Question about GE GSL25JFPBS Side by Side Refrigerator
Ice-maker problem i bought the fridge new gsl25jfpbs, but never used the ice-maker.. 3 years later i hook up water to it and problems... i turn the water on and the ice-maker makes one set of ice cubes, dumpeds them in the bucket and them refills the tray, BUT the wtaer doesn't turn off and floods onto the floor... if i turn the water off,, it makes ice-cubes again and truning the water back on will flood the fridge again..... seems like it makes ice, but there is nothing that turns off the water flow hen the tray is full ??? davey 8186455008
  • daveydude Jan 31, 2008
    there is NO wire for the height of the icecubes... the ice-maker was turned off at the electrical switch on the ice-maker....
    water pressure has been tried with city water at about 60psi and with an undersink filtered water supply.. which is alot less.. problem is still there either way...
  • robert samples May 11, 2010
    theese three years you had the fridge did you have the icemaker shut that is did you have the wire arm up how high is your water pressure
    President:
  • 1,314 Answers
Ok do you have a meter a volt meter ill tell you a better way to do it go to the back of the refrigerator and un plug the water valves then open the freezer door turn on the water if you hear the water running replace the valves if you don't replace the ice maker module the range for pressure is 30-120psi the valve just might be sticking from being dry for so long
Posted on Feb 01, 2008
6ya staff
SOURCE:
My BI95 ice maker freezes and has water flow, the mould maker fills, the water continues to run into the bucket and it freezes solid. I changed the mould maker and water valve. The problem remains
If water keeps running after the fill cycle is usually indicates a bad fridge inlet valve. This valve controls the amount of water going into your icemaker. It is found where the water line goes into the fridge, usually in the back of the fridge at the bottom. You would need to cut the power to the fridge, turn off the water supply going into the fridge and remove a panel to get to it. You can check out online what a fridge water inlet valve looks like so you can identify it. It usually has 1-2 water lines going into it and 1-2 wire harnesses attached. You can buy new ones at a appliance parts store or online.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/rick_b814bade9ade93ea
Sep 28, 2015 | U-Line Icemaker
Ice maker not working on GE side by side
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
iyooyi76
Jun 01, 2010 | GE GSL25JFPBS Side by Side Refrigerator
LG LFX23961ST with error code ER IF
could be bad fan. sometimes the sensors on the them go bad
Apr 22, 2010 | LG LFX23961ST Stainless Steel Bottom...
GE PSS25MGMA Crushed ice only, nothing else will select on panel.
Yes , replace the main board . Part number WR55X10656 . There is only partial communication between the main board and the dispensor board . This main board , is behind the 8 " X 10 " panel , on the back of the refrig . Do not replace the dispensor board . I have never come across a bad dispensor board yet . Always a first time though .
Sep 27, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Ice maker not working, ice maker is on, water dispenser is working (supply working)
I have the same make and model. I had to replace the Motherboard. I bought it online $100 and it is really easy to replace. I heard from my neighbors who had the same fridge that they got the $100 refund from GE because it was a manufacturing defect.
Sep 08, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Ice-maker problem
if the water runs constantly when you turn the water on its your valve but if it does it periodacally it probably your icemaker
Apr 29, 2009 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator with ice maker but no hook up
just make sure the lever on the ice maker is up and locked or the switch on the ice maker is off ( i dont know what model you have) but thats all you need to do , if at any thinr it gets turned on dont worry it not a problem it will just cost you a little nore to run . no damage to the fridge or ice maker .. please rate this answer , i am new here and it will be a great help thanks and good luck with your fridge
Jan 16, 2009 | Maytag Refrigerators
Fridge Leak
hi thanks for the question the water in the crisper is caused by a clogged drain tube Pull the fridge away from the wall. remove back panel clean all coils find drain tube in drain tray and clean to inside of fridge thanks the appliance doc
Sep 29, 2008 | Refrigerators
Ice-maker problem
it will respond better if you fill it with scotch
Apr 16, 2017 | Refrigerators
GE GSL25JFPBS Side by Side Refrigerator Logo
215 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Ron Beer
Ron Beer
Level 1 Expert
vince
