Question about Canon i9900 InkJet Photo Printer
Canon colors do not match photo
Colors do not match the original and test pages print solid with no lines
  • Anonymous Aug 14, 2008
    I have a i9900 Canon Printer and it is giving me some challenges. I work with a Mac. 10.4.11. Print quality is completley overpowering on Photo paper but it is fine on regular quality (standard) paper. I have been printing with this printer for two years and is only recently that it is acting up. I have downloaded the latest drivers for Mac. and still the same problem. Any suggestions will be appreciated.
    Philip
  • Iuliu Ciupe-Vaida
    Iuliu Ciupe-Vaida May 11, 2010
    Did you set the printer on photo quality? Because most inkjet printers if set on normal or draft mode does not print ok.
    Genius:
  • 3,587 Answers
Hmmm..that sounds like you need to clean the print heads and re calibrate them
Posted on Mar 11, 2008
6ya staff
SOURCE:
My mp610 Canon printer will no longer print email documents (black)- leaves page blank, except for email address (in blue print)., But printer will still print satisfactory color pictures (Photos). B
Get the latest driver from Canon's web site. Then uninstall the printer. Remove the driver from your computer. Use regedit to remove any traces of your printer from your registry. Install the new driver. That should do it.
Jan 10, 2015 | Canon MP610 Photo All-In-One Printer
Canon MG5320 is printing photos only with a purple tint
Try reinstalling your printers software, sounds like printer driver error.
Jan 20, 2013 | Canon PIXMA MG5320 All-in-One Printer
My Xerox Phaser 8560 is not printing the red properly. It comes out more llike a brown. The light blue comes as a teal and bubble gum pink comes out like a light pale plum. Peach comes out as beige. Is...
Solution : Print the Troubleshooting Print Quality Pages and Make Sure the Colors Are Accurate CAUTION: Use of inks other than Genuine Xerox Solid Ink may affect print quality and printer reliability. It is the only ink designed and manufactured under strict quality controls by Xerox for specific use with this printer. The Xerox Warranty, Service Agreements, and Total Satisfaction Guarantee do not cover damage, malfunction, or degradation of performance caused by use of non-Xerox supplies, or the use of Xerox supplies not specified for this printer.
To print the Troubleshooting Print Quality pages:
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Print Quality Problems], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Troubleshooting Print Quality Problems], and then press the [OK] button to print the test pages.
  4. Go through the pages and find the Light Stripes Test page.
    For each color, remove an unused solid ink stick from the printer, and then use the ink stick to make a mark of color next to the corresponding color on the printed page. If the colors do not closely match, that color will need to be purged from the print head. Continue with step 6 if the colors do not closely match.
  5. NOTE: If the colors do closely match, the problem is not related to the printer's hardware. There is no hardware adjustment available on the Control Panel for calibrating individual colors.
  6. Create a document consisting of a full page (100% fill) of the color not printing correctly, or download and use one of the resource files provided in the table below. For example, if cyan ink is actually printing black, create a document that is a solid fill of cyan, or download and open the Cyan fill page provided in the table below.
    IMPORTANT: Make sure to set the Print Quality mode in the print driver to "Standard" and the TekColor Correction to "None" before performing the next step. This will allow the job to purge only the problem color. Other settings may cause the printer to use a percentage of the other ink sticks.
  7. Print approximately 50 - 100 pages of the document, as necessary, until the printed color returns to normal.
IF THAT DOESN'T SOLVE THE PROBLEM TRY THIS: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=156,E=0000000002703198886,K=8233,Sxi=10,Solution=obj(964)
May 27, 2011 | Xerox Phaser 8560N Laser Printer
"Check Color Cartridge" displays even after replacement of cartridge -though I don't think original cartridge was empty- and stops printer from printing. The new cartridge is installed properly, and...
  1. First, check your cartridges. HP cannot guarantee the quality of remanufactured or refilled cartridges.
  2. Second, make sure your paper is not causing the problem. Paper that does not accept ink well can cause your images to smear or bleed. Plain paper is not the best choice for high-density graphics. Click here to see how to pick the best paper for your project .
