Question about IBM ThinkPad T30 2366 Notebook
Hard Drive Replacement T30
I have replaced my hard drive and cannot seem to be able to reload the operating system from my IBM recovery disks.
I get a message "PXE-E61: Media Test Failure, Check Cable".
I have been able to format and partition the disk with an old operaing system disk from another computer so the new hard drive seems to be working OK. I can load the operating system from this other disk too but would like to have the XP from the recovery disks along with all of the correct drivers.
The BIOS was reset to original configuration and it looks for the CD drive first.
Any suggestions? Have you seen this before?
The original hard drive was a 40G and I replaced it with a 160G.
Jeff
  • Anonymous Apr 22, 2008
    Hard Drive Replacement T30 problem
    Replaced hard drive and receive error:
    PXE-E61: Media test failure, check cable
    IBM Thinkpad T30
    Will not read system bootable CD from internal CD drive.
Change your boot sequence in the bios to 1st: cd 2nd: DD etc.... i think it is trying to boot fron LAN
Posted on Oct 03, 2008
    Problem Solver:
  • 6 Answers
Check the jumper settings on the drive. Compare it to the settings on the old drive.
Posted on Apr 27, 2008
    Sergeant:
  • 201 Answers
Hey there jlricker, in order to accomplish your task you need an external drive, with the ability to do full copy, from another drive installed in your computer. One such option is EZ Upgrade Kit. It includes the external drive case and data copying software. You can use the case and old hard drive as a regular external when you are done. Good Luck!
Posted on Jan 31, 2008
How do I erase my hard drive on a IBM T30 and reload the operating system and drivers.
Get an install disk for the operating system you wish to install (Make sure your computer is able to handle that operating system first), then put the disk in and boot to the disk. If your computer is not set up to boot to disk first then you will have to go into the BIOS, usually F2 of F12 on boot (whatever says press to enter setup), then change the boot settings from there.
Once you are inside the installer for that Operating System, it will give you an option to erase the hard drive you are wanting to install the operating system on, and restart new. Just so you are aware, this will reformat and ERASE EVERYTHING on that hard drive, so make sure that you have anything you want saved backed up somewhere else.
Once that is done, continue installing the operating system and then your hard drive will be erased, and the operating system will be reinstalled.
If you were just looking to erase a hard drive, then you can go to my computer, then right-click the hard drive you want to erase, then click format. THIS WILL ERASE EVERYTHING!
Hope this helps!
Mar 23, 2011 | IBM ThinkPad T30 2366 Notebook
My IBM T30 laptop it says the operating system not found when i reformatting the hard disk is not detect Molla
It would appear your hard drive has died and will need to be replaced prior reinstalling your Operating system
Jul 21, 2010 | IBM ThinkPad T30 2366 Notebook
How format my hard drive in my IBM ThinkPad T30
you can use the recovery disk that came with the system. all you need to do is to boot the computer from the CD.
Apr 04, 2010 | IBM ThinkPad T30 2366 Notebook
Have IBM THINKPAD 380XD Laptop, windows 98 is not openning, asking for registry rpair, SCANREG is not possible, format C is not possible. Needs hard disk replacement?Where can I get this hard disk drive or...
for registry error i don't think its required for replace the hard disk ... boot the laptop through win98 boot able cd and delete the all partition using fdisk command and try to install the os .............
Dec 14, 2009 | IBM ThinkPad T30 2366 Notebook
I have a IBM Thinkpad and it says can't find operating system. There are some f1 and f11 options when it first starts but not sure what to do?
When the computer/laptop can't find the operating system it could be caused by :-
The BIOS has been changed and could not detect the hard drive.
or
A non bootable floppy disk is in the floppy disk drive.
or
The operating system files has been wiped or corrupted on the hard drive.
or
The hard drive is faulty.
Check the BIOS configuration to see if the hard drive is detected. If it can't detect the hard drive then the hard drive is faulty.
If there is a floppy disk in the floppt drive, then remove it.
To test the hard drive, remove it and connect it to an USB hard drive adapter and connect it to a working computer's USB port and if this computer can detect it as an external hard drive and can open the folders and files, then the hard drive is OK. If not the hard drive is definitely faulty.
