Question about Nikon 17-55mm f/2.8G ED-IF AF-S DX Zoom Lens
Nikon 17-55mm I hope you can help me on that one! I just bought the Nikon 17-55mm on ebay, and it seems that when I use it with my D2H and SB800, the SB800 stays on 40mm mark all the time, no metter what focal length I zoom into. Also, when looking on exif file, it just says that I shoot the photo on 38mm, no metter if I shot on 17mm or 35mm etc.... How can this be repaired, and how much does it cost? Should I return this lense? Kindest Regards Filip O.
  • Filip_O Feb 01, 2008
    Thanks for the advice, still, it seems not to help.
    How much will a change of the circuity cost?
Change to Canon equipment
Posted on Jul 18, 2008
  • 667 Answers
You might try cleaning the lens contacts lightly with an eraser. Make sure they are all springy to the touch. If this doesn't solve the problem, then new circuitry may be required.
Posted on Feb 01, 2008
2 Suggested Answers
  • 33 Answers
SOURCE: Distance problems
I don't think it is possible to diagnose this problem, so this is just a suggestion.  After checking out your website, I'm pretty sure that you know how to work your equipment so I think the usual dribble about making sure the flash isn't on manual, etc.  Well, that wasn't the suggestion, this is.  Take a cotton swab and clean the contacts on the lens with isopropyl alcohol. If the cause of your problem is a bad contact, that should take care of it.  If it doesn't work, I'd send the lens back straight away - because if this doesn't work, then who knows what is going to go wrong next.
Good luck
Posted on Feb 02, 2008
Sb800 firing without pressing shutter release
sounds like a short in one of the circuit boards, most likely one or seveal of the ribbons and boards will need to be replaced to correct the problem. Send in for repair expect to pay up to $200 for a Nikon factory overhaul
Feb 21, 2010 | Nikon Speedlight SB-800 TTL Flash
I would like a dvd for the using of the Nikon SB800 flash
Blue Crane Digital DVD: Understanding the Nikon Flash SB800 and SB600
  • Mfr#
  • BC202
  • B&H# BLDVDNFSB800
THIS SHOULD HELP YOU
BERRIE SMITH CAMERA REPAIR
770-312-0719
bbmw@bellsouth.net
Feb 14, 2009 | Nikon Speedlight SB-800 TTL Flash
How can i make the picture number continuous with my nikon D2H?
If you go into the menu settings you can choose wheather to let it run on and reset at 9999 or start again or name the new file.
Jan 27, 2009 | Nikon D2H Set Digital Camera
Nikon D3 and SB800 flash problem
The Sb800 and the Sb900 is compatible . Can you tell me more of what the problem is .
There is no frim ware for the flash . The NIKON SB 900 FLASH SHOE IS THICKER AND MAKES BETTER CONTACT . THE NIKON SB800 SHOE IS LOOSER AND NEEDS TO BE ADJUSTED
Nov 23, 2008 | Nikon Speedlight SB-800 TTL Flash
No images on Nikon D2H back monitor
I think this can be turned on and off in the settings menu
Nov 22, 2008 | Nikon D2H Set Digital Camera
NIKON D2H ERR FAULT
I had a D2H with a similar error. The camera started giving an 'ERR' message almost from new but from reading various posts from other users I assumed it was a 'known' idiosyncrasy of the D2H, the camera would create an underexposed first shot after turning on. A colleague has the same problem on his D2H, and there are numerous references to the same problem on the web. Your post points to a similar shutter issue. My shutter failed completely at around 65,000 actuations, well short of the advertised '150,000'. In addition, the horizontal Main Command Dial had also failed a short time before, and it had cost me £135GBP to have that repaired.
The problem is down to the shutter and unfortunately replacing the shutter costs £349GBP in the UK, quoted to me by the Nikon UK Service Department, in Kingston, in March 09.
As for Nikon repairing it under a 'goodwill' policy, you may have better luck than me if you live somewhere other than the UK. I told them to keep mine, as attempting to charge me for the repair was the last straw, it wasn’t worth me spending another £350 on a camera that hadn’t been reliable in the first place. I had been planning on getting a D3 in October/November but will now probably sell my Nikon gear and go over to Canon, as Nikon don’t seem too bothered about their professional user base, and I certainly won’t be paying £5,000 for a D3X.
Sep 25, 2008 | Nikon D2H Set Digital Camera
D2H NIKON
I see the same thing with my D100. Read here about the discussions on a D200 with the same issues: Photonet
Jul 01, 2008 | Nikon D2H Set Digital Camera
Where can I buy nikon sb600 and sb800 spare parts. Need replacement infrared covers.
You have to order parts from the Nikon authorized service rep for your area. Call Nikon tech support for information. In some areas, Nikon will sell direct.
Jerry G.
Apr 05, 2008 | Nikon Speedlight SB-800 TTL Flash
Distance problems
Good luck
Jan 31, 2008 | Nikon 17-55mm f/2.8G ED-IF AF-S DX Zoom...
Nikon 17-55mm f/2.8G ED-IF AF-S DX Zoom Lens Logo
189 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
