Question about HP PSC 2210 All-In-One InkJet Printer
Check cartridge printer not working, only says check cartridge.
    Novelist:
  • 188 Answers
Please click on the web link given below and perform the steps as given in the web page to fix the issue.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00042885&cc=us&lc=en&dlc=en&product=79499
This should fix the issue.
Have a great day!
Posted on Mar 24, 2008
I have a Lexmark P4350 printer. Just bought new manufactured ink cartridges. The black cartridge works fine. The tricolor cartridge won't print at all - I removed the tape, cleaned both the printer and the...
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
turn on the lid of the printer and then remove the cartridge from the printer head.
Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Dec 16, 2010 | Lexmark P4350 All-In-One InkJet Printer
All together not working. Says: "Ink empty" But I
Turn on the lid of the printer and then remove the cartridge from the printer head.
Dec 15, 2010 | Brother MFC 420CN All-In-One InkJet...
All ink is work the black wont work
It seems simple enough, but this is one of the most effective ways of fixing printer cartridge error. Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Oct 26, 2010 | Canon PIXMA iP3500 Printer
Printer is stating incompatible ink cartridge. I am not able to print. Had this printer for about 1 yr.
printer will show this error message when the cartridges are not getting properly detected by your printer or there is another problem like if you are using refilled ink cartridges or if your printer is not working fine as because its hardware functionality is not working fine
so in order to check that which will be the reason try to clean the copper contacts of the cartridges first and then if that will not work then use a new set of ink cartridges and if those new cartridges will work fine then the previous cartridges are faulty and if that new cartridges will not work then the printer is not working fine so you must service ur printer
try these steps in order to resolve the issue..........
Sep 20, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
CHECK PRINTER CARTRIDGE SHOWS UP EVERY TIME I TRY TO TEST? HAVE TRIED NEW CARTRIDGES AND OTHER CARTRIDGES KNOWN TO BE WORKING BUT STILL GET CHECK PRINTER CARTRIDGE?
Hello sir; Make sure the cartridge you buy is OEM not refurbish, check all the cartridge install right, if still have problem that's means cartridge senser defect.
Aug 05, 2009 | HP Office Equipment & Supplies
Need to take new cartridge back out. It won't budge.
  1. Check cartridge make sure you removed tape covering electrical contacts. do not touch contacts with fingers or metal objects.
  2. Check printer contacts bake sure there is no tape paper or obstruction blocking contacts.
  3. Replace cartridge then turn printer on.
  4. Not working remove cartridge.
  5. using a pencil eraser gently clean contacts with eraser both printer & cartridge.
  6. wipe residue off with a non static lent free dry cloth.
  7. Repeat #3
  8. Still not working try new cartridge the one you have may be bad.
  9. Still not working contact be & we will try something else.
Please rate if fixed or helped. Thank you. Good Luck! I'll standby if you need more help.
Mar 07, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Remove and check cartridge
Are you using new genuine HP cartridges?
Sometimes refilled cartridges will not work.
Make sure that the cartridge is sitted correctly in the cradle.
You can try reinstalling the cartridges.
Double check if the cartridge are installed in the correct cradle.
You can also try to remove power from the printer.
Frist remove both cartridges, unplug printer.
Wait at least 15 minutes before plugging in the printer.
Turn printer on.
Reinstall cartridges.
Jan 16, 2009 | HP PSC 2210 All-In-One InkJet Printer
Printer says right cartridge incorrect. I know it's correct.
try cleaning the brown dotted circuit of both printer and cartridge. and then insert both the cartridge 1 by 1 and then check.
or sometimes it shows --replace left cartridge --- but both the cartridges are faulty and so its not working.
hope this helps you.
thanks.
Oct 11, 2008 | Dell 924 All-in-One InkJet Printer
Check print cartridge error
clean the brown dotted circuit of both the cartridge and the printer.and then try.it will work.
Aug 15, 2008 | HP PSC 1210 All-In-One InkJet Printer
Printer does not print
witch u have Cartridge is Tested ok or check with working printer
please check u r cartridge with working printer or check u r printer with tested Ok or working cartridge..
it should be working
if this information is useful for u please Rate me...........
Jul 08, 2008 | HP DeskJet 3740 InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
16 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
