Hourglass nd blue screen
unplug it from the comp if you havent already. does it have those sunken reset buttons? check the manual or online if you are not sure. if YES, reset the device and move on to the next step. If NO, you can either remove the battery (if possible) and try it back after a little while, or better, let it run out of charge and remove the battery then. By this time, please reboot the computer to make sure its fresh, to use layman language. Does it use a wall charger or has to charge on the comp? Does it have a regular USB 2.0 slot, cuz then you can use your phone charger or some other wall charger with the regular usb jack (male part). If no wall charger, I guess just re-plug it into the rebooted computer, and see if this helps it any. Sometimes my old Ipod 1st gen nano does this, and does not have a reset button or a way to remove the battery, so i just let the charge run out and the battery die, and when I charge it again, it works just fine. tell me how this works.
The battery was low, and I tried to recharge it, but it won't turn on. I've made sure the LCD is on and not the tv or hold. I've tried resetting it, USB charging, AC/DC charging, but nothing works.
mp3 player wont charge
