Question about Comdial Digitech 7700S-PG Corded Phone
HOLD BUTTON FLASING, MSG ON LCD SCREEN
My hold button is flashing and my lcd reads a msg to call back one of my extensions... How do i clear this?
Try press ICM button # 3 and the ext number of that phone
Posted on Mar 23, 2008
  • 65 Answers
Sorry, but I have to ask, Have you tried to call back to the extention that left you the message? If that does not work go to the ext that left the message and see if you can release the message from there.
Posted on Feb 02, 2008
  • 94 Answers
I m expirt in mobile phons not in basic phons so plz ask me tthe problems about mobile phons ok thx bye
Posted on Feb 01, 2008
My phone is frozen! It is stuck on this msg. "Samsung SGH-T249". No matter which button I push, nothing happens. It will not turn off, nor can I make outgoing call. The screen stays...
Press and hold the power button until the unit turns off. Sometimes it takes up to two minutes to turn off. If you cannot get it to turn off using the power button, open the back and take the battery out. Press and hold the power button for sixty seconds with the battery removed to reset the unit. Then reassemble it and turn it on. This may not solve the problem on why your screen is getting stuck but it will reset and allow you to attempt to restart it.
Aug 16, 2011 | Cell Phones
I can not clear an error msg saying " Check Ink
Hi!
Try to remove first the ink cartridges. Then, using a clothe moistened with alcohol, clean the contact surface of the cartridge where the terminals inside the printer touches. Then return back to its carrier the black and color cartridges. Restart the printer.
If error continue to appear. press and hold down the STOP/RESET button (the circle with inverted triangle button) Hold it down and wait until printer self restart before releasing it.
Just give this answer a good ratings if you want to thank me. And post back if there's still a problem.
Thank you for using Fixya.
Jan 21, 2011 | Canon PIXMA MP170 All-In-One InkJet...
FPD1975W (Black) 19 inch LCD Monitor: power button flashes but not coming on...
Open the cabinet and remove CMOS battery and harddisk connection from motherboard.
And reboot the system. It will give the msg no boot device found. Now place again the cmos and harddisk and reboot
May 06, 2010 | Gateway FPD1975W 19" LCD Monitor
On my ge answering machine, the CL red light keeps flashing even though there is zero msg. so how do I clear this CL red light flashing
Your time needs set on your answering machine. If you have buttons on the top of your base, press and hold the day/check button to set the day of the week. Press and hold the hour button to set the hour. Press and hold the min button to set the min. If you don't have buttons on base, press flash button on handset to enter answerer remote mode. Press the 8 key to enter time set menu. Set hour and min using number buttons and set am/pm using caller id buttons. Press # pause to confirm the setting.
Nov 02, 2009 | Uniden Cordless Phone
N80 White Screen
white screen?? but still your phone boots fine?can you still receive call or text msg? if soo, your only problem is the lcd of your phone,
but if your phone freeze on white screen and didn't continue to boot up, try reformatting it
by
key combination which is used to hard reset the phone (similar to #*7370). It is useful in some cases, for example when the phone cannot reboot.
The trick is
Switch off the phone.
Hold down the following three buttons: Green (call answer) button, * button, and ‘3′ button
While holding these buttons, press the power button and switch on the phone
When the message ‘Formatting’ appears on the screen, release all of the buttons...
but all your data will lost
Sep 01, 2008 | Nokia N80 Cellular Phone
Problem in TFT
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
  • If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
  • If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Jun 09, 2008 | LG L1915S 19" LCD Monitor
Reading lens error on nikoncoolpix l12
Hitting camera on desk once has partial fix.
When camera's batteries taken out & then put back in and the power on button pressed to switch camera on, the lens extends out & the camera now works.
BUT when the power button pressed to switch camera off the lens retracts AND a "Lens Error" msg appears on the LCD screen.
Just have to take batteries out to remove msg & start again as above but WITHOUT hitting the camera.
Thanks
Feb 07, 2008 | Nikon COOLPIX L4 Digital Camera
What is the Meaning of this ?
I dunno what the actual msg means so this solution might be of no use. Anyway, remove the face plate completely. Then on the actual deck, you should see a pin hole, labelled "reset". Needless to say that is the reset button. Press down on it once, don't have to hold it. You should see a red light flash once. After doing this put your deck back in and hopefully it works, again this all depends on the reason of the error msg. My msg was "3000D A3" and this solution was indeed a winner.
Jan 19, 2008 | JVC KD-G430 CD Player
Comdial Digitech 7700S-PG Corded Phone Logo
440 people viewed this question
Top Comdial Lands Phones Experts
Starnley Johnwells
Starnley Johnwells
k24674
Are you a Comdial Lands Phone Expert? Answer questions, earn points and help others
