Dell OPTIPLEX GX260/SMT P4 2GHz 512MB 40GBGX260/SMT 2GHz 512MB 40GB PC Desktop Logo
Posted on Jan 31, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Urgent matter forgot password
Hi i have this little problem
no a long time ago my dad put a setup password in his Optiplex GX260
now he cant remember and for some reason the computer kept starting at 4 am in the morning he was mad and until this day i couldnt find why..
in the setup of the bios was an alarm at 4:00 am but we cant access to it because of the of the setup password he forgot....
could someone please tell me how to break the code or override it
its really annoying to unplug the computer every night please help me
Thank you very much
  • Erbian Jan 31, 2008
    well it says that there no auto wake so lets see at 4 am anyway thank you very much for your help
    and besides its not in my room its on my dad..LOL jajaja
    tyvm
Anonymous
Level 2:
  • Expert 43 Answers
  • Posted on Jan 31, 2008
Anonymous
Expert
Level 2:
Answers
43
Questions
Helped
24200
Points
120
Unplug your power source open the case and remove the battery, wait 60s put the battery back and turn on the computer. I think than you will not be waken up and you will be able to access BIOS as well.
  • Anonymous Feb 04, 2008
    Did it wake up :D
  • Anonymous Nov 02, 2011
    For removing Windows Passwords in safety, I highly recommend windows password reset tools. Last week, and then I downloaded it and used it to remove the lost password successfully. You can download one from:http://www.reset-windows-password.com
How to Boot from USB in DELL Optiplex GX260
Hi Junaid
Can you please supply a little more info so that we can try assist you.
With the little info we have to work on maybe I can suggest you need to make a bootable operating system to use in your device connected to your USB port to boot the machine.
Hope this helps
Kind regards
1helpful
Using dual monitors on a Dell Optiplex GX260
You cant.. Unless the nvidia card you added has two video OUTs. Plugging in a aftermarket card causes the motherboard to disable the onboard video..
If your nvidia card has two "outs" then you can use two monitors... most newer nvidia cards support this. sometimes it requires an adaptor, but usually it was included in the box
Need manual and setup guide for dell gx260 optiplex
go to dell.com
put in your model number and download the instruction manual and any driver you are looking for.
3helpful
An old Dell Optiplex gx260 just won't turn on
Possible failures are:
  1. Powersupply failure
  2. Motherboard failure (Check the capacitors for popped ones)
  3. Front I/O Panel
Resolution problems
open your cpu remove the battery on the motherboard restart the pc without battery and refresh the bios by the jumper or a switch present near to the battery.
Change the resolution right click over your desktop blank area click properties and under setting you can adjust screen resolution
3helpful
2answers
Installing a sound card into my Optiplex GX260
Hi
OptiPlex GX260 can be Small Form-Factor, Small Desktop or Small Mini-Tower. Compatibility with PCline 5.1 PCI depends on the profile of the PCI Card and the Profile of your OptiPlex.
GX260 Small Form-Factor is compatible with Low-Profile PCI Cards only. GX260 Small Desktop and Small Mini-Tower are compatible with standard PCI Cards. (Small Mini-Tower however uses a PCI Cage).
Check OptiPlex GX260 Systems User's Guide - http://support.euro.dell.com/support/edocs/systems/opgx260/en/ug/index.htm
From here you visualize the 3 form factors. Also there is info and steps to install PCI cards.
NB:
1. Generally, upmarket PCI cards are standard height. Some manufactures supply a metal piece to allow it to be used in Low-Profile or Standard Profile.
2. Driver software needs to be installed after the hardware is installed.
Mike
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
