Question about Verbatim VER95327 USB Hard Drive
Bought a Verbatim 1Gb USB Drive with some .pdf files for secure zone. I overwrote these accidentally.
  • Verbatim-Store 'n' Go USB Drive 1 GB. I have accidentally lost the manual and a nother text file, both in .pdf format, relating
  • 2 more comments
  • watson2 Feb 21, 2008
    I have an ibm think pad 1420 with win 98 se. It has a usb 1.0 port and I would like to use my verbatim 1GB flash disc. The system doesnt recognize it so can't install it. what do I do to either upgrade the usb port or the drivers in win 98 se? (or both).
  • Anonymous Mar 26, 2008
    how do i get file from my verbatim
  • bob68ou1 Aug 23, 2008
    need to know how to use usb drive in my computor no instructions came with it please help
  • Anonymous Mar 17, 2014
    cannot format verbatim store n go V3 usb driver
    Sergeant:
  • 226 Answers
Usb drives dont have manuals the computer automatically detect the drive.
in saving files it is the same when you save in a floppy or other drives.
Posted on Jan 31, 2008
6ya staff
SOURCE:
How do i download the privacy zone exe file for my 1GB verbatim 2.0 store 'n' go flash drive
if you are downloading data from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another device or a
usb device
if you need more help with this post a reply
hope this helps
Jun 23, 2012 | Computers & Internet
Verbatim usb drive 8 gb help
I would like to give you some solution steps. However you haven't indicate your Operating System. So please let me know the operating system (XP, Vista etc)
Feb 04, 2008 | Verbatim STORE-N-GO (95312) 8 GB Hard...
Download execution file for a privacy zone
or if you are downloading data from the internet
usb device
hope this helps
Verbatim 2 GB store n go says it has 918 MB of free space, but says 'disk is full' when I try to add files. I do not believe the store n go is partitioned. What gives?
If you can read the drive, Copy the information from it, into your computer, and format the drive, copy the files back, and it should work... also, if you have a security switch on the drive (write protection) you have to disable it.
Apr 14, 2011 | Verbatim ® Store `n` Go USB Flash Drive,...
I'm Windows XP... I can copy many files to the Verbatim. But when I try to copy a 1GB+ file, the copy craps out. I Googled and found some Microsoft problem when copying 1GB+ files to external drives, but...
The usual limit is exactly 2GB, not 1GB.
It's a limitation of the file-system used for the directory of the disk-drive, when formatted according to the 'FAT32' specifications.
So, copy all the files currently on the Verbatim to your disk-drive.
Then, "reformat" the external (not the "internal") disk-drive, using the 'NTFS' file-system. This file-system has a maximum-file-size limitation for one file that is _much_ larger than the capacity of your Verbatim.
Then, copy all the "saved" files back onto the Verbatim.
Finally, copy your "large" files onto the Verbatim.
Sep 30, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
5.84 GB will not fit on the 8GB Store N Go
Easy Fix.. You need to reformat your USB File System to NTFS rather than FAT32 (Default). FAT32 limits the size of all downloads to 4 GB. NTFS has no upper limit so you could download an 8GB file, if you wanted..... FAT32 is the default on the unit you have. Easy fix.... right click on your drive, click 'format', 'file system' change to NTFS and click 'start'. That's it ! ! ! !
Nov 19, 2009 | Verbatim Electronics - Others
Verbatim USB 8GB file copy problem
ITS virus problem which is playing with the inf file of the usb drive.
also another possibility is 1) the usb port ihas loose connections and disconnects i between drive sensing
2) certain 8 gb drives go back to a capacity of 2 gb drive if one formats it accidentally .
Sep 18, 2009 | Verbatim STORE-N-GO (95312) 8 GB Hard...
Verbatim 1gb flash drive privacy zone lost space
try this link. http://verbatim.com/support/support-article.cfm?support_id=807E395C-1422-1392-A886DB00B24DFF68&supportType=Download
Aug 13, 2008 | Verbatim CORPORATION 94933 USB 2.1GB...
In order to delete your privacy zone, you have to get the application once more. To get the software click here http://verbatim.com/support/support.cfm?open=Downloads ...ok so you will have to format your flash drive with the application, removing the privacy zone if you want, this will obiously DELETE ALL DATA ON THE DRIVE after the format has completed, you can then remove the application from you flash drive, if you still remember the privacy zone password, then all you have to do is just type it and you have acess to the privacy zone... anyone who needs assistance can contact me to [email protected] if you are confused, email me and i can also try to clear it up for you. MAKE SURE THAT YOU CHOOSE THE CORRECT PRIVACY ZONE APPLICATION FOR YOUR FLASHDRIVE
Feb 26, 2008 | Verbatim CORPORATION 94933 USB 2.1GB...
Microsoft Windows 2000 help Processor:, Intel Pentium 133 MHz or equivalent 8 CPUs Supported. Memory:, 256 MB. Drives:, 1.0 GB Disk space CD-ROM / DVD drive ...
Computer questions and answers listing 200 - 299 CH000273, Not able to see over 8.4GB hard drive. CH000274, Not able to see or boot with hard drive over 33.8GB. CH000275, Unable to see over 8GB with ...
Good Luck, Please dont for get to Vote, Thank You.
Dec 20, 2007 | Verbatim STORE-N-GO (95312) 8 GB Hard...
Verbatim VER95327 USB Hard Drive Logo
147 people viewed this question
Top Verbatim Computers & Internet Experts
gggg
Don Hart
Duncan Mutch
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
