Question about Panasonic AG-DVX100A Mini DV Digital Camcorder
Mic level problems
I have channel 1 set to input 1, xlr/mic plugged in to input 1's input, channel 1 audio level cranked up, and the only way to get a level on the mic is to literally pound on the mic.  Internal mic does fine, but problem is the same all things being equal on channel/input 2.  This is a used unit, new to me, previous owner remembers having a similar problem but says it's a setting, but couldn't remember what that setting was over the phone and I can't find anything relating to this problem in the owners manual.  Also tried with another mic, same problem, plugged this mic into another camera, mic and cable seem to be fine, too.
  • AngelFaces Feb 06, 2008
    I thought it posted my addition to this a day or so after I posted... I found that switch and it worked, human error is a bit embarrassing :-)
  • Anonymous Jan 24, 2009
    Thank you. I just bought a used DVX100B and I was in a panick!
Also put the phamton switch in off . and put a dynamic mic. the setting in menu is better put in -50db and adjust the level control .
Posted on May 17, 2009
There is a small switch on the front side of the camera ( the lens side) make sure that it is set to mic (Input 1)
Hope this helps.
santhoshcj@gmail.com
Posted on Feb 06, 2008
Ch. 1 on Behringer pmp4000 not working
A short on the XLR input board, or possibly a short within the XLR connector itself.
Nov 14, 2017 | Behringer Europower PMP4000 Powered Mixer
Audio-Technica freeway 200 Series VHF Wireless System - I had problems connecting the wireless system with a quarter inch to a xlr. The sound system made a very loud disturbance sound. What cable do I use...
XLR connectors are a two-wire plus ground system. Using a 1/4 inch to XLR adapter may not connect the wires correctly to your sound system input.
The A-T Freeway 200 Series has a 1/4" output jack. This would indicate a line level. A cable to connect the tip of the 1/4" jack to pin 2 of the XLR and the sleeve of the 1/4" jack to pins 1 and 3 of the XLR should work. The XLR should be plugged into a device that accepts line level.
Ideally, you should plug the 1/4" into a 1/4" or RCA jack that is designed for line levels.
Dec 14, 2010 | Audio Technica ATM33A Fixed Charge...
My mic output is very weak. Music comes out great. I have to set the levels all the way up to get any mic sound and usually there is a lot of clipping. You need to almost scream to get any sound with a...
Thiis amp has plenty of gain for mics. Make sure your mic has a good XLR to XLR cable (balanced) and connects to the XLR input connectors. If you have 1/4 inch jack cables that aren't TRS balanced on the mics, get rid of them and get XLR's.
Then push the PFL button down (LED will light red) for a single channel with a mic and adjust the trim (top knob for the channel) so that the level peaks without clipping on the main LED display when highest input to the mic is being generated. You should not get clipping then during operation.
After that you use the slider tio adjust the level for the mic. The MAIN slider should be at least up around -10 to zero during operation. If your main slider is way down, then you haven't balanced your channels properly. Do the same for each channel as the instructions for the mic above. If the gains of the other inputs are too high and the MAIN slider too low, this is what is causing your problem.
Typically the trims for mics like Shure 58 are about 3 o'clock.
High level guitars may have trims anywhere from 9 to 3 o'clock.
Ideally you will want your channel sliders to be between -10 and zero.
Sep 11, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
How tointerface an audio technica mb 4k to computer
As long as the microphone is getting power (via a seperate phantom power unit, or using batteries, the MB 4k can use AA) you should be able to plug into a computer with no trouble, as long as a couple other things are set. You'll need two things in addition to your mic and battery.
1) You need an adapter to go from XLR to 1/8". Go to www.sweetwater.com and search for "XLR to 1/8". They are around $10.
2) Your computer must have a "mic" level input. It is probably a red connector. If your computer only has a "line" level input (probably blue), then you will have to use the mixer, or some in between unit to up the output of the mic to line level.
Not sure why your mr8 is outputting so low. Make sure you have phantom power turned on.
Best of luck!
Jun 19, 2009 | Audio Technica Audio-Technica MB 4k/c...
Panasonic dvx1000a has no audio input, for xlr connector, the switch line mic is in mic pos. and the external mic not work in that camera.
You have to switch the CH1 and CH2 switches inside the lcd display to input 1 or input 2 to control the xlr inputs. If these switches are in int (L) and int(R) position, then you are adjusting the audio on the CH1 ad CH2 dials below the lcd viewer on the outside of the lcd for the on camera mic. Only use line setting on the front of the camera when you are receiving an audio feed at line level from an audio board. If you set the camera to mic setting, and you are receiving a line level audio signal, you will blow out the audio 0 way too loud, if you are receiving a mic signal and your switch is set to line, you will not be able to hear the mic with the audio Ch1 and ch2 all the way up.
