Question about Maytag PYE2300AY Electric Dryer
Maytag Perfoma model PYE2300AYW
Push start button and drum doesn't turn. I am hearing humming sound, as if the motor wants to start, but does not. I lifted the top and gave the drum a half turn and it worked fine. I pulled the drum out, belt is fine, rollers are fine, pulley is fine, heating element fine, blower fine also.....I have no clue.
Again today, hit start and a humming noise but no drum turn. Lift the top of the dryer off, give it a turn and it came on no problem. Any ideas?
cpruitt
deion528@hotmail.com
  • 2 more comments
  • diggidydeion Jan 31, 2008
    Ummm, what is a bad start winding in motor?
  • Anonymous Nov 24, 2008
    DRUM WONT TURN HOW DO I OPEN
  • Anonymous Mar 12, 2014
    timer set then push start button and it hums like it's trying to start then stop humming without starting .wait a few minutes and it does a repeat over again.trying to take it apart to see drum belt can't figure out how to get the top off.
  • Anonymous Mar 23, 2014
    works on and off. sounds like it is working really hard to start up
  • 770 Answers
Bad start winding in motor
Posted on Jan 31, 2008
  • Gary Davd
    Gary Davd Feb 01, 2008
    Yes it is in the motor some motors have an external Capacitor to help it start this could bee bad if yours does nbot then the motor will hav eto be replaced if the re is no binding on the drum you can also removed the belt and start it to see if it goes there are no oil port on this type of motor they are sealled bearings
When I press the start button, it hums but won't turn on, I hear clicking behind the cycle setting dial?
f you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Jan 17, 2011 | Maytag Dryers
Dryer makes loud humming noise but drum doesn't turn when I push start.
Check to see if the drum will turn by hand. If so, leave the door open but push the light switch button down and start the unit. Once you hear the humming sound, manually turn the drum with your hand to start. If the drum turns normally, you have a bad motor and needs to be replaced. If the drum does not turn, something is jamming the motor and needs to be disassembled and inspected.
Good luck
Oct 03, 2010 | LG DLE2514 Electric Dryer
I have a Maytag PYE2300AYW. Push button but nothing happens. Had breakers to house checked and all good.
Dryer suddenly stop working when pushing start button (knob will make a humming or ticking kind of noise but won't turn on. I cleaned and check the outside exhaust and lint screen passage. Nothing is helping. help
Jan 08, 2010 | Maytag PYE2300AY Electric Dryer
Maytag pye2300ayw hums when you push in to start, sometimes will get started but not always
Sounds like the motor is weak and needs replaced. Or something is binding the drum and not letting it turn freely.
Jan 06, 2010 | Maytag PYE2300AY Electric Dryer
When we push the on button, you can hear a hum,
Sounds like the belt that turns the drum has broken. the hum sound is the motor turning. Does it still get hot in the drum? If so then you need a replacement belt ($15-$25).You can open the rear or the dryer to confirm the belt is broken. Be sure to unplug from the wall outlet to avoid electrical shock.
Aug 18, 2009 | Dryers
Maytage MDE3080DAYW
Hi, it sounds like you have a bad motor. You can try and open the door, hold the door button while having someone push the start button. Try turning the drum with your hand while these buttons are pushed and see if the dryer starts. It sounds like the start winding has gone bad.
If the drum will not turn, remove the front panel of the dryer and see if something has gotten into the blower wheel to stop it.
I hope this helps you. Please let me knwo if I can assist you further.
Vic
Jun 13, 2009 | Maytag MDE308DAYW Electric Dryer
When start button is pushed, hums but does not run. Drum does not turn. Belt is okay
It sounds like it is the motor or a stuck/obstructed blower wheel. You can start by opening the door, push the door switch in, hit the start button & see if you can turn the drum clockwise by hand. This might get it going. if the drum does not move by hand then the problem is probably within the blower. post your findings for a follow up
May 01, 2009 | Dryers
When I push the start button, the unit just buzzes or hums.
You have a broken drum belt. The hum you hear is the motor spinning at high speed.
Apr 21, 2009 | Maytag MDG2706A Gas Dryer
Maytag PYE2300AY Electric Dryer Logo
613 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
