I don't have a manual so I don't know what this light means on my 1997 Mitsubishi montero. It says C/D (not the disc player) It is a light on the dash next to the 4wd wheel indicator lights. It just came on and the car is shaking a lot when I go up hill or speed up.
It depends on what warning light is on!
In any case, from your description and experience, it would be your engine 'Oil' warning light: it comes on when there is not enough lubrication (thus the overheating) flowing because of low oil pressure: immediately check your oil leveland top up as required) and make sure that change your oil and oil filter as soon as possible as it is a very damaging condition and the engine could seize.
Hope it helps: let me know hoe you go.
Right off, it sounds like you are low on coolant possibly along with other overheating problems. A car works harder going up hill than down.You have not described what the icon looks like. Is it a thermometer? With car not running, turn on the key but don't crank it. All dash light indicators should come on for several seconds as a test. Does that same icon show up during this test? Have you checked the coolant level in the coolant overflow vessel located under your motor hood? Let me know?