May 17, 2009 | Panasonic AG-DVX100A Mini DV Digital...
MY JOB DEPENDS ON THIS!!! SONY DSR PD170 AUDIO PROBLEMS
Appreciate the direct "Ask Me".
The Sony PD170 is not an everyday equipment, nonetheless, I will assume that on the Sony DSR PD170:
  • the Samson UHF M32 receiver is plugged to Audio 1;
  • boom mic is plugged to Audio 2; (or vice versa) and
  • Both Audio 1 & 2 are using the XLR connectors.
Assuming that your boom mic is a conventional dynamic, on the Audio Control Panel, pls set:
  • INPUT 1 -
  • MIC CH SELECT CH1&CH2
  • INPUT LEVEL MIC
  • +48 OFF
  • INPUT 2 -
  • INPUT LEVEL MIC
  • +48 OFF
This is of course assuming that both the boom mic and the output of the Samson UHF M32 receiver are set to MIC level. In some instances the Samson UHF M32 receiver requires a LINE setting. The only time the +48 is set to ON is when the mic that is used/plug in requires phantom power such as condenser types. If the mic or the Samson UHF M32 receiver requires power then this should be switched ON otherwise, there will be no audio coming in. Though most M32 uses a 9 volts battery.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 11, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Channel Two Input silent
Not sure of particular model, but if it's like z1 then it's convoluted and non-intuitive.
But here goes.. if i can remember.
Go into menu, then audio
check that the channels aren't linked
if set to manual check manual adjustment wheels
The z1 doesn't seem to allow on board mic and xlrs, so check that
Does mic need phantom power?
Is XLR input set to mic?
Sorry i can't be more model specific... but hopefully something of this will be helpfull.. the main thing to check tho is that the xlrs aren't linked
Jan 29, 2008 | Sony Dvcam DSR-PDX10 DV Digital Camcorder
Sound recording with external microphone
An instruction manual is available for download at www.canon.com
Your camera, according to the manual, has a single input for microphones, and in the internal menu, AUDIO DUB has to be set to MIC. IN. when using an add-on microphone. An MA-300 hot-shoe microphone accessory can be used, and then the input controls would be on this device, not the camera. Your camera can also record in two different audio qualities: 16-bit two channel or 12-bit four channel. If you are using an accessory you may need to select 12-bit in the internal setup menu in order to have enough channels to add on the additional microphone(s).
Finally, and hopefully not, the camera may have an internal hardware problem, and so would need to be serviced.
Nov 05, 2007 | Canon GL2 Mini DV Digital Camcorder
Need of codes....
Hi I hope this will help http://www.dvcentral.org/tricks.html Tricks 4 XLR ins: Get the Canon MA-300 adapter and get yourself 4 XLR inputs. Perfect for a couple of wireless lavs, a boom, and another mic. Sure, it's less data for the audio channels, but it's plenty for voice recording. Sure, you can't digitize audio 3&4 easily, but it is possible, and it's just so darn useful to have four audio channels in the field. (Also, you can easily mount the wireless lav receivers right on the back of the camera.) Using the Canon on-camera mic via an XLR input: Say you're using a single boom mic, inputting via XLR 1. You've got XLR 2 doing nothing, and the on-camera mic doing nothing. Seems a waste. Well, all you need to do is adapt the on-camera mic to input through XLR 2. A short female-mini-to-male-XLR adapter will do for the audio signal, but the mic needs power. Simple, just get a short micro-mini extender cable, plug one end on to the mic, and the other into where the mic's connector would normally plug, on the camera's handle. Make sure the mic is switched to stereo, and voila, you have a second XLR mic. Monitoring in the field: Though many people told me it couldn't, the XL H1 downconverts to NTSC on the fly during recording, so you can plug a little monitor or deck into the video and audio out jacks and have yourself a video tap. Perfect for the director who wants to see what's going on through the camera. I used a little DV camera, and recorded it all so we could have a playback tape if needed. Very useful. (Note that the output NTSC is anamorphic, stretching the 16:9 image over the whole 4:3 frame. A monitor with a 16:9 switch is useful, or something that automatically adapts, such as what I used, a Sony PD-100 DVCAM camera.) Native slow motion: In a 24F project, shoot 30F and use Cinema Tools to slow down the footage to 24fps for a slight slow motion effect. Use 1/60 shutter speed for a standard look, or 1/30 for a slightly dreamier feel. Good Luck.
Sep 15, 2007 | Panasonic Proline AG-DVC7 Mini DV Digital...
Panasonic AG-DVX100A Mini DV Digital Camcorder Logo
161 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
