Question about Acer TravelMate 2300 Notebook
Laptop's LCD Panel showing a vertical burn-in patch (Picture Attached)
My Acer Travelmate Laptop suddenly started to display an odd vertical patch. It happened when I resumed my laptop from Stand-by mode. This patch is about 1.5 inches wide and runs from the top of the screen to the bottom. The color under the display is fine but the brightness is dull. I used DPT software (Dead Pixel Tester) to re-activate the pixels but it did not work. Although I did notice that the patch is not visible when the background image is green. (Seen below)
Please help me out with this problem!
  • 58 Answers
Try updating your display driver.
Generally the computer should be updated as far as the drivers is concerned.
Check on line at the website of this laptop for updated drivers.
Check these before you do anything else.
Posted on Feb 01, 2008
Laptop black out
When the following situations, you need to replace the LCD inverter:
No image on the screen, but the power light stays on
Dark display but still readable
Between the screen flashes on and off 1/2 to several seconds
Power light stays on, but no display and sound
No image on the screen, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
More:http://www.lcdinverter.info/acer-travelmate-8001-lcd-inverter-p-2046.html
Aug 08, 2013 | Acer Computers & Internet
Acer 4320 can not switch on properly. after a few minutes turn on, suddenly black out.
The problem is most likely the DC jack in the laptop, causes are no power to intermittent operation, but if the screen blacks out it means the LCD display has issues especially if the rest of the laptop is working, could be a loose video cord from the screen to the motherboard has come loose.
Jun 10, 2012 | Acer TravelMate 4320 Notebook
HP Pavilion dv6-3007tu
what exactly is your problem? will it not start?
Jul 25, 2011 | HP Pavilion dv6-1122us Notebook
White screen on Acer Travelmate 7720
most likely you have a faulty LCD screen, the only option u have is to replaced it or u can use a external LCD screen to act as screen for your laptop. you'll be needing a VGA cable to connect your laptop to any LCD screen available.
Dec 16, 2009 | Acer Aspire 7720 Notebook
Acer travelmate 230 laptop doesn't display battery? ideas?
This should work. Go to 'Start-Control Panel-Power Options' Go to the 'Advanced' tab and make sure the 'Always Show Icon on Taskbar' button is checked.
JB
Jul 12, 2009 | Battery Technology for Acer Travelmate...
Acer 2410 display having 3inches wide black vertical line at the right end
Hi...there,
The problems.. your panel are damaged. Don't bother to replaced...will cost you a lots of $$$.... It's time for retired...
Oct 14, 2008 | Acer Refurbished 11 3 STN LCD DISPLAY **...
Display Screen
she might have changed the display settings, right click on your desktop and go to properties, go to the settings tab and change the screen resolution there. might not be the problem but worth a look, i had something simular when my daughter messed with my pc.
Jun 25, 2008 | Acer TravelMate 4010 Notebook
Vertical red line on notebook screen
send teh laptop for the repair most probalbly the port haas gone bad
May 19, 2008 | Acer TravelMate 4150LCi Notebook
Travelmate 4000 disassemble
Reinstall direct x before disassembling the laptop. If the problem is hardware is likely to be LCD display to be replaced, LCD ribbon cable out of place, or graphic chipset defective.Here is download of part list and explode view for your laptop. You can require service manual or schematics for travelmate 4000 on this forum, or check older posts and see if you can find it.
Regards
Apr 05, 2008 | Acer TravelMate 2300 Notebook
Acer Travelmate 6291 LCD monitor problem
Your concern is a typical problem with LCD displays/monitors. There could possibly be three (3) reasons why it is behaving as you have posted.
1. Backlight/Inverter problem;
2. LCD panel problem;
3. Video card problem.
You can do initial diagnosis by:
a. connect the laptop to an external monitor. Using the Fn + F? keys, activate the external monitor to be the default display. If it works, you have eliminated the possibility of the video card having a problem. If it likewise did not display anything or blanks out after sometime, then you have just confirmed that it is the video card that is a problem.
If you have ruled out the video card (using above procedure), you can proceed determining if it is an LCD panel problem or backlight/inverter problem.
To determine if it is a backlight/inverter problem, run the laptop normally even without a display. Let it boot and run through its startup sequence even if you can not see anything. Using a flashlight, shine a light obliquely to the face of the LCD display. if you can see some semblance of your desktop albeit dark, then you have just confirmed that it is the backlight/inverter. If even with the aid of a flashlight, the display s completely blank, then it is possible that the LCD display panel is defective. In some cases it is the flexible flat cable that is at fault.
With any of the aforementioned possible problems, opening the unit is required. This would need familiarity with electronic components and circuitry, use of a DVM and perhaps even a soldering iron. Should you not be comfortable doing this, it would probably be to your best advantage to seek the services of a qualifiedly professional.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 22, 2008 | Computers & Internet
Computers & Internet Logo
214 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
