Question about Panasonic PT-43LC14 43" Rear Projection HDTV
Tv power on for 10s some time
I have a lagend flat t.v. i closed the setelite last night but not the t.v it ran whole night. i always do that. i noticed in the morning the t.v. was still on but later in morining i found out that t.v. is not working. i tried plugging into different socket but no luck, one time the red light was on for 10 second. i tried many time, in many time few the the red light came on.
    President:
  • 4,402 Answers
Bulb, could be ballast or thermal fuse.
read here
Posted on Jan 31, 2008
I have a Panasonic plasma, & we just had a power outage today... every time we have one, it won't power back on. The call center is closed for the night, & I can't remember what they told me to do the last...
First, unplug the TV, wait 30 seconds to 1 minute, then plug back in & try it. This allows the unit to reset.
Be sure you AC outlet breaker has not tripped.
could also be the TV fuse or power supply PCB.
You should be sure to put a good surge protector in line with this TV as these constant surges are going to severely shorten the life of the unit.
Jul 24, 2014 | Televison & Video
We had a thunderstorm last night, and the power went off and came back on a couple of times and now our Tv isn't working. The green power light stays on, but there is no picture on the screen. We...
The tv Tuner signal board it is shorted and dead.That the board where the tv incomming broadcasting signal cable plug into it.U have some basic mechanical skills like take things aparts and putting it back together.Yes?Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Aug 12, 2011 | Norcent Technologies LT-3250/LT-3251 32...
My KDL-52Z5100 has just died. The TV power/standby light blinks 3 times in a row. If the power switch is pressed, the backlight and BRAVIA come on for a few seconds, then it shuts down again. Lightning hit...
The surge could easily come in through the antenna wire to the the TV.
Did you try unplugging it for about an hour to let it reset itself?
If it still does not work, then you will need to do in-depth troubleshooting, starting at the power supply module first.
Please read my guides to get more understanding how the TV works.
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jul 03, 2011 | Sony KDL-52Z5100 LCD TV
After a lightening strick next door last night, my AStar 27" TFT LCDTV Model LTV-2701 will not power up. The Direct TV receiver and the DVD recorder on the same surge protector are fine. Saw the...
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where.If otherwise, Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this will help in solving the problem.....
Jun 25, 2011 | Televison & Video
Lightning struck nearby last night and our VISIO HD TV will not turn on. The stand-by light comes on, but that is all. Is there hope for it? Is there a chance it can be repaired? It was new in Feb....
Hope this will helpout in solving the problem....
May 17, 2011 | Vizio Televison & Video
Television won't turn on, either by remote or pushing button on t.v. itself. light just flashes. worked fine last night
The status light flashes to signal that the power source is in protected mode. This mode has been activated by the protection system of the power source this morning, when you tried for the first time to start it. It has been activated because during the night a part inside the tv has failed and has started to act as a short.
The only way to fix that is to open the tv, test the power source, identify the power rail that is down and has triggered the protection system, follow the rail and test all components that are powered by it till you find the failed one then replace it or the whole board on which is situated.
To do this requires electronics experience, if you don't have it then call someone who has it. Or take the tv to a repair shop.
Dec 29, 2010 | Proscan 32LA25Q 32 in. LCD TV
My HP 10s Scientific calculator does not switch on what could be the problem, is it maby because the calculator was left in a drawer and now the batery ran flat hou can I charge it on the solar power...
You can't charge the calculator off the solar power panel. The solar power panel merely conserves battery power when using the calculator in a bright environment. Try putting in a new battery and see whether the calculator turns on.
Aug 25, 2010 | HP 10s Scientific Calculator
I cannot get the TV to turn on even thought it worked well last night. The red light is on but it will not turn to green/blue.
Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this helpout.....
Aug 03, 2010 | Televison & Video
Trouble turning tv on.
U know basic electronics and soldering?Go to the power supply board.Searches all around the power supply board for these capacitors it have electrolite gases leakages capaciotors.These capacitors usally or alway have bulges up or puff up on it top.Replaced these capacitors will return ur power function back to normal.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Apr 27, 2010 | Samsung LN40B750 40 in. LCD HDTV
TV turns off when you change the channel
sounds like a power fault, prob just weak capacitors if you can change them it would not cost a lot to replace them, when you change channel it draws more power and if its at its limit it will turn off as the capacitors cannot take it. few £'s or $s to get the replacement capacitors, you will probably see the blown capacitors on the power board as the will not have flat tops they will be rounded, change them same for same i.e 16v 330 for same 105c type would be best. it will say this on the capacitor.
May 27, 2017 | RCA TruFlat 27F520T 27" TV
Panasonic PT-43LC14 43" Rear Projection HDTV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
