Question about Samsung HCN653W 65" Rear Projection Television
Green semi-circle of lines on Samsung 55" HDTV (projection)
I have three or four green lines starting at top left hand corner of screen coming down in a semi-circle and ending at top hright hand corner. These lines drop down about 1/4 of the screen
I believe i have the same problem myself. When my TV is on any of the Component Inputs without my DVD player turned on i usually get the normal green screen. But now that is a dip in the green at the top of the screen from the top left to almost the top right and black pushing down on the dip. Almost like a green curtain was sagging at the top and you can see the black behind it. It does this on every input and distorts every picture you see. The distorted picture has all the green slightly off from where the rest of the picture is and where the dip at the top of the screen is there is somtimes purple instead of black.
I know the basics of how the picture gets onto the screen and its my guess that the Green "gun" for lack of a better term and somhow come loose, or been missaligned to a great extent. I would love to find an answer to this problem, and anyones best guess as to how much a repair man will charge, just so i know the ballpark.
Posted on Feb 01, 2008
I have a Mitsubishi 55"
This set has a convergence problem. You should only need to replace the IC. Part is STK393-110. It sits on the middle board behind the large heatsink. Use a heat transfer compound to ensure repair lasts. If you have no experience soldering (or unsoldering) please use a professional for the work. The traces are fragile and I have fixed many mistakes local DIYers have committed. Goodluck.
Jan 20, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Akai 54 inch PT5492S projection tv
try to degauss the screen....
here is a a little guide on how to do it if your tv doesnt have the option
http://www.wikihow.com/Degauss-a-Computer-Monitor
Dec 29, 2007 | Akai PT5492S 54" Rear Projection...
Distorted picture
You have a convergence problem.On this model you can change the convergence amp board which has the convergence IC's on it making it an easy repair.
Oct 06, 2007 | Samsung HC-P4752W 47" Rear Projection...
My screen has two giant line on it from corner to corner you only can see them on light images on screen and they move up and down
Look for Bad capacitors on the board(FMT) on left hand side up front most of the time this will be your problem they will be swollen or puffed up on top
Dec 19, 2010 | Samsung HLN467W 46" Rear Projection HDTV
Blurry, Multi-Color, Multi-Line
covergence problems and its not adjustable you need work done on the convergence board or a new board and realignment which can be timely.
Nov 01, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Panasonic PT 47WX53 CinemaVision TV
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Mar 21, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Green screen crash
i have a projection tv. It is a a Samsung HDTV 55" widescreen. There is a green curvey lines at top of screen. Can you help?
Jan 20, 2008 | Televison & Video
Problems with green arching lines
yes there is a small black box with 6 controls on it, take off the bottom front of the tv, behind that you should find a black piece of plastic you can remove by taking out 2 more screws. the black box should be in the upper rhs.now i don't remember if the top 3 are the screen controls or the focus controls. the rows should be labled, you are looking for the screen control row. the green control is the middle one. you can try turning down the control till you no longer see the green lines. try adjusting in a dark room, it will be easier to see the lines & when they are gone. if you problem is not solved by trying this, then i agree with your tech & the green tube is bad. good luck.
Oct 23, 2006 | Sony KP-65WV700 65" Rear Projection HDTV
Samsung HCN653W 65" Rear Projection Television Logo
154 people viewed this question
Jerry Greenberg
Jerry Greenberg
