Question about Palm Tungsten T3 Handheld
Palm T3 frozen, tried restart in hole, nothing?
Palm3 frozen help please
  • 1 more comment
  • TITLE Jan 31, 2008
    I tried hot synch nothing happens,It has been off all day
    I tried hard reset and soft, NG
    Title
    I'm un sure of who is helping me. but iam still frozen after soft and hard reset /synchs
    title
  • 126 Answers
Doing a soft reset A soft reset tells your handheld to stop what it's doing and start over again. None of your information will be lost. After a soft reset, a screen appears that lets you reset the date and time, if needed. To do a soft reset, use the tip of an unfolded paper clip (or similar object without a sharp tip) to gently press the reset button inside the hole on the back panel of your handheld.
If a soft reset does not unfreeze your handheld, you need to do a hard reset. Doing a hard reset Only do a hard reset if a soft reset doesn't solve your problem, or if you want to clear all of your information from your handheld. [!] IMPORTANT A hard reset deletes all records and entries stored on your handheld, including the username that identifies the handheld. Before you do a hard reset, be sure to synchronize.
1spacer.gif palm T3 frozen, tried restart in hole, nothing? - spacer.gif hold the power button. spacer.gif 2spacer.gif While holding the power button, use the tip of an unfolded paper clipalm T3 frozen, tried restart in hole, nothing? - spacer.gifmilar object without a sharp tip) to gpalm T3 frozen, tried restart in hole, nothing? - spacer.gifs and release the reset button inside the hole on the back of your handheld. spacer.gif palm T3 frozen, tried restart in hole, nothing? - spacer.gifspacer.gif Wait for the Palm Powered™ logo to appear, then release the palm T3 frozen, tried restart in hole, nothing? - blank.gifton. spacer.gif 4spacer.gif When you see the message that warns you about erasing all of the info on your handheld, do one of the following: blank.gifPress Up on the navigator to finish the reset and show the Digitizer screen.
blank.gifPress any other button to do a soft reset.
Posted on Jan 31, 2008
  • Dean Pitts
    Dean Pitts Jan 31, 2008
    If your handheld continues to freeze after a reset, check your third-party applications for incompatible applications.
    If you think you have an incompatible application, here is a link to the Palm support for this specific problem
    http://www.palm.com/us/support/userguide...
    It explains the problems with incompatible applications and how to the third party application that is causing the problem.
    Dean
  • Dean Pitts
    sorry, how to find the third party application causing the problem
    Champion:
  • 207 Answers
I understand that your palmtop PC is frozen however, I believe that many of these drives were corrupted OR your memory has run out space. I suggest have it checked to liscensed technician and have it backed-up some of your vital files and documents then refomat it to replace the software with a new one and to supply new drivers as well.
    President:
  • 1,950 Answers
Is this how you performed the update?
  1. Slide open your handheld.
  2. While pressing on the Power button use the tip of your stylus to press the Reset button on the back of your handheld.
  3. Continue holding the Power button until the Palm logo is displayed, then release the Power button.
  4. Your screen should now display the following:
    Erase all data?
    Yes = "up" button
    No = any other button
  5. Press the "up" button to erase all data.
  6. Complete the setup on the handheld (picking language, set date/time, etc.)
  • 1 more comment
  • Damen Wong
    Damen Wong Jan 31, 2008
    Does it turn on and then freeze?
  • Damen Wong
    I made a mistake in the first post...I mean hard reset not update.
  • Damen Wong
    Did you try disconnecting the battery overnight?
6ya staff
SOURCE:
Tungsten t3
Please use the free chat feature that palm offers. I am not sure of any other way to charge your palm. Here is the link. Scroll to the bottom of the page and you will see Palm Chat. Click on the Chat Now link and follow the instructions. Best wishes.
http://kb.palm.com/wps/portal/kb/na/tungsten/t3/unlocked/supportservices/page_en.html
You might be able to find a charger on Ebay too.
Nov 18, 2009 | Palm Tungsten T3 Handheld
How to resart?
Go to this url and select what you want to do for detailed instructions. Save the url for future reference...Enjoy and please rate this solution.....
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=5183,E=0000000000342449107,K=3005,Sxi=8,Case=obj(887)
Mar 23, 2009 | Palm Tungsten T3 Handheld
How do you restart the tungustine t3?
See your other 3/23 post. I posted the url on that one.
Error in Palm Desktop on PC
You need version Palm desktop v6.2 (not v4) to run under Vista. If you have the 64 bit version of Vista you will have to use Bluetooth to transfer data, not USB. Enjoy and please rate this post.
Mar 21, 2009 | Palm Tungsten T3 Handheld
Phone restart
Did you poke the reset hole in the back of the palm? This does a reboot.
You can try that, or try plugging it in to charge and while it's charging poke the reset hole (this is supposed to reset the charging mechanism).
Sep 04, 2008 | Palm Treo 755p Smartphone
Good evening....i think i left my palm "on" & not charged last night. i opened it this afternoon & it was a white screen that said RESET. i tried to turn on or off & pressed restart...
Hi, from the sounds of your situation, im sorry to tell you that your address book is gone. If you have hotsync with your desktop before, you may be able to retrieve a copy of your address book from your last sync. Otherwise there are companies available to recover data from pdas but their services are very expensive.
Mar 10, 2008 | RIM BlackBerry Pearl 8100
Plam T3 frozen
Have you tried a hard reset?
Jan 31, 2008 | Palm Tungsten T3 Handheld
take the battery off for 15 seconds and put it back again. you need to reboot your Palm at least once a week. goodluck!!!
Synchronizing Tungsten T3 with desktop or laptop
I recently re-installed my T3 program
What do you mean?
  • Did you restore your T3 from a backup on the PC?
  • Did you install programs on the T3 using the PC's "quick install"?
Is Palm Desktop showing the correct Contact/To-do/Calendar Data?
How are the conduits set up? (From Palm Desktop, select Hotsync->Custom)
Nov 15, 2007 | Palm Tungsten T3 Handheld
Really dumb but help please
Here's the link to the user manual; http://www.palm.com/us/support/handbooks/palm3.pdf check page 16 of the pdf file (page 8 of the manual) it shows the location of the serial port (there is no USB) page 29 of the pdf (page 21 of the manual) shows how the palm sits in the cradle and how the cable connects to your serial (COM) port on the PC. also page 66 of the pdf(page 58 of the manual)claims you can use an otional hotsync cable if you do not have a cradle. go to this link to download the software required; http://www.palm.com/us/support/palm3xe/ there are also some video instruction guides etc. contact; http://store.palm.com/home/index.jsp to order a cradle or a cable if these weren't stolen with the palm. Hope this helps, please ask again if you have any problems :)
Jun 27, 2007 | Warrior 797146022002
Palm Tungsten T3 Handheld Logo
167 people viewed this question
Top Palm Computers & Internet Experts
Ekse
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
