posted by Filip_O on Jan 31, 2008
Hello!
I hope you can help me on that one! I just bought the Nikon 17-55mm on ebay, and it seems that when I use it with my D2H and SB800, the SB800 stays on 40mm mark all the time, no metter what focal length I zoom into. Also, when looking on exif file, it just says that I shoot the photo on 38mm, no metter if I shot on 17mm or 35mm etc....
How can this be repaired, and how much does it cost? Should I return this lense?
Kindest Regards
Filip O.
filipmisiak.com
Best Solution
posted on Feb 02, 2008
I don't think it is possible to diagnose this problem, so this is just a suggestion. After checking out your website, I'm pretty sure that you know how to work your equipment so I think the usual dribble about making sure the flash isn't on manual, etc. Well, that wasn't the suggestion, this is. Take a cotton swab and clean the contacts on the lens with isopropyl alcohol. If the cause of your problem is a bad contact, that should take care of it. If it doesn't work, I'd send the lens back straight away - because if this doesn't work, then who knows what is going to go wrong next.
Good luck
Good luck
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Nikon 17-55mm f/2.8G ED-IF AF-S DX
Email this problem
Email this problem
Can you Help with these Camera Lenses problems?
Repair Service
Find Camera Lense Repairman Near You:
