection on the board,you said that you smacked the right side of the tv and it goes normal.there are parts that should be resolder on the board in order to back into normal operation.
Oct 22, 2008 | Sony KV-32S66 32" TV
TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Jul 19, 2008 | Sony KV-36XBR450 36" TV
Sony KV-32FV15 TY
I have had my Sony KV-32FV15 for about 2 years now and nothing has ever gone wrong(even going through several moves.) I recently moved again and when I plugged in the TV, you can hear the sound perfectly but the screen just stays black. You can not even hear the squeal that the TV makes when comming on. Is there anything that I should initially look at to troubleshoot. I cannot afford at this time the $250 fee to repair my TV. I look forward to your input and hopefully I can get this TV working again.
Oct 24, 2007 | Sony KV-32FV15 32" TV
My tv rolls from bottom to the top
It's a bad cable connection. Move the cable wire and see if there is a difference. The bad connection can also be at the cable box outside.
Jun 29, 2007 | Sony FD Trinitron KV-28FQ75 28" TV
1/3rd of Bottom portion of Screen is blacked out
sound like you have cloced caption text on, this is not the same as the normal cloced caption, look on your rempte for caption or "cc". if you don't see it you will find it in your menu & turn it off. have a good day.
Jan 02, 2007 | Sony FD Trinitron WEGA KV-32FV300 32" TV
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
