No power to decks
I have just received a pair of Denon DN-s3000 and plugged them in. They were from america and i plugged them in in the UK. The lights came on for seconds and everything died. I have bought an adaptor now however when i plug them in there is no power or anything. Do you know if they have a cut out switch or anything
  • 1,512 Answers
Sorry to say but you may have destroyed the units. USA uses 110volt. Uk is 240volts. There may be circuit protectors, pico fuses, internal fuses, and transformer fuses that have failed. replacing them first is the first approach to getting them going again. An adapter plug is not what you need. You require a step-down transformer to reduce the voltage supplies to 110volts. Check on the units also. There may be a voltage selector switch that you can select the right voltage for the UK. Be careful with how you go. Mains voltage kills. If you are not sure then please go to a tech and have them check the decks over for you. Good luck
Posted on Feb 01, 2008
6ya staff
SOURCE:
Tip
DISASSEMBLING AND CIRCUIT DIAGRAM
DENON DN-X300 DJ MIXER
DISASSEMBLE PROCEDURE
1. Top Panel
(1) Pull out the Knobs from the Top Panel.
(2) Remove the 6 screws attaching the Top Panel.
(3) Pull up the Front Panel.
for more check the link bellow use the search tab to find DENON DN-X300
http://electro-medical.blogspot.in/
google.com/+AjinGopakumar
on Feb 22, 2015 | Denon DN-X1500S DN-X 1500 S DJ Mixer
The Denon DN-C680 gives ERROR 105 on the display. Why?
Apr 04, 2011 | Denon DN-C680 CD Player
Does not turn on - could be power supply problem - external cable and fuse okay - how do I open case to look inside?? (qualified electrician and stage systems specialist)
screws on side come off and you must remove the 4 screws on the front and remove the CD drive. I think there are a couple on the back. pretty easy to get lid off.
Jun 26, 2009 | Denon DN-S3000 Turntable
Need manual for Denon DN-2000F MKII
u can get the manual in this link below
http://www.warnk.de/denon.html
else check this u wil get some more information
http://www.google.co.in/search?q=manual+for+Denon+DN-200F+MKII&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
thank you
May 06, 2009 | Audio Players & Recorders
Help with denon dn-s3000
if the cleaning cd don't work then it will need to be cleaned by hand , and if that don't do it then you will need the laser mechanism replaced
electech
Oct 29, 2008 | Denon Dns1000 Table Top CD Player CD...
Playstation3 and Denon AVR-1804
If you don't have a user guide, go to:
usa.denon.com From there, you can click on Support and search for archived info...you will find a pdf there.
Of your five plugs, a red and white next to each other will plug in to the audio in on your denon (Red is for Right) I would use something like the VCR-3 pair on the left side of the rear panel. The other three, Red Green and Blue are for Video Component In on the denon; Use either Video-1 or Video-2 in the component section on the right half of the rear panel.
At his point, it will be best to look at the manual, because you will have to pair the two items together in the menu system. It takes a little patience but isn't too hard.
Good luck.
Sep 04, 2008 | Denon AVR-1804 Receiver
Power conversion
If you have 110 - 120 volts AC at 60Hz, then the mixer must be bad. Unless 50 Watts isn't enough. Does the voltage drop when you plug in the Mixer to the convertor?
Geno
Mar 05, 2008 | Denon Dn-X1500 Professional DJ Mixer...
Stopped consistently producing sound
Try plugging and unplugging a pair of headphones. The headphone jack in these receivers are flaky and sometimes think there are headphones hooked up even when there isn't. Full repair would require the headphone jack to be replaced. If you don't use headphones at all, you can take the top cover off and unplug the cable going to the headphone jack board and eliminate the problem that was as well.
Mar 01, 2017 | Denon AVR-1603 Receiver
66 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
