Question about Video Cameras
No viewfinder image
This Sharp Jet Zoom 12 Model VL-L310U had been used very little, in storage mostly and up to now worked very well. The battery finally quit holding a charge after about 6-7 years. Here is my problem description below.
I have no image in the view finder. I have connected it to AC/DC power and tried it with and without a VHS tape. It powers up ok on the VHS functions and all else seems ok, except for a flashing camcorder & key icon that flashes in the side window near the auto lock button. Page 16 of the owner's manual refers to this as an "alarm indicator" and says to "follow the alarm immediately" by going to page 17 where there is no mention of this issue.
Any ideas? Thanks, Bill Jacobs.
Same problem!!! Someone help!!!!!
Posted on Mar 05, 2013
I wish I had an solution ..having same problem...do you have pdf for manual ...might be able to figure out.....
Posted on May 08, 2010
Sharp camcorder VL-L285 Troubleshoot
Any VHS camcorder is probably at the end of its life by now - replace it with something more modern
Jun 03, 2017 | Sharp Video Cameras
HOW DO I WORK A DIGITAL CAMERA?
STEP-BY-STEP INSTRUCTIONS FOR OPERATING YOUR FIRST DIGITAL CAMERA
1. READ YOUR CAMERA MANUAL before taking any photographs.
2. Check your batteries. Make sure to either recharge or replace them if you haven't used your camera as yet or for an extended period.
3. Insert your storage media card in the appropriate slot. If you forget to insert your media card, you'll get a "No Card" message.
4. Remove the lens cap.
5. Turn the camera on by either an on-off switch or a sliding lens cover.
6. Turn off the LCD. (See your camera manual for instructions)
7. Make sure your camera is set for automatic mode. Set the image quality to the size image desired-HQ (high quality) or less (to take more pictures on the same card).
8. Bring the camera up to your eye and look through the viewfinder. Positioning the target mark in the center of the viewfinder on your subject will assure that it will be in focus.
9. Push the zoom lever toward W (wide angle) to shoot wide-angle shots or push it toward the T (telephoto) to zoom in.
10. Press the shutter button half way down gently and confirm that the green light next to the viewfinder is illuminated.
11. Press the shutter button all the way down. You'll hear a beep when you take a picture. Wait until the green light stops flashing before taking another one. Remember, digital cameras have a slight delay that traditional cameras don't since it takes a second to save the image to your camera's storage media card.
12. Turn off the camera. Your new photograph should appear on your camera's LCD screen.
TIPS:
1. Use the viewfinder to compose your photograph, not the LCD screen, which will severely drain your battery power. Use your LCD screen only when shooting close-up photographs.
2. Hold your camera steady. Sometimes, the least amount of movement will cause your photo to be slightly blurred. Purchase a very small tripod so that you can provide extra stability for your camera. Also, if there isn't enough light (indoors or outdoors), make sure to use your camera's flash.
3. Experiment with your camera's features and take notes so that you can learn what works for you. Do this before you plan to use it for an important family event or trip.
Dec 15, 2010 | Cameras
Camcorder gone bad
First a few questions:
1) Will the unit accept a tape or is it completely dead?
2) In camera mode, does the viewfinder work?
Thanks,
Dan
Feb 17, 2009 | Sharp VL-A45 8mm Analog Camcorder
Need Manual
Display Optical Viewfinder Yes Optical VF Type Optical LCD Viewfinder Yes LCD Size (inches) 1.5 Power Battery Form Factor 2 x AA or 1 x CR-V3 Usable Battery Types Alk. / Lithium disposable, NiMH rechargeable Batteries Included 2 x AA Alkaline disposable Battery Charger Included No Flash Internal Flash Yes No of Flash Modes 4 Flash Modes Automatic, Fill (On), Off, Red-eye reduction Flash Range Description Unknown Ext Flash No Connectivity Video Out Yes Video Mode Switchable Yes External Connections USB 1.1 Other Connection DC In Included Software Unknown OS Compatibility Windows, MacOS Image Storage Usable Memory Types SD/MMC Other Memory Types Built In (8MB) Memory Included (MB) 8.0 Uncompressed Format None CCD Raw Format No Compressed Format JPEG (EXIF 2.1) Movie File Format MotionJPEG (AVI) Image Capture Image Resolution 1280x1024, 640x480 Movie Resolution 320x240 Aspect Ratio 4:3 CCD Sensor (Megapixels) 1.30 CCD Manufacturer Unknown CMOS Movie Audio No Quality Levels 3 Lens Digital Zoom Yes Digital Zoom Values 2x Auto Focus No Manual Focus No Normal Focus Range 120 cm to Infinity
49.0 in to Infinity Max Aperture f/3.0 Aperture Range Description f/3.0 Lens Thread Type None Exposure Number of White Balance Settings 5 White Balance Settings Auto, Sun, Shade, Fluorescent, Tungsten Manual White Balance No Longest Shutter Time 1/20 Shortest Shutter Time 1/2500 Exp Adj Range 1.5 EV Exp Adj Step Size 0.30 EV Metering Modes Auto Spot Metering No Aperture Priority No Shutter Priority No Full Manual Exposure No Self Timer 10 seconds General Model Number 3315 Camera Format Compact Currently Manufactured No Retail Price $99.00 Street Price $105.00 Price Update Date 2003-10-07 Date Available 2002-07-22 Remote Control No Tripod Mount Material Unknown Operating System Windows, MacOS Weight 120 g
4.2 oz Weight With Batteries? No Size 108 x 59 x 36 mm
4.3 x 2.3 x 1.4 in Warranty in Months 12
Oct 26, 2008 | Vivitar ViviCam 35 Digital Camera
Blurred image
The viewfinder image should look sharp & clear, as long as the camera is turned ON. If the camera is OFF, the viewfinder image will blur. At least this is how it works on my C2000z. If your viewfinder is always blurry, I would return the camera for exchange.
