Question about D-Link DI 514 Wireless Router (DI-514)
Dir-655 router I just got a laptop with windows vista OS. but I can not connect to my DIR-655 router. does this router support windows Vista?
  • 196 Answers
Yes. Here's a link to the spec sheet:
http://www.dlink.com/products/resource.asp?pid=530&rid=2027&sec=0
What specific problem are you having?
Posted on Jan 31, 2008
Can i use Dir 300 on a windows 7? my desktop's OS is vista while my laptop's is windows 7.. would like to know if it supports windows 7..
Yes, this product is compatible with Windows 7.
To note, if you are upgrading to Windows 7 from either Windows Vista or Windows XP check before installing that your Wired/Wireless equipment on your computer will have compatible drivers for Windows 7.
Sep 08, 2011 | D-Link DIR-300 Wireless Router
D-link DIR 655 owner's Manual
Look on router ID plate for REVISION.
Owner Manual Links:
For DIR-655: http://www.dlink.com/products/?tab=3&pid=DIR-655&rev=DIR-655
For DIR-655 REV. B: http://www.dlink.com/products/?tab=3&pid=DIR-655&rev=DIR-655_revB
Thanks for choosing FixYa, If you find this helpful please vote and comment.
Oct 11, 2010 | Computers & Internet
My DIR 655 was working fine. Bot an IPOD Touch
Should be small recessed button on back of unit, use a pen and hold button in for about ten seconds to reset back to factory settings
Dec 28, 2009 | D-Link DIR-655 Wireless Router
Connection, via D-Link Dir 615, lost after restarting computer
Did you tell Vista to "automatically connect to XXXXX network whenever in range" ?
Oct 20, 2009 | D-Link DIR-615 Wireless Router
Cannot connect via wireless to dlink 655. wired connection works fine. when i disconnect to go wireless the laptop sees the dlink but there is no internet connection. running Vista Home Premium. static...
You must manually configure the wireless settings. Go to Network and Sharing Center > Manage Wireless Networks. Remove all the listed network there. Then click Add > Add Network in Range > Select your signal > Type the security if you have and press connect. That should do it.
Sep 23, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Cannot connect to DLink DIR-655
The part below is all you need to look at, the rest is Ethernet which is your wired connection, ethernet card.
Here is what are causing your problems from what you gave me and basically your computer is not communicating with the router:
1)I don't see any IP address for your laptop so you can't get on the internet if you don't have an IP address, also, I don't see any gateway address. The gateway address is your router address, and that address is given to the router automatically from your Internet Service Provider.
So if your computer cannot see the gateway address then the gateway address (router) cannot give you an IP address to get on the Internet.
Your Wireless card looks ok, that is the physical address and if you were able to do the loopback then its working.
So on your laptop I would begin from the beginning. Go into network connections and delete the DLink connection if it is there. Then Start>control panel>Network connections>click wireless network connection>click change settings of the connection on the left window>click wireless network tab>make sure checkmark"use windows to configure my wireless network settings>click add a new network>TYPE IN THE SSID FOR THE NETWORK>ENTER WEP/WPA KEY>CLICK OK, then close and you should be connected.
You said other computers are able to access the internet thru the DLINK so it all points to your laptop not being configured correctly.
HOWEVER :)...I see alot of "Media disconnected in your list. Make sure all of the lights are working on the front of the router, if not check the cabling or call the ISP sometimes the problem is on their end. Hope this helps, keep me updated.
C:>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : HPdv7
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Atheros AR5009 802.11a/g/n WiFi Adapter
Physical Address. . . . . . . . . : 00-24-2B-12-FD-63
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
May 01, 2009 | D-Link Xtreme N DIR-655 Wireless Router
My DIR 655 is able to conect to my laptop through wireless
Do you see wireless signal of your router from your Laptop? If not! make sure the Wi-Fi of your Laptop is activated for you to get online wirelessly.
Mar 07, 2009 | D-Link Xtreme N DIR-655 Wireless Router
D-Link DIR 655- losing connection with ntwk is "INVISIBLE"
unfortunatly it is my understandingthat blackberrys require an ssid to connect as they are not as advanced as a laptop or wireless adapter on a pc...sorry
Dec 11, 2008 | D-Link Xtreme N DIR-655 Wireless Router
How to connect USB NAS to D-Link DIR 655
if you update your router firmware to the most current you can use the usb port to connect to an external hard drive or flash drive but you have to install drivers on the computer you want to access it with also i believe only one person can access it at a time
Oct 25, 2008 | D-Link Xtreme N DIR-655 Wireless Router
D-Link DI 514 Wireless Router (DI-514) Logo
103 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
