Question about Intel Motherboard
Problem with my system
I bought a computer 4 weeks back in that system there is a problem that is
mouse gets hags and later on display goes so i will restart again
  • 152 Answers
My friend had the same problem... he uses a usb mouse... he unplugs the mouse and then plugs it again... that helped him.... but he couldnt solve the problem fully.,...
Posted on Jan 31, 2008
Cursor Jumping Around
****a piece of Scotch tape over a mouse's laser, might make it work perfectly******
***some optical mouse's need a mouse pad and some work
on any surface.***
i use a lot of computers that have mouse's that i have to
list it slightly and let them ride on a finger when they are
off the mouse pad.
a few weeks ago, my good mouse finally frayed its cord and i
had to start using one of my redundant mouse's that needs a
mouse pad.
i noticed immediately that it could work almost normally if
i lifted it 1/4 inch off the table.
I'm not going to deal with this like that though..
i speculated that it must be because the laser sensor is too
sensitive..( since it works better from farther away....)
i wanted to try to put a piece of scotch tape over it to
act as a diffuser to make it less sensitive, but i was too
busy. lol. so like a month later . i finally tried the tape
idea, and it works perfectly!!!. dam
if you get an optical mouse that goes crazy without a mouse
pad, you should try this
Dec 14, 2013 | SteelSeries Ikari High Performance Laser...
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
Blank screen
It Could be because your laptop is infected with Virus . Due to Virus your Explorer.exe File was corrupted. If now computer is all right after restoring then I'll suggest you to use Good Antivirus Program and regular update it and Scan your Window Regularly.
Aug 17, 2012 | Compaq Presario CQ56-115DX Laptop
Power is on but after 2-4 seconds display turns off but power is still on where the power light is in blue.it's not in sleep mode where the power color is orange.it just goes back to normal at random...
Without looking at the monitor to confirm this, I suspect you have failing capacitors which power the HT circuit, simply, the power needed to light the display, is leaking to earth, capacitors have lost the ability to store the charge necessary to illuminate the screen, which is why it is working erratically.
You need to get this checked out by a TV technician.
Jul 23, 2011 | Acer Computers & Internet
2005 altima, check engine light came on....mechanic said it was the crank shaft sensor...replace both of them......light comes back on a week later, then goes out, then comes back on....seems like whenever...
obviously not a mechanic
with bad sensors you would have starting and noticeable engine running problems
have the fault codes read by an accredited service center and check the EVAP system
Feb 17, 2018 | 2005 Nissan Altima
Monitor Goes black, or flickers on and off
The high pitch sound is coming from the inverter. It is faulty and needs to be repaired or replaced. The inverter supplies high voltage to the CCFL lamp, this lamp gives the backlight to the LCD so you can see the LCD images.
Check out LCD parts for parts, service and DIY info. use this link :-
www.lcdparts.net
Aug 29, 2009 | ViewSonic OptiQuest Monitor
Usb mice work for a few weeks and then **** out. wha?????
if your mouse have a ball inside you can clean the roll inside sometime dust on it and do not rotate
Jul 13, 2009 | Mouse Systems Mouse (The Mouse model) by...
My keyboard and mouse will not work at all not even when rebooting! I bought another one and they will not work. Everything else that uses usb is still working! Help!
Here we go, this is the best way to avoid reinstalling duplicate hardware, which we have all done at one time or other. You need to get to the device manager, start, settings, control panel, system, device manager , hardware, now you will see everything installed in your machine, if you see duplicates for the mouse and keyboard remove them, if no yellow marks in the device manager, uninstall both the keyboard and the mouse, when uou reboot, it will have a pop up in the system taskbar that says, found new hardware, and then it will say installing the software for your new hardware. If this doesn't work then we need to go into the "install hardware" also in the control panel, but that should do it, I am giving you a lot of info, but sometimes we can't find you again until a day or two later so I want you to have all possible inf before you start. Also the easiest way of all is this. If the computer was working yesterday or last week, we can do a system restore thus restoring it to a time when everything was ok and everything was working, this is Start, accessories, system tools, system restore, pick the day from the choices shown on the calander and sit back as it restores your machine back to a working computer, have a good night and good luck,Gym
Dec 21, 2008 | Computers & Internet
Black display
start your computer then press f8 to go to advance boot menu then select enable vga to boot. when you get to log in and get your screen try to reinstall the video driver
Jun 04, 2008 | Acer Aspire 4315 Notebook
Mouse Problem
your system may be infected with viruses, so that it becomes busy running the virus, Try installing an antivirus.
Otherwise reinstall Windows.. if you can arrange a seperate mouse then connect it to the machine and see the mouse working well, replace the mouse.
Oct 10, 2007 | Belkin F8E882XBLKPS2 Mouse
Intel Motherboard Logo
23 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
