Question about Motorola Mobility SLVR L7 Cellular Phone
Powering on bluetooth function on the phone
I started having trouble with my bluetooth, so I powered off the bluetooth function on my SLVR. Now I can't get it to turn back on. It just says "Bluetooth powering on..." and never actually turns on. I finally have to just hit cancel. Any suggestions?
  • kttm Jan 08, 2009
    i have the exact same problem! and when it was turned on i would have to disconnect it or something when it was paired up with another device and busy?
    i dont know im not good at phones ):
Ahh i just fixed mine, try turning your phone on and off and then trying agan
it worked for me and good luck
Posted on Jan 08, 2009
Try updating your firmware...if already uptodate...deactivate your phone, activate it again while pressing # and *...you will see the bootloader, now use the motorola update software inorder to reinstall your phone ;) just follow their instructions ;)
Posted on Feb 06, 2008
Plantronics k100 I have no volume.the only thing I hear is call ended.
One possibility: The K100 needs to be re-paired to your phone. When powering on the K100 it searches for the cell phone so you want to make sure your phone is in pairing mode and no other bluetooth device is interfering with the procedure so the phone within range can be connected by tapping the Multi-Function button.
Follow the link to the Plantronics K100 User's Guide for more help and instructions.
Good luck from Headsets Direct!
Sep 25, 2011 | Plantronics K100 Bluetooth Headset
Having trouble pairing phone with Blue Ant ST3
  1. If the Supertooth 3 is on, turn it off by holding down the green Multi-Function button for about 5 seconds (until you hear a voice announce "BlueAnt ST3 powering down").
  2. Hold down "Vol " and the green Multi-Function button until you hear a loud siren/distinctive tone.
  3. The Supertooth 3 will turn on. Hold down the green Multi-Function button for about 5 seconds to turn it off again.
  4. The Supertooth 3 has now been reset: all pairing and other information has been deleted. When you turn the Supertooth 3 back on again it will prompt you to select a language and then go into pairing mode.
You will now need to re-pair your phone with your Supertooth 3.
Apr 17, 2010 | Blueant Supertooth Light Bluetooth Speaker...
Power failure
for powering on
use ur phone charged for sometime wait for some time after charging and press contiously the power bottone of ur phone untill the phone start fully
first it flash a white blank screen and then it start.
after start of phone
Please reset your phone setting without data loss it only reset your settings like as ringtones,skins,etc. as defult settings
U follow it work
Menu>Settings>Initial Setup>Master Reset>"ur secuirty code"
It takes sometime and then it free from this problem
Apr 16, 2010 | Motorola Mobility SLVR L7 Cellular Phone
I have a cellular innovations bluetooth headset model number HFBLU-10K and I am trying to sync it with my iphone and I am having trouble. Is it compatible with the iphone? Lynda
yes, this item is definately compatible to the iphone. try this:
1) turn bluetooth unit completly off
2) make sure bluetooth function in your phone is turned on
3) from the off position hold down the (mfb) or power button as if you were turning on the unit
4) you will see a blue light indicating the btooth is powering on DO NOT LET GO OF BUTTON
5) after blue light you will see red and blue light start to flash together..when you have achieved this state you can let go of the button
6) go to your phones btooth menu and go to where it says add a device or search for devices(terminology different in every phone)
7) your phone should search and find it, it will come up as hfblu-10k.. after it finds it just follow the prompts your phone gives to complete the set-up. FYI password is "0000"
Dec 31, 2008 | Cellular Innovations HFBLU-AX1 Bluetooth...
Bluetooth
well you may need to use another BT headset
Jul 11, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Motorola slvr bluetooth not working
try master resetting the phone...if that does not work take the phone and have it reflash or go to www.modmymoto.com
Jun 15, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Bluetooth problem
You must power cycle your phone and shut off the device you are trying to pair and start over.
Mar 07, 2008 | Motorola Mobility SLVR L7 Cellular Phone
SLVR L7
please goto
menu > setting > initial setup > restore factory setting
and then enter password i.e. (000000) which is by default password if you change the password than enter that password.
Note:-Never try wrong passwords more than three time, It may be risky.
Then the phone will restart.
I think all minor problems with your phone will be eliminated.
Dec 19, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Bluetooth Stereo headphones
according to the specs ive read these are the bluetooth profiles supported by your phone :
Bluetooth® Supported Profiles: dial-up networking, headset, hands-free, file transfer, imaging, printing, JSR-82
copied directly from motorola website........so in other words your phone does not support the bluetooth stereo profile.....so the headset may function as an earpiece but music play wont be possible
Dec 13, 2007 | Motorola Mobility SLVR L7 Cellular Phone
How do I switch on my Bluetooth? Motorola SLVR L6
to find another phone you need to go into what you want to send e.g. the picture, push the options button and scroll to copy then search devices. it will find her phone then
Mar 13, 2007 | Motorola Mobility Earwrap Handsfree For...
Motorola Mobility SLVR L7 Cellular Phone Logo
71 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