  3. If the paper is not the problem and you are using genuine HP cartridges, print a clean test to see if the printer and cartridges are functioning properly. Load the printer with clean, plain, white paper and print a clean test page. To see how to print a clean test page, see your printer's User's Guide , or see HP Deskjet Printers - How To Print Internal Tests , or HP All-in-One Product Family - Printing Self-Test Reports .
  4. Evaluate the clean test page. Different printers produce different pages, but you should recognize elements from the examples below on your test page. In general, cartridge and printer problems are indicated by streaks, missing colors, or wrong colors.
    • Examples from a good printer and cartridges (your test page may not look exactly like this): Figure 1: Solid colors that match color dots on cartridge labelc00059224.gif Figure 2: Pattern unbroken, or broken in only a few placesc00059225.gif
      c00059227.gif If your test page looks more like the good examples above than the bad examples shown in the next two sections below, the printer and cartridges are probably not causing the problem. Click here to continue troubleshooting .
    • Examples from a failing printer or cartridges - streaked or broken bars or lines Figure 3: Fading, missing, or streaked bar - low-ink or empty cartridge, clogged nozzles, or electrical problemsc00059228.gif
      Figure 4: Color completely missing (magenta bar missing below)c00290898.gif Figure 5: Lines broken randomly - clogged nozzlesc00059231.gif
      Figure 6: Lines broken in pattern - dirty contacts or other electrical problemsc00059232.gif
      Figure 7: Color completely missing (magenta pattern missing below)c00290899.gif If your test page looks like these examples, you probably have a cartridge that is empty, has clogged nozzles, or dirty contacts. Click here to continue troubleshooting .
    • Examples from a failing printer or cartridges - colors do not match the color dots on the cartridge label (Note: do not compare the test page colors to the colors of the examples on this web page. Your monitor may not display the colors properly). c00059234.gif c00059235.gif If your test page looks like these examples, you probably have a cartridge in which the inks have mixed. Click here to continue troubleshooting .
Oct 26, 2010 | HP OfficeJet V40 All-In-One InkJet Printer
I don't know how to fax
The control panel LCD also provides menus to operate the copy and fax modes independently of a PC. One nice touch: the LCD displays small and large type on the same screen, allowing more information about a print job to show at one time. b.gif 21262659-2-200-dt2.gif
The flash card reader under the control panel means you don't need a PC to print photos.
The MP730, while easy to operate, lacks some of the advanced features you might find on separate printers or faxes. For example, the MP730 can't collate copy jobs. To make more than one collated copy of a multipage document, you have to place the document in the ADF several times. Nor can the MP730 sync fax numbers entered by hand or accessed from within the Windows Address Book (Canon doesn't provide its own fax/address-book software), so you may end up duplicating efforts. Nor does Canon's software create group dials from your address book on your PC or provide a cover sheet. Finally, the MP730 can't forward faxes to another number or hold a fax to send when nighttime low rates kick in, which other multifunctions do.
Still, the MP730 provides plenty of features we do like. Using the menus with the Photo Print mode, you can print a photo contact sheet, pick individual images to print, and set up the printer to copy or print onto high-quality glossy paper. In the Copy mode, menus let you print two reduced originals side by side or print the same image on the same page several times (useful for business cards, name tags, and so on). The fax engine distinguishes voice from fax, sending voice calls to your phone or an answering machine and sending fax calls to the printer or to buffer memory so that you don't have to get a second phone line installed for your fax.
Installing the MP730 software is slow but idiot-proof: You just pop in the CD and follow instructions, which require restarting your PC several times. Canon bundles the MP730 with ScanSoft's OmniPage SE, a lite version of the best optical-character recognition software on the market, and NewSoft's Presto PageManager 6.0, one of the best document-management databases available.
