Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Intermittent power I am away from my set at the moment so i can't check the model # it is a 55 in HD ready rear projection. The problem is no power. when I first plugged it in it came on & had full raster but none of the controls on the front of the set worked. after unplugging it & replugging it has not came back on. Any ideas on where I should start? I am lost. Thanks
  • hosed1 Feb 05, 2008
    Thanks, But I need a little more detail. I would like to know which circuit controls the main switching on the set. Like on an older Toshiba (ICA01). This chassis has a totally different layout.
    Thanks
    Problem Solver:
  • 40 Answers
Usually there will be a blink code on the front LED that you can use to diagnose the problem....if there is no Led lit.....pwr supply...if led is lit....deflection board..............
Posted on Feb 03, 2008
If we have an hd-ready television and we have dishnetwork hd does their box make our tv hd? Or do we have to have their magical piece of equipment to make our television hd?or tv is the WS-55315 model.
You need a HD box connected to the DTV input on the back of the set (it is marked 1080) This set has only one HD input for this---HD ready means it will work only with a box (some newer sets have a HD tuner built into them and for basic HD channels do not need a box).
SD TECH
Jul 11, 2010 | Mitsubishi WS-55315 55" Rear Projection...
I'm looking a HD cable.
This set may have a DTV cable. You probably have an HDMI cable on your box. You can get a DTV to HDMI adaptor.
Nov 23, 2009 | Philips 55PW9363 55" Rear Projection...
Phillips 55 inch rear projection tv red convergence screwed up
Install the DPTV305_DPTV345 Chassis convergence repair kit. You can get the kit at the following link and it contains the parts plus instructions on CD.
http://www.tvrepairworld.com/
Jul 25, 2009 | Philips 60PP9202 60" Rear Projection...
HD UPGRADE MITSUBISHI WS-55315
Check your manual, I have the same set and you need a
WD 5000 HD upgrade panel, I believe.
This TV is HD upgradeable, it is NOT HD ready, like you have
been told by other responder......
Jan 22, 2009 | Mitsubishi WS-55315 55" Rear Projection...
I have HCL5515W tv. Want to convert to HD tv.
Not without the box, HDTV didnt really made an appearance except in the past 5 years
Jan 18, 2009 | Samsung HCL5515W 55" Rear Projection...
I have a red and blue shadow in my picture
IT sounds like it needs to be degaused.
Before checking this, check for speakers placed by the set. this will cause it too.
The best way to avoid this situation is
  1. Don't place unshielded speakers near the set.
  2. Don't move the set while it is turned on.
The coil that is used is about $50 and can sometimes be found at industrial electronics stores. It's called a degausing coil. most TVs have a version of this built in and mutiple power on/off/ons may fix it, but don't hold your breath...
The trick is to turn the coil on with it right up to the screen. Move the coil in a big circular motion parallel to the screen as you S-L-O-W-L-Y move away from the screen. when you are as far away as you can get [about ten feet] turn the coil off. Caution. KEEP HARD DRIVES, CREDIT CARDS, AND FLOPPY DRIVES AWAY from the energized coil!
Good luck
Ken
Aug 15, 2008 | Akai PT5598HD 55" Rear Projection...
Turned off and now won't turn back on
Can you verify that 55PW9363 is the actual model number of your set? Also does the power indicator light up when you press power? Please respond to this same post
Jul 01, 2008 | Philips 55PW9363 55" Rear Projection...
Clicking noise
its the surge protector - plug it into the wall to see if that takes care of it and then put a UPS or uninterupted power supply on it so it has protection.
Feb 28, 2008 | Philips 55PW9363 55" Rear Projection...
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
