Question about Onkyo DV-CP702 DVD Player
Fuse keeps blowing
During a lightening storm I heard a loud pop from the player. Opened cover and fuse had blown (1.6A 125V). Replaced with 2A 200V fuse and it blew right when player plugged in 2X. Did lightening ruin it?
  • sue316 Aug 10, 2008
    I have had the player for about 6 years-I don't know if lightning hit it or what-it just won;t come on
  • 43 Answers
Unfortunately yes :(
Posted on Jan 31, 2008
Tv does not turn on, after a thunder storm.. tv was off during storm.. but heard a click as if I was turning off tv.. Blueray player , ok Direct tv box ok , all come on that was connected to tv... whi
during thunder storm, is your TV connected to wall outlet, if it so your set have a problem on power supply, you are lucky if is only a blown fuse.
Aug 06, 2014 | Televison & Video
I just got a free sharp LCD LC19SB27UT and it has a power problem, I opened it up and notice a fuse was dead, this all happened because a friend was using it in a thunder storm, I went to radio shack and...
on the power board you will see a black flat ac converter with this on it + ~ ~ - on it check this with a meter its more than likely to have gone as its the first thing to go in a storm. the + and - can be the other way round ~ ~ is the mains volts in and + - is the volts out if the ~ ~ has no resistance it has blown and it will keep blowing the fuse check the + - and you should have a resistance from the rest of the power board.
Jun 05, 2017 | Sharp LC19SB27UT LCD TV
Have an HK AVR510 it stopped all sound. I opend it up and found that (under 10 years of dust) that one of the 125V 2A fuses had blown. (it is the first fuse on the right looking from the front of the...
I am now having a very similar issue with an av 100 unit I have had for quite some time now. Bought replacement fuses for it the same exact size and they keep blowing as well.. one thing I notice in the original fuse is that there appears to be a resistor in the fuse case.. maybe it requires a special fuse.
Dec 19, 2010 | Harman Kardon AVR 510 Receiver
The television quit working during a storm and seemed to not be getting power. Took off the back and found the 5amp/125v fuse blown. Replaced it and it blew again as soon as I plugged it in
Hello
All telivisions are provided with fuses, and the function of fuse is to protect its internal circuit agains short circuit, and protect the other components in the TV. if fuse must blow, surely there must ba reason. Without rectify that reason, if you put the fuse and switch it again, it may poise to other more problems. So get it repaired with a qulaified service personal. Never put any more fuse in it and swich on the Tv. Ok.
Oct 18, 2010 | RCA Televison & Video
I have a projectionTV Sony mod. KP48V75. During a storm the safety power fuse blew. It was 125V 6.5A. I replaced it with 125V 6A and so far everytime I plug the TV on it blows the fuse. I have been through...
Most likely the storm did damage to the power supply board (the G board in a Sony) which is part number A-1316-388-A for your TV. However the board is no longer available..It most likely has a bad regulator and possibly rectifiers on that board that are shorted. Complete board replacement would be the best solution.
Nov 03, 2009 | Sony KP48V85GRAY 48" Rear Projection...
Can't find 2A 125v fuse replacement for on-off will 250v be OK?
There is no difference between a 125v and 250v fuse. The most important thing is the 2Amp. This fuse is probably the line fuse and could be the only trouble and may have blow with a line surge. Make sure the 2A you use is a Fast Blow Type. If it does blow again you most likely have a internal power supply failure.
Apr 19, 2009 | Sharp Aquos LC-20B2U 20 in. LCD Television
Sony str-de845 Powers up, relay clicks, fuses BLOW!
This condition, may be produced by defective components (Q506, Q507). you can remove those transistor, replace the fuses, power-on and wait for relays click. if the fuses not blown again, them replace both transistor.
Mar 05, 2009 | Sony STR-DE845 Receiver
No power available to Pioneer CLD-D505 laserdisc player
Check the power supply look for anything that might be burnt or damaged.
Feb 10, 2009 | Electronics - Others
6.3a slow-blow 125v fuse
Hi, If the fuse physically fits into your unit then it will work. However- - - WARNING! Although 6.3 amps on a 250v fuse will allow the current to flow it will not afford you the circuit protection you require for a 125v circuit. If the circuit develops a fault then there is a danger that you burn out the circuit before the fuse. As you have already blown one fuse I would suggest tracking down the fault before you do any thing else.
The Scrivener.
Oct 12, 2017 | Pioneer VSX-D458 Receiver
Toshiba 50H81 TAC0151 Blowing Fuses, I Need schematic
Well without the schematic, knowing Toshiba they have alot of convergence problems, so see if the fuse blown in the convergence area, if you you may have to replace convergence amps. These are the big STK's. Most of the time there was a color problem with set before going out. If no problem with this on your set then look in the HV area Hor. and Ver. area. Hope this helps!
Sep 09, 2007 | Toshiba 50H81 50" Rear Projection...
Onkyo DV-CP702 DVD Player Logo
280 people viewed this question
Top Onkyo Televison & Video Experts
Steve
Are you an Onkyo Televison and Video Expert? Answer questions, earn points and help others
