Question about Intel Motherboard
Monitor Flickering Hi.. I have an Intel 845GVSR motherboard.. Of late i find a kinda a dark lines goin across my monitor from top to bottom, so can anyone tell me whether it is a problem with ma mother board(i have checked ma monitor at the service center and they said there is no problem), and can you suggest any good solution for this problem..????
  • deepak_14us Jan 31, 2008
    R u sure abt this..?
    Or might there be any prob with the board(i mean the power suplly across the board)..?
    And if it is the board can ya suggest me an appropriate add-in card(i don have any knowledge about this card matters)..!!)..?
    Genius:
  • 1,067 Answers
Bad onbord video card get new video card
Posted on Jan 31, 2008
  • nick helpap
    nick helpap Jan 31, 2008
    no its video card mark me as fix ya buy one and enjoy ok
  • nick helpap
    when u do buy new one disabel the onbord one in bios
Is any displayport have in Intel D865GBF Motherboard
Yes
It has a VGA port for a VGA monitor. The port is BLUE in color, NOT PURPLE.
This is an example of a VGA Cable, and a VGA connector,
http://en.wikipedia.org/wiki/VGA_connector
Note the number of socket holes, and the arrangement of the socket holes.
There are 5 socket holes across the Top row.
There are 5 socket holes across the Middle row.
There are 5 socket holes across the Bottom row.
The Purple connector with 5 socket holes across the Top row, and 4 socket holes across the Bottom row, is NOT it.
Not the VGA connector.
You can connect a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor, IF it has a VGA cable.
[ There is also an adapter that you can plug a flat LCD screen monitor into, and the other side of the adapter plugs into the VGA port, on the back of your computer.
This is if the flat LCD screen monitor has a DVI cable,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
DVI to VGA adapter,
1) http://www.directron.com/dvitovga.html
2) http://www.directron.com/dviadapter.html
Look at the pins on the adapters. Now look at your monitor cable, and the VGA port on the computer. Make sure which adapter you need ]
For additional question please post in a Comment.
Regards,
joecoolvette
Jun 18, 2012 | Intel D865GBF Motherboard
Monitor flickers with lines across screen
screen is going bad which is why its flickering and has the lines across the screen. Theres a board behind the lcd and when that doesn't process the voltage properly it can cause the screen to flicker. White lines across the screen means the screen is going bad. At this point unless your monitor is under warranty, go ahead and replace it.
May 28, 2011 | Norcent Technologies LM-965WA Monitor
My lg m2762d lcd tv has a half millimeter white line across the screen can you tell me whats wrong?
makes a difference where this line is... very top, top, middle, bottom, very bottom? also, is this set new to you, or has it been fine for a while, and just started doing this? does the line stay there when you switch to other inputs? (like a dvd player or a gaming console)? this kinda stuff will help you get an answer that makes sense - good luck
Dec 11, 2010 | LG W2753V PF Flat Panel 27" LCD monitor
I have an Intel 845GVSR motherboard with 2.6GHZ processor, yesterday after i cleaned my PC, I could not able to see any display in Monitor (also in keyboard). I dont even hear the boot beep. I cleaned my...
This is a common problem for everyone. You did the right thing by cleaning the RAM. Check the monitor and cable, test with another monitor if possible. Check with another video card as well. This will solve the problem.
Think this is helpful !
Aug 12, 2010 | Intel D845GVSR Motherboard
Horizontal lines flickering
  1. Mybe VGA driver instalation not compatible with your monitor screen, you must check there are OR if you are use External VGA mybe theyare not compatible with your motherboard system
  2. if not work you must bring your monitor go to service hard,because your computer,because most likely your monitor easy damaged. good luck
Apr 25, 2010 | Microsoft Windows XP Home Edition
Can i use lcd monitors for intel 845gvsr based desktop with pentium 4 processor. Till now I was using LG CRT monitor. Now i want to buy a new LCD monitor and planning for Samsung 18.5" 933SN PLUS LCD...
Yes, this should be possible. Just check the connector behind your graphics card to see if the LCD's cable can fit into it. If not, you can obtain a simple converter to enable you connect your LCD.
All the best
Jan 10, 2010 | Intel Motherboard
MY COMPUTER DOESNT SHOWS ANY DISPLAY .I HAVE INTEL 845GVSR.I WANT TO KNOW HOW TO CHEK THA ITS RESISTORS ARE BUBBLED?IF THEY ARE. THEN HOW TO REPLACE THEM?
Its best to first check if the PC is passing its POST, if it beeps once them thats good, if not the MoBo is faulty, and it is probably easier to get a replacement, if it does pass POST then check your monitor and cables.
Aug 11, 2009 | Intel D845GVSR Motherboard
Monitor goes into stand by when conection to tower is turned on
try a video card connect bottom motherboared!!!!
Oct 09, 2008 | Intel Motherboard
MOTHERBOARD DRIVER
Well it is not the computer that has a problem... It's your monitor, it needs to be checked by a technician to fix those cold solders that causes the flickering on your screen.
Have it repaired then... Fixya me okay..
Feb 11, 2008 | Intel Motherboard
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
