Question about Epson Stylus Photo R340 InkJet Printer
Epson R340 cd tray print problem
Hi wonder if you can help - cd tray went in came out without cd - found it in the back - it was loose pulled it out through vent - but since then when cd tray goes in its rejected saying tray not loading correctly. Any ideas ?
Thanks Phil.
  • 2 more comments
  • elcues Sep 08, 2008
    My Epson R340, ever since new had trouble accepting the cd tray. I took it in for repair and was told there was nothing wrong with it . This is the standard if the repair facility can not fix it.They just want their warranty money.
    After I got it back I still had to load it 2-3 times to get it accept a cd. I called them back and I was told it was me not the printer. I new then I was in for a nightmare until it completly broke .
    Now it is out of warranty and just keeps spitting the cd back out. It has always went two clicks backward and the tray just sat there . Then the error message would pop up tray loaded incorrectly frload and press start.
    Then it would usually work after one or two trys.
    NOW NO WORK AT ALL NEED HELP for HOW TO FIX.
    THANK YOU; EDW.L.
  • wardB Sep 15, 2008
    I also have the same problem with trying to print on CD's/DVD Interestingly I also have a R280 with the exact same problem. I usually have to reposition the tray 2 or 3 times before it will feed correctly. Often the print head will traverse before the tray positions itself creating a noise and leaving residual ink on the front edge of the CD tray. If I don't immedaitely clean the front edge of the tray, the CD will have blotches of ink all over it.
    I am very frustrated and have not been able to find out why
  • Anonymous Oct 22, 2008
    Cd tray rejects with Black marks all over it
  • jlsmith12 Jan 26, 2009
    I have a Epson R340 that I have had for over a one yr.an I have the same problem with the CD/DVD feed tray.it takes a while for the feed tray to load.I have talk to the Epson Technial support people.an the know nothing.about how to fix it.I think we should all git togather an report this to the BBB.that the Epson R340 Printer has a problem an Epson cannot an will not fix it.
    JAMES
    President:
  • 2,351 Answers
I would like to print direct to a DVD and a CD on a epson stylus
download new drivers for the R340 andthere will also be printing software attached to the drivers
Jan 02, 2010 | Epson Stylus R340 InkJet Photo Printer
I am trying to install a printer on my computer, but I cant find the cd. How can I do it without? I have an epson stylus photo R340.
Hi
Go to support.epson.com and select printer model under printers then inkjet then go o drivers and support then download the driver for your computer.
Hope this helps
Jan 02, 2009 | Epson Stylus Photo R340 InkJet Printer
Epson 1400 simply pulls blank paper through when I try to print
I've had the same problem. Drives ya nuts. Found that error said dvd/vcr release something or other on the epson print monitor. In any case, I found that if the front door isn't securely closed. (the front door you open to insert the dvd thingie, the paper will just feed or not feed at all. Once the door is closed on the front, the feed works fine again.
Smles,
Writenright@aol.com
Dec 14, 2008 | Epson Stylus 1400 InkJet Photo Printer
I cannot get my epson stylus phot R340 to print cd covers properly - it is loaded but prints the wrong area
under the printer settings pick tray 2 then pull down the list select cd/dvd, should do it, regards mark
Jul 10, 2008 | Epson RX620 All-In-One InkJet Photo...
Epson R340 not loading ultra premium glossy photo paper correctly
I have several Epson printers and it would seem this is common, I am on my fourth replacement printer, Epson keeps shipping them.
Mar 08, 2008 | Epson Stylus Photo R340 InkJet Printer
Mac OS 10.5 Leopard
I had the same problem with an Epson R340 printer and Epson Print CD software after installing Leopard.  Here's what I did.  Go to System Preferences.  Select Print & Fax.  Select the "+" box on the lower left part of the screen.  Select Epson Printer  -- USB and click "Add" and "continue" in the box that comes up (if it does). Now see if Epson Print CD will print to a CD.  If it does, great.  You can now actually go back to System Preferences and Print & Fax and delete the printer you just added by clicking on the "-" box and Epson Print CD will still work.  Now I found another problem with printing. The CD printing is now off center to the right and down, so in Epson Print CD program you have to click on print and from the print screen click on "Position Adjustment" in the bottom left corner.  I've found the perfect position is 3.5 mm up and 3.5 mm left to make everything print perfectly.  Good luck.
Nov 08, 2007 | Epson Stylus Photo R340 InkJet Printer
Cd tray not feeding
I had the same problem. My printer was sitting too far back in the cabinet and the cd tray was hitting the back wall when it was pulling it throuh. I moved the printer forward and the obstruction in the back was no longer an issue. It started printing all cd's just fine.
Jul 17, 2007 | Epson Stylus Photo R220 InkJet Printer
Epson stylus photo r340 paper feeder
the friction feed roll might be dirty from paper lint, ink glazed or it might have something stuck in it ( a piece of paper from a jam etc.)
Jan 29, 2007 | Epson Stylus Photo R340 InkJet Printer
Epson Stylus Photo R340 InkJet Printer Logo
555 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
