Question about Tomtom GO 700 GPS Receiver
Tomtom go 720 won't start up
MY tomtom go 720 was working fine. Now, when I power it on, I get a picture of the tomtom unit on a green and white background, and then nothing else will happen. I cannot connect it to my computer. I have tried resetting with a paper clip, and this hasn't helped. Any ideas?
  • Cath271 Jan 31, 2008
    This hasn't worked. Under my computer, when I click on the removable drives, it says 'insert disk into drive x' - I don't think my computer is able to see the Tomtom.
    President:
  • 4,402 Answers
Leave on charge for two hours, then if you have a sd card take the SD card out, hold down the reset button at the back of unit for ten seconds and then the 'on' switch for ten seconds.
STEP 1
Connect your TomTom to your
computer True True (``````````` (``````````` 0 95250 95250 Tomtom go 720 won't start up - clip_image002.gif via USB and open up your Windows Explorer and go to the drive. (It will be listed as TOMTOM (E) or some other drive letter).
Copy the Yellow Folders one by one to your PC. Ideally, save all the folders under a new folder that you name.
You may find that the folder ttntools and gns may not be copied. This is o.k. if they aren't.
STEP 2
Format your Tomtom via MY Computer.
STEP 3
Copy the Yellow Folders from the
backup True True (``````````` (``````````` 0 95250 95250 clip_image002.gif you made in STEP 1 back to the TomTom.
STEP 4
Open TomTom Home
Click on Upate Now.
Install the latest update onto your TomTom.
Once installed, switch your TomTom off, then disconnect if from the PC.
Thats it. From now on, make a full backup using TomTom Home prior to any updates.
Also note, that copying all the files will take some time.
Posted on Jan 31, 2008
  • Cary Farah
    Cary Farah Feb 01, 2008
    If you can, the best test is to try your player with another PC, to see if you still have the problem. This localises whether the problem is with the PC (most likely the USB) or the player. See the link below (search on "connection problems") for a lot more troubleshooting on this.
    go to my computer > click on hardware tab >
    click on device manager button > in the is next screen on the bottom should have>>universal serial bus controllers
    (write these down just in case it cant find them)
    right click on them and uninstall, reboot let windows reinstall them
    Also told Microsoft hotfix causes this problem try uninstalling the last hotfixIf that doesn't fix it try the USB cable
GO 720 GPS Receiver: Haven't used my 720 for 6 months, have had it plug...
It will do that, diconnect your unit and try switching it on, have you downloaded tomtom home 2 to your computer? as you need this to manage your unit.
May 06, 2010 | Tomtom GO 720 GPS Receiver
My computer will not acknowledge my tomtom go 720 is plugged in to usb connector power light is on in charging cradle but computer says not connected
I had the same problem. I tried uninstalling software and re-installing it. That did not help. I reset my TomTom Go 720 with the reset button on the bottom of the unit. The computer then recognized my TomTom.
Aug 30, 2009 | Tomtom GO 720 GPS Receiver
Tomtom 720 will not turn on even after pressing reset button
hook it to your usb cable to your for a few hours and then try and start it. first with the power button, it that fails try the hard reset..if neither those work, download tomtom home. follow the directions and tomtom home should be able to repair it unless you have internal problems, like a bad usb port on the gps. bill
Aug 18, 2009 | Tomtom GO 720 GPS Receiver
Certain functions not working? tomtom go 720
This happens with my cell phone all the time too, just have to go to manage phones and delete my phone then re-configure it and that seems to fix it for a while at least. Also night & day always has to be done manually, it won't change automatically that i'm aware of. I'm pretty sure i had to download some of the free voices from the TomTom Home or website initially, in any case i prefer to use my TomTom 720 without voice as becomes annoying listening all day nag nag nag blah blah blah.
Aug 10, 2009 | Tomtom GO 720 GPS Receiver
Screen deactivated & a red circle with an 'X' flashing
First turn your firewall off (if you have one). You need to go into your 720 with the TomTom Home software and erase the downloaded software (with the remove items from my device) and reset the device (little reset button under the unit keep it pressed for 5 seconds), place it back in the cradle and restart your computer and than restart the 720 , bring the TomTom Home program up, and when the TomTom Home software in your computer restarts and detects the 720 it will tell you that you need to update the application, if it doesn't than you force the update by going to the add maps option, select items on my computer, select applications and press the add button, when done, go back and to device (option in top of your screen) and select disconnect device, restart your 720 and it should be back to life with the upgraded software.
Aug 01, 2009 | Tomtom Go 730 GPS
Doesn' t turn on
1. Connect the TomTom to the USB for power (green light should be on).
2. Hit the reset button on the bottom of the device - you should feel it depress slightly.
3. Press firmly and hold the power button and count to 10.
5. Try this a couple of times if it doesn't work the first time.
Even if your battery is ****, the power connection has a pass-through, so you can still use the device as long as its connected to the charger.
Dec 19, 2008 | Tomtom GO 720 GPS Receiver
TomTom Go720 shuts off spontaneously
tomtom GO-720 will not power back on after leaving on top of refrig off for the past two days now?
May 17, 2008 | Tomtom GO 720 GPS Receiver
Downloading Free Maps for TomTom GO 720
I want dowloading free maps for tom tom go 720
Apr 02, 2008 | Tomtom GO 720 GPS Receiver
Sat nav
STEP 1
Connect your TomTom to your computer via USB and open up your Windows Explorer and go to the drive. (It will be listed as TOMTOM (E) or some other drive letter).
STEP 2
STEP 3
Copy the Yellow Folders from the backup you made in STEP 1 back to the TomTom.
STEP 4
Open TomTom Home
Click on Upate Now.
Jan 20, 2008 | Tomtom GO 700 GPS Receiver
Tomtom GO 700 GPS Receiver Logo
115 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
