Question about HP DeskJet 845c Printer
Hp Deskjet 845C - Yellow Colour not Printing
the yellow colour and its derivatives (shades of green , orange etc) is not printing on my HP Deskjet 845C. If I try to print text and/or patterns in yellow only, the printer goes through the movements as if it was printing normally, but no ink is transferred to the paper. If I try to print colours containing yellow, e.g. green, then only the blue component in green is printed. Replacing the ink cartridge with a new unit does not improve the situation.
  • 1 more comment
  • Bianca Trinidad May 27, 2008
    Please describe the specifics of your problem below. We'll add
    your post as a comment to dansera's Hp Deskjet 845C - Yellow Colour not Printing problem, and notify you when a new solution is offered.
  • hbear318 Oct 23, 2008
    Simply, the yellow color worked once, then disappeared. The other colors work, but they are not blended well and show evidence of streaking and shadowing. I used an hp17 refilled tri-color cartridge with a fresh date with these results. How do I initiate a test page in order to see the levels?
    Many thanks,
    DB
I found this post to work for me when yellow was not printing on my HP PSC750 after using 2 cartridges: "Well if you want to damage your printer use alcohol. But if you want to make it work then pull the cartridge from the printer and run hot water on a couple of paper towels leaving alot of hot water in the towels. Put some thing under them to keep them from staining your counter top and then set the cartridge down onto the hotwater towel and let the hot water melt away the dry ink and in minutes you may be printing again if this is what it is. Be sure and use a dry paper towel to wipe off the ecess wet before you reinstall the cartridge."
Posted on Sep 05, 2008
Yellow is printing dark muddy colour, tank content same colour.
Has the printer printed a good yellow using this ink tank at all?
Dec 12, 2013 | Brother Office Equipment & Supplies
Help w/ h/p deskjet 3520
hi/....
this is because of the low ink in the catridge. normally the colour catridge contains three colour in it. yellow ,blue and i think one more is pink. so in your case the other colours might have finished. so because of that you are getting only yellow. so please replace the catridge with new one and the problem wil be solved
Jul 15, 2010 | HP DeskJet 3520 InkJet Printer
Yellow not printing properly.
Go to the maintenance section of your printer on your desktop and clean the cartridges
Start - printers or Start - control panel - printers
Also check the level of your ink while you're there
May 08, 2010 | HP Deskjet D2360 InkJet Printer
Hpdeskjet932c quit printing yellow & blue
Just try with replacing the color cartridges may be it is dry.
Sep 24, 2009 | Zebra 110Xi III Plus Thermal Printer
Print colour is off
Sounds like you have cyan and magenta ink but no yellow. (You need yellow to get yellows, greens, reds and orange shades.) First try running the printer utility to clean your ink jets, then run a test print. If this does not work then simply replace the yellow ink cartridge.
Aug 27, 2009 | HP Photosmart D5360 InkJet Printer
My hp deskjet 1280 will not print yellow
Hello, this is Harry from www.BusinessSpread.co.uk.
We had the exact same problem when printing, we used 3 different 78 colour ink cartages and they all said 100% full but did not work. We then had a look at the dates on the box and they were all expired so when buying ink from anywhere even PC world or Curry’s always look at the expiry date.
Today I went to PC world and purchased a new 78 ink which said expires July 2011 and it works perfectly fine.
Regards,
Businessspread.co.uk
May 09, 2009 | HP DeskJet 1280 InkJet Printer
Colour???
HP Deskjet 450 and HP Color Inkjet cp1160 and cp1700 Series Printers - How to Print with Black Ink Only Follow the instructions below to print with black ink only.
NOTE: HP Deskjet printers use all the primary colors, Cyan, Magenta, and Yellow, to create shades of gray when Print in Grayscale is selected in the printer driver and the Black only option is not available or not selected.
  1. Click Start , Settings , and then Printers . In Microsoft® Windows XP, click Start and then Printers and Faxes .
  2. Right-click the printer icon and in Windows 95/98/Me, select Properties . In Windows NT 4.0, select Document Defaults . In Windows 2000/XP, select Printing Preferences .
  3. Select the Color tab.
  4. Select Print in Grayscale .
  5. Select Black only .
    NOTE: If the Black only option is not available, download the latest printer driver from the HP Web site. Click here to go to the HP Support and Drivers page.
  6. Click OK to save the changes and close the window.
  7. Print the desired document or graphic.
Oct 25, 2007 | HP DeskJet 450Ci InkJet Printer
HP DeskJet 845c Printer Logo
709 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
