Try resetting by:
turn off dishwasher
trip circuit breaker to remove all power to unit
wait 30 seconds
restore power
start dishwasher
the drain pump should start and drain all water then start a cycle. Good luck
Con you check to see if the insulation over the top and sides of the dishwasher was touching the floor and wicked up enough water to get wet? That would reduce the sound dampening characteristics. It is also possible that the hose being shaken off was caused by an issued with something jamming the pump; check the drain grates to see if there is anything you can pull out.
You're correct you have a faulty water inlet valve. At the end of the wash cycle the solenoid in the valve is not closing properly to not allow water to re-enter the tub. For further assistance with this repai
dishwasher will not fill with water: This is often the fill valve. You can test the fill valve coil for continuity with a ohm meter, no needle movement = bad fill valve. You can also test the fill valve for 120 volts at the fill valve with a volt meter, power there and no fill = bad fill valve. No 120 volts there, you will have to trace power back to find the trouble maker. Test things like the float and float switch, wires and timer. Fill valves are very bad for working once or twice and then quitting, if your dishwasher fills the first and second fill cycles and then no more water through the rest of the cycle, replace the fill valve. You will need to remove the access panels to get at the fill valve. Dishwasher fill valves also have a screen built into the valve entrance, this can also get all clogged up and need to be cleaned. -----There's no water entering the machineIf there's no water entering your dishwasher, check these:Water-inlet valveFloat switchWater-inlet valveThe water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.Float switchThe float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
After further inspection of my dishwasher I found a bad gasket under the lower wash arm. Over the years it finally gave up and was shooting a torrent of water through the water in the bottom of the wash tub. When all that water hit the door liner it went up into the lower door vents, into to wire harness, and onto the floor.
Favorite for bosch is the water inlet modual which monitors the water flow in could be faulty, If incorrect pulses take place the motor wont proceed. Otherwise listen for a hum after water stops filling. If there is a hum, the main wash pump is jambed and has to be sorted out.
You could have a defective fill valve that is not shutting off properly. Look for a fill inlet opening somewhere on the inside casing of the wash tub. Usually it is on the left hand side of the machine looking in. While the dishwasher is sitting idle, watch the fill valve opening to see if water is leaking in. It could be a minor as just a drip. However, over a period of several hours you could end up with a wash tub full of water. Over a weekend with no one home, it could overflow onto the floor. The valve usually cannot be repaired and would require replacing. Good luck.
