Question about Radio Shack Pro-2018 Scanner
My pro-2018 won't scan anymore.
I turn the volume on and adjust the squelch and all I get is static. It won't scan anymore. It used to work wonderfully but all of a sudden it won't scan. I have re-programmed it using all up to date frequencies.
Turn the squelch down and it will work
Posted on Jun 11, 2008
You may need to re program it and get a external antenna.i recommend that you get a scanner pc programming kit.
Posted on Apr 05, 2008
How can i stop the squelch ive tryed turning the sqcuelch doesnt help
Plug the AC adapter into the back of the scanner and into a wall electrical outlet. Screw the antenna into the receptacle on the back of the scanner (extend the antenna to full length for best reception).
  • 2 Set the squelch level to allow signals to be heard by turning the squelch knob counterclockwise. Rotate the volume knob clockwise until you hear static. Slowly turn the squelch knob clockwise until the static noise disappears.
  • 3 Start programming frequencies into the scanner by pressing the "Manual" button.
  • 4 Press the up arrow or down arrow key until the channel you wish to program is visible on the display.
  • 5 Use the numbers on the keypad to enter the frequency for the local transmitter you wish to receive.
  • 6 Press the "E" key to complete the process of entering the frequency.
  • 7 Repeat steps 3 through 6 for each additional frequency you wish to monitor.
  • 8 Press the "Scan" key to start the scanning process. The scanner stops on a channel when it detects a signal strong enough to hear over the squelch setting. Two seconds after the signal stops, the scanning process resumes.
  • Dec 06, 2011 | Uniden BC248CLT Base Scanner
    Whenever i turn on my pro-82 scanner all i get is static and have tried squelch and reset
    Check your antenna connections, if the connections are good then try a different antenna. Most likely that is the problem if it's the scanner. If your trying to scan Public Safety Frequencies you may be running into a situation where they have gone Digital and your scanner is Analog or they may have encrypted their frequency or control channels so the scanners won't work.
    Sep 21, 2011 | Radio Shack Pro-82 Scanner
    My scanner (radioshack Pro 2018) doesn't receive signals from local poloce, ambulance and so on. What do I need to do?
    First, try scanning the Weather band to see if you scanner is working properly. If you don't pick up anything, your scanner likely needs some professional help. If the Weather broadcasts come in, then you just don't have the correct frequencies programmed for your local services, and it's possible that your area is using a trunked system - which your scanner is not capable of receiving. For a comprehensive database of active frequencies and systems in your area, Visit:
    www.RadioReference.com
    The site will tell you if trunking systems are in use, and it will also provide a wealth of other useful scanning info.
    Bill B
    Aug 10, 2010 | Radio Shack Pro-2018 Scanner
    Can't break squelch ? Have Uniden Bearcat hand held scanning radi
    Look at the squelch knob. If it is turned fully counterclockwise, it is in "Auto". Turn the knob clockwise to enter the manual mode and adjust the range untill static is heard. Reverse direction until the static is no longer heard.
    Jul 17, 2010 | Uniden BC248CLT Base Scanner
    SCANS BUT WILL NOT ICK ANY CHANNELS AND HAS NO
    Turn the scanner on and volume up all the way, turn the squelch until you hear static, then turn the squelch down slowly until its silent, press scan, has it ever been programed? Just a thought. hope this helps..
    Mar 25, 2010 | Radio Shack Pro-94 Scanner
    My scanner will not scan
    You need at least 2 or more frequencies programmed, and
    adjust the squelch knob until there is no more static, then press the scan button.
    Here's a manual
    Feb 09, 2010 | Radio Shack Pro-82 Scanner
    Have a Radio Shack PRO 2018 that stopped working properly,Scans but necver finds anything.adjust squelch and nothing but static so it is not the speaker.PLEASE HELP
    Did your local public service switch to a digital system? If so, you cannot receive digital trunking on this radio. Ask at your local Radio Shack store, or a local ham radio operator who can help you out.
    Jan 12, 2010 | Radio Shack Pro-2018 Scanner
    Trying to program it
    First you'll need a list of frequencies to program. For a comprehensive database of active frequencies in your area, visit:
    Once you have your freq list, power the scanner ON,and:
    1. Press PGM. Then enter the channel number (1-200) where you want to store a frequency, then press PGM again.
    2. Use the keys to enter the frequency (including the decimal point) you want to store.
    3. Press ENT to store the frequency into the channel. Press DELAY if you want the scanner to pause 2 seconds on this channel before it proceeds to the next channel after a transmission ends.
    4. To program the next channel in sequence, press PGM and
    repeat Steps 2 and 3.
    Operation
    • To listen to a weak or distant station, turn SQUELCH counterclockwise. If reception is poor, turn SQUELCH clockwise to cut out weak transmissions.
    • If SQUELCH is adjusted so you always hear a hissing sound, the scanner will not scan or search properly.
    Need the full manual for your scanner? You can download/print it here:
    http://support.radioshack.com/support_electronics/doc69/69290.pdf
    BillB
    Jan 09, 2010 | Radio Shack Pro-2018 Scanner
    Help setting up bc145xl scanning radio
    you have to adjust the squelch. When it scans it will stop when ever the squelch breaks. Start with the squelch turned up a little less then half way, then scan.
    Mar 02, 2009 | Uniden Bearcat Pro PC68XL 40-Channels Base...
    I am also new to radio scanning
    Hi, you do not mention where you are located, but my first guess is that you are trying to listen to some freq's that are not compatable with your scanner. The squelch you use to quiet the white noise, so when someone keys their mic the squelch opens easy and allows you to hear them. The scanner you have is a standard FM analog style scanner. Nowdays there is also digital and encripted, trunktracking, and more. None of the different styles are compatable. On my scanners at home I run an external antenna to pull in a greater range. Our local area still runs the standard FM radios. If you respond back with some info, I might be able to narrow the problem down further.
    Thank you,,, Mechanic
    Dec 25, 2007 | Radio Shack Pro-2018 Scanner
    Radio Shack Pro-2018 Scanner Logo
    220 people viewed this question
    Top Radio Shack Radio Communications Experts
    John
    John
    Greg Cann
    Greg Cann
    Jason
    Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
