Question about Nikon D40x Digital Camera
Dark monitor when i turn the camera on the flash pops up inmediately, the monitor is dark, i can take pictures but nothing appears on the monitor. i can not see the pictures i've taken. the battery is charged, it seems to be working correctly but "says nothing". thankyou for your help. MAGDALENA
  • medelein Feb 01, 2008
    oh, no ! i know that. the thing is that when you use the monitor/play button nothing appears, i mean the monitor is dark all the time no matter what button you use. another thing: it sounds and moves as soon as you turn it on as if it was focusing. should i reset it?
    yes i know. thank you very much. i just reset it and it seems to be doing ok.
  • 667 Answers
Since the D40X is an SLR, (single lens reflex), it is not possible to use the LCD monitor to frame your pictures before they are taken.
To view what your images look like after you have taken them, you need to use the 'monitor/play' button marked with a rectangular box
Posted on Feb 01, 2008
  • Kevin Pettit
    Kevin Pettit Feb 01, 2008
    Couldn't hurt, Nikon service is the next option if that doesn't work. You would be surprised at the number of folks that do think SLR's work like the point and shoot digitals
I have a Fuji FinePix A330 camera and when I try to take a picture in the light, daylight or lamp light, lines appear through the picture. Sometimes fine lines but other times like a burst of light. This...
I have a Fuji FinePix A330 camera and when I try Problem with the Fuji FinePix A330 Digital Camera I have a Fuji FinePix A330 camera and when I try to take a picture in the light, daylight or lamp light, lines appear through the picture. Sometimes fine lines but other times like a burst of light. This just started happening recently. But when I take a picture in the dark with the flash the photo turns out fine. Any answer as to what caused this? Thanks
Dec 28, 2010 | Fuji FinePix A330 Digital Camera
Apparently takes pictures ... but black out the screen .... if you turn on and everything but can not see anything ... Sorry about my English
I see nothing on the monitor screen when I want to capture a picture. The screen monitor remaind black but I can capture new pictures. when I press the play button, I can't see the picture. When I retreive the picture from the camera to a computer, I realize the picture is black and I can't distinguish anything.
But when I introduce the good picture from my computer to the Digital Camera, from the Sceen Monitor, I can visualize only the good picture I introduce in mysefl.
The flash is working properly, the on/Off button is ok, the lens appear to be normal.
My Digital Camera is Casio EX-S880 EXILIM
Jan 29, 2010 | Casio Exilim EX-S880 Digital Camera
Pictures very dark even with a light meter
Digital cameras operate on a delayed shutter. Your Camera and flash are not synchronized. Try adjusting flash to a slower speed. Or the cameras Fstop value to get them insync.
If you half push the shutter the rangefinder and focus circuits kick in and will adjust to available light and give you your best picture. Do not ever push the shutter in one step. press it slightly to get the best focus and then push the last millimeter to get the picture!
Dec 29, 2009 | Fuji FinePix S3 Pro Digital Camera
Picture too dark
Do not confuse dark pictures with black pictures.
1. Flash Range
2. Exposure Compensation
3. Monitor Calibration (low monitor brightness)
4. Obstructed or covered flash
5. Obstructed or covered light sensor (only on certain models)
6. Flash not firing
Visit www.kodak.com/go/stepbystep
NOTE:
A normal sunny outdoor scene is a good way to test the exposure metering of the camera.
Nov 16, 2009 | Kodak EasyShare C875 Digital Camera
Why does the word, ''busy'' pop up on the canon rebel xti?
If the flash fires a full charge(eg. in a dark environment) then this message will appear whilst it recharges. If the message appears all the time and you cannot take a photo there is most likely a problem. Try taking some pictures without the flash card to eliminate that first.
Apr 13, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Nikon SB 800 fires but pictures reamain dark
make sure your white balance is set to "flash" on both cameras
Oct 04, 2008 | Nikon Speedlight SB-800 TTL Flash
Flash and dark photos
Perform Initialize option in camera menu,
if problem doesn't fix, camera needs Strobe Adjustment and this can be perform in Sony service center because it requires spacial tools.
Thank you.
Sep 21, 2008 | Sony Cyber-shot DSC-W35 Digital Camera
White Screen
  1. Upon startup lens emerges but when screen appears it is white whereas it normally displays whatever the lens sees. When the shutter button is pressed the camera will focus and take a white picture which can be deleted. The camera does not flash although flash is set to automatic and photo taken in a dark room. Camera flashes (weakly) with flash set to manual on. Lens is unobstructed and appears to be perfectly normal. Camera was not dropped. Batteries have been changed.
Jan 19, 2008 | Pentax Optio E10 Digital Camera
In AUTO mode, pictures are all dark!
Yes you definitely can,
Turn on the camera.
The mode dial can be turned to any setting.
2. Press the button for longer than 5
seconds.
The message “Reset settings to default?” appears on the
LCD monitor.
3. Select [OK] using the left and right
buttons, then press the button.
The normal screen resumes when resetting is complete.
To cancel resetting, select [Cancel] instead of [OK].
Dec 09, 2007 | Canon PowerShot A70 Digital Camera
Nikon D40x Digital Camera Logo
148 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