The MultiPass MP730 won't replace top-of-the-line printers and scanners, but its print and scan speeds keep up with other multifunctions' as well as that of most as midrange ink-jet printers and scanners on the market today. In our tests, it printed ordinary text at 6.4 pages per minute and printed CNET's high-resolution test photo in 3.7 minutes. For comparison, the Lexmark X5150 (only $149 but without fax capability or automatic document feeder) prints text at a more common 5.2 pages per minute, and printed our test photo in about 2 minutes. Canon's MP730 scans a page of black in 9.4 seconds and a page of color in 20 seconds; that's seconds faster than the HP PSC 1210. And the Canon makes copies in 18.7 seconds; that's almost twice as fast the HP PSC 1210.
Unfortunately, the MP730 delivers a mixed bag on image quality. When printing, better paper has a big effect. When we printed text on ordinary paper, for instance, it looked grayish instead of black, and a gray shadow haunted the edges of letterforms, while on coated (not glossy) inkjet paper, text popped out in a solid black and looked much cleaner. Our color photo on ordinary paper looked very dotty, had rough transitions between shades, made a blob of detailed areas, printed lines with jagged edges, and mixed inappropriate colors; coated inkjet paper improved detail and let colors appear in the right hues, though much too saturated. And on top-quality glossy paper, textures, shading, and transitions suddenly looked right, and we saw sharp, clear detail.
Grayscale scans on the MP730 when compared with other scans seemed overexposed, losing paler shades of gray along with some detail, while color scans showed accurate colors and fairly good detail despite somewhat grainy textures.
Jan 27, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
A faint line shows up down the middle of the page, when printing a photo
from cnet review of the product
  • Unfortunately, as with the Z1420, fast print speeds come at the cost of print quality with the Z1300. Black text prints, though nicely dark, were beset by obvious jaggedness. The color graphics print had a slightly faded look to it and color blocks showed graininess and faint horizontal striations. Barcode-style patterns were muddled, too. For our tests, we printed color 4x6 photos with the standard black and tricolor cartridges, as Lexmark did not include photo ink tanks with the test unit. The colors were dull, details were hazy, and again, the entire print was marred by graininess and faint horizontal lines. That said, nobody buys a $25 printer to print photos for framing or to create displays for a classroom science project. A $25 printer is a convenience item for occasional reference prints, and as such, the Z1300 does its job.
Inkjet printer quality
(Longer bars indicate better performance)
b.gif Photo b.gif Graphics b.gif Text Canon Pixma iP1800
Good Good Good Lexmark Z1300
Fair Fair Fair Lexmark Z1420
Fair Fair Fair
Sep 15, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Trying to match color between photograph on monitor to printer. OS is Vista.
The only way to get color matching with the solid ink line 8400, 8500, 8550, 8560, 8860. Is to build you own colors with the CMYK sampler printout.
Beware this will print over 50 pages of swatchs showing the mix of CMYK for various colors. Your can then look at the color you want and see how it's made up i.e. 30% 30% 40% yellow gives a orangish color. You can then build these colors and name them in your application.
You will NOT get Panotone color matching with the solid ink series.
Apr 27, 2009 | Xerox Phaser 8560DN Laser Printer
Photo's print with lines through them
Useually if your printing has lines through it it means that the head (where the ink comes out ) is had it & your up for another head. Sorry but useally big bucks I hope it's still under warranty
Oct 25, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Yellow Prints in the other colors
Problem seems to be with your Ink Tank(s) or Printing Head. Replace both of them one by one and retry.
Jun 06, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
C88 / T060 cartridge refilling problem
sounds lke your yellow nozzle not working properly...had same issue on lexmark printer, ended up geting this epson...learnt from my mistakes...perhaps it ran dry? or you left the yellow cartridge out longer than the rest....only you might know what happened
Mar 22, 2008 | Epson Stylus C88 InkJet Photo Printer
Canon i9900 InkJet Photo Printer Logo
129 people viewed this question
Clive
Clive
old marine
old marine
Ekse
