Simpletech external hard drive 500gb
How do i remove the external case?
seems to have some sort of mechanical problem. makes buzzing sound when attempting to turn on, then nothing. how can i retrieve my data from the driver?
thank you
  • 2 more comments
  • CGARCIA Feb 27, 2008
    computer will not pickup external drive
  • willsdad Feb 28, 2008
    funny noise..rotate click, rotate click. device is not recognize... just moved all family pictures to this drive
  • Anonymous Jun 14, 2008
    I just placed some important files and recent important funeral pictures on this drive. It started buzzing without loading up to the computer and nothing else. I took it back to Office Max where I purchased it. They would like to attempt retrieving the files and place them on discs for me. They also said they would offer me another external drive. I was attracted to the high capacity offered by Simple Tech, but I think I might settle for something else when I go back to the store. Maybe I will consider a smaller drive from WD. A friend of mine has one at work and he does not seem to have a problem with it.
  • skydvrz Jan 08, 2009
    I have the same problem of buzzing noises when the external is turned on. Never had this problem before. I have the only copy of someone's wedding video on this external and need to get access to these files ASAP!!! Someone please help!
  • 66 Answers
Well trying to remove is not a problem if you have some experience of putting it in the hard drive but ,check the wire connections first of all ,but i must inform you if you dont have any idea then ask on some repair shop just the opening part inside the things are really simple it has a LED for power on and off and some simple connectors that connnect ur hard drive to the usb from which you connect it to your computer so check if you can open just the outer shell with some help!!!hope it works for you!!
Posted on Feb 01, 2008
My SimpleTech SimpleDrive Pininfarina 500GB... stopped working
open the hard disk casing remove the drive check it on some other casing
May 06, 2014 | SimpleTech SimpleDrive Pininfarina 500GB...
I dropped my itb hitachi hard drive, it now makes a beeping sound but doesnt spin up any ideas?
Hard drives are easily destroyed by dropping them. The drive cannot be fixed. There are companies that can retrieve data off faulty hard drives BUT it will cost you an arm and a leg for their services.
Feb 17, 2013 | SimpleTech SimpleDrive Pininfarina 500GB...
How do I use my simpletech external hard drive. I
I have a 500GB and a 1TB. Both drives if they work at all, is because you have to apply the power after usb is connected. The 500MB still good but the 1TB took a big dump.
Dec 31, 2009 | SimpleTech 1TB External USB 2.0 Hard Drive...
SimpleTech SimpleDrive 640 GB external USB harddrive wont turn on
Loose connection inside the Drive case. Remove drive and check internal wiring.
Dec 23, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
External no longer recognized
Right click My Computer, Properties, then click on Device Manager.
Select Disk Drives then on tab menu Action, Add legacy hardware. Go through the setup and use CD's that came with Hard Drive otherwise search company site for drivers.
Oct 05, 2009 | SimpleTech 500GB SIMPLEDRIVE EXT HD-USB...
500Gb SimpleTech Ext Drive No Power
Hello.
It sounds like you might have a problem with the power supply.
I have seen MANY external hard drives with failing power supplies. Take it to the store you purchased it from for a check up, it should still be under warrantee if its only 3 months old.
Good Luck!
Jun 17, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
I have a 500GB external SimpleTech HD. Tonight it
If it was running at the time it fell, the heads crashed into the platters, and the buzzing you're hearing is the dents left in the platters spinning by 7200 times a second.
Not good. Likely will need a professional service to recover the data.
Jun 05, 2009 | SimpleTech SimpleDrive...
Won't recognize my USB
i have a feeling its not the hard drive thats bad i think it sounds like the case .
you can try buying another case and transfering the hard drive to it the case is around $20.00
Nov 30, 2007 | SimpleTech 250GB USB2.0 7200 RPM External...
Computers & Internet Logo
914 people viewed this question
Alun Cox
David Payne
David Payne
