Question about Mitsubishi VS-50611 50" Rear Projection Television
Mitsubishi 50 in tv model # VS-5061
Television works fine when first turned on , then after about 5 min the screen turns to a yellow, blue color and images have shadows ( kind of double image)
Then it will go back to normal, to a nice sharp image and then start all over again. Any help would be appreciated. I do have a service manual and a little experience with electronics.
  • Donna Webber Feb 14, 2008
    Checked the circuit boards and found them to be dirty with an oily sticky residue. Cleaned them off with electric motor cleaning spray.
    re-soldered all soldering joints on the CRT pc boards. Television is still not working properly. After a couple of minutes after turning it on, one side (the right) is perfect the (left side) has a yelow blue shadow. THis is intermitant. Will check the CRT boards to see if there is any residue on them. Any more advise would be greatly appreciated. thanks
  • korry15 Jan 30, 2009
    I have this Mitsubishi 5061 tv. It has a weird problem. When I first turn on the tv the picture kind of has a fish bowl effect going on. The top and the bottom are curved outward. But if I leave the tv on for a few hours it fixes itself. Does anyone have any idea what is going on and how to fix it with out having to pay a repairman a couple hundred dollars to fix it?
  • Mitsubishi Master
  • 8,617 Answers
First of all check the circuit boards to see if ant CRT coolant has bee leaking on them. A strong flashlight will work best to spot it. It will usually appear on the front half of the boards nearest to the screen,. Mitsubishi has had some issue with CRT leakage. Also check for solder cracks around the Convergence amp ICs. Let me know what you discover, or if you need anything more.
Posted on Jan 31, 2008
  • Sonny Berry
    Sonny Berry Feb 14, 2008
    you have probably got some solder corrosion issues due to the coolant leaking onto them. resolder everything that had the crt coolant on the.especially the diodes and capacitors. You will also need to replenish the coolant levels after repairing the seals on the CRTs that were leaking.
I have a 50" projection screen tv model #
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Apr 14, 2011 | Mitsubishi VS-50604 50" Rear Projection...
Mitsubishi big screen won't stay on!
Its very possible you have a failing resistor r2200
Nov 22, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Screen is blue
the problem will either fix itself out or the screen will go. chances are one color goes then the next and then its toast but can go after blue as well.
Aug 06, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi parental control reset for tv model vs-5061
I can help you unlock your Mitsubishi HDTV V-Chip.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Jul 20, 2008 | Mitsubishi VS-50611 50" Rear Projection...
Mitsubishi vs 5043
I turned the set on and everything was fine, then the screen went black and mullti-colored horizontal (arched) lines were flashing across the screen. The next day I turned the set on and everything was fine for about 5 minutes then the problem reoccures again. Haven't looked for solutions till now.
Apr 06, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Tv lost color
Your problem most likely is on the signal board is my guess. If your not a technician it would be in your best interest to have him check L2C60 on the signal board.
Nov 19, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi vs-5051
First you can safely take off back and look for Screen controls&Focus, Gently turn up the 3 screen controls this will add light to picture, but you need to evenly turn up, the 3 colors are red, blue, green. the other 3 knobs are for focus. Do not turn them if you do you will need to realign the focus also. And if this doesn't help then there is a high voltage capacitor leaky in the flyback area.
Sep 14, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
692 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