Sep 07, 2005 | Olympus Camedia C-3030 Zoom Digital Camera
Images appear to be very noisy or grainy
When DIGITAL ZOOM is set to ON in the MODE MENU, the lens can zoom into the Digital Zoom portion of the zoom by pressing the zoom (T) button. When you see the zoom indicator on LCD enter the red portion (towards Tele), the image in the viewfinder will become closer. However, since the D-630 is using the digital portion of the zoom, the lens doesn't physically zoom, it takes the existing image and enlarges your image using an electronic program. This can result in a “noisy” or “grainy” look to the image. This is normal when using the DIGITAL ZOOM. The DIGITAL ZOOM can be turned OFF to prevent you from using this portion of the zoom. Locate DIGITAL ZOOM in the Mode Menu and set it to OFF.
Sep 01, 2005 | Olympus D-630 Zoom Digital Camera
Difference between the D-400 Zoom and the D-450 Zoom
The D-450 Zoom is an improved version of the D-400 Zoom. Both models have the following features: •1.3 megapixel resolution •3x optical zoom lens - 2x digital telephoto •Stream-lined compact form design •Automatic focus, metering, and white balance •Built-in, pop-up electronic flash •Real-image optical viewfinder •LCD monitor •Buffered RAM memory; burst shooting •Video output to TV •12-second self-timer •8 meg SmartMedia included. Larger capacity cards available. In addition, the D-450 Zoom has the following features: •A larger buffered RAM memory permits rapid shooting (real-time shooting without having to wait for the image write) and a true sequence shooting in more quality modes: Memory Card Storage Capacity Shots Frames per second Quality Mode 10 2.0 SQ 8 0.8 HQ 4 0.8 SHQ •A new high-resolution glare-free LCD monitor screen that can be easily viewed at any angle and even in bright sunlight. The new monitor also uses less power •Automatic ISO adjustment from ISO 160 to 640. Manually selectable ISO 160, 320, and 640 •New Slow-Synchronization flash mode which enables the use of the flash on shots requiring long exposure (such as night time photography) •Image playback now includes an easier to use index mode of 4, 9, or 16 images. A 3x magnification inspection mode allows easy viewing of image detail •Overall power efficiency has been improved. 1.5 to 2 times more battery life compared to the D-400 Zoom •D-450 Zoom comes in a Champagne Gold finish NOTE: The D-450 Zoom digital camera does not include the Olympus FlashPath floppy disk adapter (which was included with the D-400 Zoom). The FlashPath adapter is available as a separate accessory.
Aug 31, 2005 | Olympus D-460 Zoom Digital Camera
Noisy or grainy images
When you press the “T” zoom button, the image in the viewfinder will become closer. However, since the D-435 uses a digital zoom, the lens doesn't physically zoom, it takes the existing image and enlarges your image using an electronic program. This can result in a “noisy” or “grainy” look to the image, which is normal when using the digital zoom.
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
When you press the “T” zoom button, the image in the viewfinder will become closer. However, since the D-435 uses a digital zoom, the lens doesn't physically zoom, it takes the existing image and enlarges your image using an electronic program. This can result in a “noisy” or “grainy” look to the image. This normal when using the digital zoom.
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
Aug 31, 2005 | Olympus D-400 Zoom Digital Camera
Video Cameras Logo
114 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