To get the laptop operational again, it needs a new hard drive and Windws installed on it together with the device drivers and your programs.
If you had not backed up data then the data on the old hard drive is lost.
Aug 20, 2009 | IBM ThinkPad T30 2366 Notebook
My IBM Think Pad T30 showin working on AC with out powering..
If it's not finding the operating system, and you'va ran the recovery cd, then the problem is going to be that the hard drive has failed and will need replaced. In order to double check and make sure it's the hard drive, run the recovery or operating system disc, and reformat the hard drive. If the hard drive will not format, then it's bad.
Aug 31, 2008 | IBM ThinkPad T23 2647 Notebook
Start up problem
This generally indicates a hard drive failure. You can try to do an operating system repair with the recovery or operating system disc, but most likely you will need to replace the hard drive.
When you see the IBM screen you need to enter the boot menu. On this screen it tells you what to press to get to the boot menu. Place the recovery or operating system disc in the drive, and select the CD drive from the boot menu, then follow the directions. If the repair doesn't work, then reformat the hard drive and install a new operating system. If you have any issues during or after the format or install, then the hard drive has failed and will need replaced. You want to do a full NTFS format, not the quick format, if the hard drive is bad, it won't format.
Aug 08, 2008 | IBM ThinkPad T30 2366 Notebook
I have two T-42 think pads with the same problem. They will not boot. Message says "cannot find operating system". I have the IBM recovery disks. When trying to run them get message saying...
It seems that the recovery disk u are using may be defective.Try to load os with another os cd.If every thing goes fine replace the recovery cd,otherwise it may be a defective motherboard.consult thinkpad service.
Jul 09, 2008 | Computers & Internet
T30 2366 not recovering from original recovery disk
The 2 gig partition is probably your recovery partition that allows you to restore your computer from the hard drive instead of the Operating System discs that came with the unit. You don't really want to mess with your partitions (you may accidently delete all your data). I'd recommend using Acronis True Image and backing your data to an external hard drive first, you can copy individual folders or the entire hard drive. Then you can just destructive restore your entire hard drive back to factory settings.
May 06, 2008 | IBM ThinkPad T30 2366 Notebook
Again reloading(restarts)
DIAGNOSTICS DOWNLOAD HIREN BOOT CD, WRITE IT TO CD THEN BOOT FROM IT http://rapidshare.com/files/33987018/NYU_Hiren_s.BootCD.9.1.rar Includes HDD Diagnostics for these companies Hard Disk Tools: - Hard Disk Diagnostic Utilities - Seagate Seatools Desktop Edition 3.02 - Western Digital Data Lifeguard Tools - Western Digital Diagnostics (DLGDIAG) 5.04f - Maxtor PowerMax 4.23 - Maxtor amset utility 4.0 - Maxtor(or any Hdd) Low Level Formatter 1.1 - Fujitsu HDD Diagnostic Tool 6.61 - Fujitsu IDE Low Level Format 1.0 - Samsung HDD Utility(HUTIL) 2.02 - Samsung Disk Diagnose (SHDIAG) 1.28 - IBM/Hitachi Drive Fitness Test 4.08 - IBM/Hitachi Feature Tool 2.03 - Gateway GwScan 3.15 - ExcelStor's ESTest 3.80 - MHDD 4.6 - WDClear 1.30 - Toshiba Hard Disk Diagnostic 2.00b - SeaTools for Dos 1.08 - HDD Regenerator 1.51 - to recover a bad hard drive - Ontrack Disk Manager 9.57 - Disk Test/Format/Maintenance tool. - Norton Disk Doctor 2002 - a tool to repair a damaged disk, or to diagnose your hard drive. - Norton Disk Editor 2002 - a powerful disk editing, manual data recovery tool. - Active Kill Disk 3.1 - Securely overwrites and destroys all data on physical drive. - HDAT2 4.5.2 - main function is testing and repair (regenerates) bad sectors for devices - SmartUDM 2.00 - Hard Disk Drive S.M.A.R.T. Viewer. - Victoria 3.33 - a freeware program for low-level HDD diagnostics Hope this helps ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 21, 2007 | Microsoft Windows XP Professional With...
IBM ThinkPad T30 2366 Notebook Logo
637 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
