Question about Konica Minolta magicolor 2400 Laser Printer
Toner Leaking I refilled my toner cartridges several months ago and started experiencing leaking toner. After some cleaning and troubleshooting, I decided to replace the two toner cartridges that were leaking with new ones, and the new ones are leaking more than the old ones. Any ideas?
  • Anonymous Mar 06, 2008
    on a Konica Minolta 2400 W printer we tried refilling toner cartridges. The excess toner compartment was full and all three colors started leaking. Now the cartridge rotation is out of sinc and we can't get the cartridges out to replace. Stuck
    Champion:
  • 214 Answers
Are the new ones original toners ? if not, then you have to buy a new original or working toners, because, its not recomended to refill toners, but if you want, then you can refill them only about 1-2 times.
Posted on Feb 01, 2008
How do i fix toner stain on printout and photocopies? please what might be the cause of the dot stains?
There are several reasons for stains on a Laser printer or photocopier
1. Clean all rollers. Fuser; transfer and pickup.
2. Ensure the toner is clean from outside.
3. Hope the Toner is not refilled and Is not leaking.
4. Clean paper path.
Mar 08, 2016 | Office Equipment & Supplies
When I print a page black lines appear on the page making. Its like the toner is leaking or something. I don't know how to fix this issue. I've cleaned the inside of the printer several times and...
The toner is leaking. The toner cartridge has two compartments, one for new toner & another for waste toner. When the waste toner compartment is becoming full to its capacity it starts throwing extra toner outside of it. That is what is called toner leaking. If you can empty the contents of the waste toner compartment, your problem will be solved. One more thing if wiping blade for waste toner is worn out, it also leads to toner leaking.
Aug 02, 2011 | Samsung ML 2151N Laser Printer
Hl3040cn prints a black stripe down the page despite the drum being cleaned as advised by Brother.Peter
Hi
3 issues might be the problem.
1. The toner waste compartment is full. You need to clean the toner waste compartment located in the cartridge itself.
2. Roller drum inside the cartridge have lines normally starts on both ends of the drum. This due to bulky printing. Check and replace this parts inside the toner cartridge. Manual cleaning is not advisable because the result will still the same. If you have only toner cartridge, use the roller drum and replace in place of it.
3. Faulty Toner Cartridge that cause leaking the toner powder. If you purchase remanufactured toner cartridge or you refill the toner cartridge. It tends to worn out the parts. Normally starts as roller drum and follows with the other parts. Replace new original Toner Cartridge. When you refill the toner cartridge, you need to clean the waste compartment as well as it will later be full and overflow.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
May 15, 2011 | Brother HL3040CN Laser Printer
I have the 1522 printer. The toner ran out and I refilled using Chinese toner fron Deal Extreme. Black toner leaked out the right hand side of the toner cartridge messing up printing. I tried refilling...
it sounds like your priming station is full. you would have to spend some money to get it looked at this is not something you want to attempt your self.
Jul 30, 2017 | HP Office Equipment & Supplies
I would not advise you to refill a toner cartridge becausethe toner powder is very fine and you do not want to breath in this tonerpowder. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Mar 25, 2011 | Office Equipment & Supplies
Hp laserjet 1100 toner catridge refill?
Hi follow these steps..
1.Purchase a refill kit for your model of printer. It is important to purchase a refill kit designed for your specific model, since generic refill kits do not work well with HP printers. There are a number of places to buy these kits, but you must make sure you get the right kit for your printer model
2.Take the toner out of the printer and clean it carefully. Over time toner cartridges will accumulate paper dust, dried toner and other debris, and all of this must be cleaned away before the cartridge is refilled.
3.Flip the cover out of the way to expose the developer roller, then use a soft clean cloth to clean the roller. It is important to clean this roller before refilling the cartridge.
4.Make a small hole in the toner cartridge, using the instructions provided in the refill kit. It is important to follow the refill kit instructions carefully, since the toner refill process will vary from model to model.
5.Place the replacement toner in the hopper, then carefully pour it into the HP cartridge. Be careful not to spill any of the toner, and if you do spill the toner be sure to clean it up promptly. Reseal the hole you made after the cartridge has been refilled.
6.Sit the refilled HP cartridge on a clean flat surface and let it remain there for 20-30 minutes. Pick up the cartridge and make sure no toner has leaked out. If you do see any leaks you will need to reseal the hole you made again.
7.Pick up the cartridge and make sure no toner has leaked out. If you do see any leaks you will need to reseal the hole you made again.
Good Luck & cheers:-)
Jun 30, 2010 | HP LaserJet 1100 Printer
Dell 3000cn leaking black toner cartridge
If they all have leaking, I would bet its the fuser causing the issue. It sounds like its not sealing the ink properly, thus it looks like its leaking.
Apr 07, 2010 | Dell 3000cn Laser Printer
Toner on the side of paper when copying
If you are using refilled toner cartridges then your toner cartridge may be leaking or the waste toner tank on the toner cartridge may be leaking. The other cause and more likely is the drum cartridge is leaking toner. I would recommend removing both cartridges. Then hold each 1 at a time over several sheets of clean white paper. Tap on the cartridges and see if any toner falls out of them. These cartridges are normally sealed and should not leak much if any toner. If toner falls out of either cartridge you will need to replace that cartridge.
Good Luck and Thank You for using Fixya.
Mar 27, 2010 | Sharp AL 1631 Copier
Blue toner seems to be leaking, lines across page
is the toner refilled ? if yes you have to buy a new one, you cant refill one toner more then 2-3 times because the cleaning system stops working in some point.
if these streaks are visible in pc drum your drum is damaged and you need to replaced.
the toner not istalled is caused by toner leak, toner contact pins are tirty, you need to clean them. if you remove drum and toners you cans see a 3 reading pins under toner rack.
Jan 23, 2008 | Konica Minolta Magicolor 2530 DL Laser...
HP 4600DN RED CARTRIDGE LEAKING TONER
are you using non refilled genuine HP carts?
Nov 26, 2007 | HP LaserJet 4600dn Color Printer
Konica Minolta magicolor 2400 Laser Printer Logo
407 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
