Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Please help!!!! i am trying to install xp pro on vista. everything in the bios is enabled.when i boot from cd it loads right up as if there is no cd in there. and if i go into once the pc is on the install xp is grayed out. please help me!!!!
  • 2 more comments
  • kmitchell Jan 31, 2008
    the options that i have in the boot is floppy drive, usb flash,internal hard disk drive, internal optical drive, and network. i am not sure what order they should go in
    OMG!!! thank you sooo sooo sooo much. I feel so releaved now. You have no idea how much you have helped me out. thanks a bunch
  • Anonymous Aug 30, 2008
    HOW TO UPGRADE XP TO VISTA
  • Goran Veletic May 11, 2010
    Rearagne your boot order in BIOS.
    Sergeant:
  • 201 Answers
Hey there kmitchell, you will need to enter the bios setup once more. Look for the boot menu option or the boot seqence option. set the cd as the primary boot and the hardrive as the secondary. Save changes and exit. Your problem should be solved . Good Luck!
Posted on Jan 31, 2008
  • Devocap
    Devocap Jan 31, 2008
    Hey there kmitchell, internal optical drive first, internal harddrive second. Good Luck!
    President:
  • 4,402 Answers
Go into bios and change the boot order so that the cdrom is first.
I can't load win xp
check the hard disk option in bios or load bios setup default then check
Aug 25, 2009 | Asrock P4I45GV R5 Motherboard
To install xp with vista in compaq presario cq45 207tu
Even if you manage to install Windows XP, you will not find the drivers for sound/video because this operating system is not preferred by the manufacturer.
Hope this helps. Thanks.
Jul 22, 2009 | Computers & Internet
NEED WIZ"S HELP- CANT BOOT XP OR VISTA CD FROM DVD DRIVE
I'll give a whack at this problem. I think the previous person meant blank drive NOT black drive (that doesn't make sense to me).
I would follow the previous persons in going to BIOS and making sure the first boot device is CDROM. My question to you is whether you've already done this or whether you need assistance with this process. If so, please tell me what computer model you have.
Dman
Jan 08, 2009 | Microsoft Windows Vista Ultimate Edition
NEED WIZ HELP- UNABLE TO BOOT FROM XP OR VISTA FROM DVD DRIVE
first you must check your XP/Vista cd if it is bootable then open the bios setting change the first boot to CD ROM save and exit the bios insert CD wait for a second if the CD is BOOTABLE if so then follow the instructions of formating drive. But before you do that you must be sure that you have all the driver need to you PC for security you must use the black drive then install the XP OS.
Jan 07, 2009 | ASUS A8N-VM CSM (00610839133826)...
Dell xps 600 windows booting problem
You would probably do right to reinstall Windows. The bios handed off to Windows long before the splash screen comes up. It is probably a faulty driver or corrupt registry entry. If it was me I would reload Windows
Dec 01, 2008 | Dell XPS™ 600 PC Desktop
I want to rmove Vista from Toshiba pro l40 laptop and replace with xp pro butif I try to boot from xp pro cd it eventually gives me blue error screen. How can I remove Vista?
It is not recommended because everything that is Vista Compatable, isn't XP compatable. However, if you are sure that you want to remove Vista, look up UBCD and download it to an ISO. Then enable boot from CDROM first. Within that CD will give you options of removing an operating system what-so-ever by the use of A Hard Disk "WIPING"(formatting) tool. Good Luck
Mar 14, 2008 | Computers & Internet
Install xp in compaq presario c700
Dear sir, I purchased a new laptop compaq presario c700. When I tried to install os it is booting from cd but it is not recognising harddisk. I checked in BIOS but I didn't find the option where to find harddisk. So please provivide the solution
Dec 07, 2007 | Compaq Presario C700T Notebook
Unable to install Win XP on Toshiba portege R500
make the SATA disk mode from ACHI to Compatibility in the BIOS. once its done without any problem you can make partitions, installa Windows XP. hope this helped you. thanks.
Ammar.
Oct 02, 2007 | Toshiba Portege S100-S1133 Notebook
How to install XP on pre loaded Vista in HP Laptop what can i do
make sure you have taken all the backup of your data from your system bcoz xp will not overwrite on vista you need to be format your drive which will erase your data. for installing windowx xp you need win xp cd as well as all the driver for win xp bcoz the driver is diffrent for vista and win xp . if you have windows xp bootable cd just place in your cd-rom or in dvd rom .and go to bios setup (bios setup is just press the del button from your keyboard or f2 key it is display whrn you start your system )and change the booting sequnce from hdd to cd rom when it will boot from cd one massage will come press any key to continue just press the space bar and follow the setup instruction . if you need more help let me know bye
Sep 28, 2007 | Microsoft Windows XP Professional With...
I bought a cheap Compaq laptop that came with Vista Home Premium. The speed was horrendous! Anyway, I received the same no hard drive found error. To solve the problem, I went into the system config (BIOS) by pressing F10 on startup, and turned off SATA hard drive support (its supposed to make the hard drive run faster), I rebooted, inserted my Win XP Pro disc and viola, it detected the hard drive. I would say that the laptop runs a good 40% faster than before. Vista is a big no no when it comes to low end laptops built for word processing and internet browsing.
Aug 19, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
35 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
