Question about GPS
GPS hookup on a snowmobile.
The snowmobile has no battery. I have found 12v but its AC. Ineed to convert it to DC. for the GPS to work. Al
  • Anonymous Jan 17, 2009
    i have the nextar x4-t and am wondering if i can download snowmobile trails to another sd card. and if so, what file format do i need for the gps to read it. also, does anyone know where i can download the trails?, thanks.
  • 29 Answers
Take the insides out of an old wall-wart, those black things that hang from outlets. They take the 12 volts AC from the transformer and pass it through diodes and filter it with a capacitor. And there you have a feed wire too.
Posted on Jan 31, 2008
Why would my 120 converter not keep my batteries charged while plugged in?
If you are referring to a 12V DC - to -120V AC converter, then the answer is obvious. The converter makes the AC from the DC voltage provided by the batteries. You cannot charge a DC battery with an AC source. Additionally, even if you could, the resulting charge would be less than the draw taken from the battery (physics - loss from heat). Also, there wouldn't be enough power left over to do anything with.
Nov 23, 2014 | Cars & Trucks
Can i connect my tele in mt caravan on 12v
Yes. Either by using a 12v dc tv, or if it uses 120v/240v ac by using an inverter on the 12v dc supply which ups the voltage and converts to ac.
Jul 14, 2011 | Televison & Video
I bought my drill from the US and as we know its 110v AC there, i want to make the charger into a car charger 12v DC. is there any way of doin this and if so can someone please help me
You cannot convert an AC charger into a DC charger for a cordless tool, no matter what you do. The charger has a transformer that operates only on an AC current only. You did not state what battery your drill has, but a range of chargers are available for cordless tools, as long as the batteries are 12v or less. Speak to your hardware outlet.
May 03, 2011 | Vacuums
I have a polaris 2009 600 IQ shift snowmobile that I would like to put a 12 volt dc plug on for my GPS. I got a outlet from polaris and I found the acc plug on the sled.I do not have electric start so...
I Have a 2010 Polaris Shift (with No electric start) and over the clutch on the left side (sitting on the sled) is a bunch of plugs, one with 4 wires.. and a longer plug with even more wires.... The One with 4 wires has a Yellow wire that produces about 10V AC, which is a good tap for a electric shield. The Longer plug has a solid Red wire which produces around 13.5V DC, which is a good tap for your 12V Plug. Connect your positive to the red wire and your ground to the brown wire (also your ground can be securely attached to your frame by a nut located just above your plugs on the frame) and your good to go!.. with the 2010 shift you don't need a battery for it to produce DC voltage.
Nov 04, 2010 | Polaris ATV
Ineed an ac charger magelan gps model 1412
Hi!
Incredibly, the AC charger for your GPS is incredibly inexpensive.
I found a link where you can purchase them for a very good price!
http://www.amazon.com/gp/offer-listing/B0026Y4O1O/ref=pd_sxp_olp
Hope this helps.
Aug 22, 2010 | Magellan Car Charger Power Adapter Cord...
I will like to know if one can get an inverter that can server for about 20hrs or so
You haven't supplied enough information. An inverter only converts 12V DC to 115V AC. There are some battery packs with inverters, but that's not what you asked about. The time it "serves" is dependent on the load being connected and the battery(s) that the inverter is being supplied from. Go to a web site such as :http://www.donrowe.com/inverters/inverter_faq.html#hookup
You can learn a lot about inverters here.
Jun 21, 2010 | Whistler Power Inverter
Honda Accord 1989 part that converts ac to dc
The alternator.
It should produce 13.5-14.6 volts DC when charging a 12V battery
Jan 07, 2009 | 1989 Honda Accord 4 Door
Garmin 1412, wont run on battery power, DC only. Need info on maybe a full reset whether to return as defective
I found there are select 120v AC adapters that will work on Magellan GPS. When a working 120v or 12v adapter to mini USB adapter is plugged into the unit, the battery bars will be 'scrolling' and therefore charging.
When your adapter, or even USB cable from your computer, is plugged into the GPS unit, and the battery goes to FULL, it is NOT CHARGING. The battery bars must be SCROLLING for the unit to charge. In this case, get a different adapter until it works.
Dec 22, 2008 | Magellan RoadMate 1412 Car GPS Receiver
Thermoking
This system uses in conjunction with the transformers a rectifier which converts the High AC current voltage (220V-AC) to a Low AC current voltage (12V-AC) and then the rectifier converts that energy into the D/C current (12V DC). The two diffrent 12V power sources are controlled, operated by a "electric" relay, via a roadside or electric selector switch. DS_TK TECH
Jun 20, 2008 | Classic Minicooler Mini Cooler / Warmer...
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
