Question about GE 24 in. GSD3210Z Built-in Dishwasher
Soap doew not disolve
I am have a problem with my dishwasher where the soap does not desolve. We use a liquid soap and have tried tablets. The main latch door does open during the cycles but when everything is finished and we open the dishwasher either the tablet is laying at the bottom of the dishwasher or the liquid soap is running down the side of the dishwasher. Where do I start troubleshooting this one at?
  • 1 more comment
  • houzful Jan 31, 2008
    The water is right up to the float. Which is in the forward left corrner. About 1 inch of water.
    Water Is dripping from everywhere!
    Hard water. Very Hard!
    President:
  • 1,314 Answers
First start the washer listen for it to fill then open the door and see how much water is in it let me know but hold my rating till we finish
Posted on Jan 31, 2008
  • 1 more comment
  • robert samples Jan 31, 2008
    ok let it go on see if you here it washing once you hear it washing open the door real quick and see if water is dripping every where
    hows you water is it hard water are you getting the water as hot at the sink as possiable before starting the washer has it always done this
    i know hard water can cause this try cutting the amount of soap you put in by 1/2 and dont use the tabs there are some dishwasher detergents designed for hard water you might try on of theese the washer seems to be working fine its just the hard water wont let the soap disolve
Soap tablets are not disolving in the drawer?
Unlike a dishwasher the drawer on a washing machine is for soap powder or liquid. Tablets won't dissolve in the drawer you need to put them in the drum if at all.
Dec 13, 2010 | Washing Machines
Smeg DI 409CA Dishwasher - Doesn't wash properly, tablet doesn't desolve and cycle lasted all night
The first thing is have a look at the instruction manual from HERE
If the dishwasher is not washing properly then please follow these steps:
  1. Check the water temperature. Should be 125 to 140 F.
  2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
  3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
  4. Check the spray arm and pump cover for splits or leaks.
  5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
  6. Make sure the dishes are loaded properly, or dishwasher is not overloaded.
  7. Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles.
As you said that the water builds up at the bottom see If it comes out 'foamy' then liquid dish soap is getting introduced into the dishwasher. Liquid dish soap is different than automatic dishwasher detergent. liquid dish soap needs to be COMPLETELY rinsed from anything that has been pre-soaked prior to putting in the dishwasher. after a couple of regular cycles the foam will go away. Nowadays liquid dish soap is also 'concentrated' or 'ultra concentrated' which doesn't help.
If further this does not solve your problem the the only solution is to get it repaired.
Goodluck..
Feb 23, 2008 | Dishwashers
Soap dispenser is not releasing and the water is not disolving the soap; thus the dishes are not getting clean
if you are using tablets as opposed to liquid then just put them in cutlery basket at beginning of cycle wash result will still be the same, probably wax valve has failed these do go often and will need new dispenser or wax valve service engineer will need to change
Oct 27, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Soap dispenser drops soap out and tablet does not disolve.
use liquid soap ...those tablets are less messy but they don't work very well ....and make sure to use a dry agent like "jet dry"
Jul 25, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
Tablet falls to the bottom of tub but wont disolve
The newer Whirlpool dishwashers have little slots in the top of the soap dispenser to allow water to seep in during the first water fill. This design allows the tablet to begin to dissolve during the first fill then be usefull when the soap door opens. In your case, I would check to see if the soap dish is opening at all. Perhaps one of the racks are not allowing clearance or the soap door itself is sticking closed.
Let the dishwasher fill, drain, and then fill again. Open the door of the dishwasher and see if the soap door is still closed and if so, there is your problem. Also, at this time, check the water temperature. It should be at least 120 degrees F for the soap to be effective.
Hope this helps, Ken
Jul 17, 2009 | Frigidaire Dishwashers
Whirlpool gold builtin dishwasher
Do not recommend premeasured tablets, usually too much soap. If pre-rinsing dishes use only 1 or two teaspoons of soap in the main wash cup..do not put soap in the prewash cup. Excess soap can cause oversudsing and make the soil sensor think the dishes are real dirty initiating additional wash cycles. Use rinse-aid for better drying performance
Apr 28, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have a kenmore dishwasher. the soap dispenser lid was not opening and releasing the soap, now the lid is opening but it's leaving the soap in the dipenser. have used the pellets that contains the liquid...
disasemble the pump housing and remove the debris that are located in the housing, not enough pump pressure to spin the spray arms to desolve the detergent
Apr 09, 2008 | Dishwashers
Soap does not desolve
check that the spray arms are turning and that the holes in them are not clogged, if you line them up pointing towards the front let the machine fill then as it starts to wash open the door and you should see the arms slowing down, if they are okay then check the water level which should just lap the filter at the bottom
Jan 07, 2008 | Jenn-Air JDB6510 Built-in Dishwasher
I put the wrong dishwasher on my last post.
Dec 01, 2007 | GE 24 in. GSD3210Z Built-in Dishwasher
Need to dissolve hard soap
The internals of a dishwasher are stainless steel and plastic and for these sort of problems a diluted solution oh hydrocloric acid can do the trick......just wear gloves!!!
Jul 26, 2007 | Kenmore 18 in. 14432 / 14439 Built-in...
GE 24 in. GSD3210Z Built-in Dishwasher Logo
307 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
